| Aluminum vs. Salt (per F150) #277845 03/07/15 12:26 AM 03/07/15 12:26 AM |
Joined: Jun 2001 Posts: 493 Minnesota Jeff Peterson OP
Posts: 493 Minnesota | From what I've seen that saltwater can do to aluminum on cats and outboard motors, what do you think will happen to the new F150 Ford Pick-up Trucks that have aluminum body panels? Will winter road salt and ocean seaspray eat these trucks alive? What could Ford have done to them to protect them over time? Is there any "new" protection technology that's transferable to cat tramp frames, pylons, and spars?
| | | Re: Aluminum vs. Salt (per F150)
[Re: Jeff Peterson]
#277847 03/07/15 12:46 AM 03/07/15 12:46 AM |
Posts: 6,049 Sebring, Florida. | When I lived in NH, where they dump salt onto the roads all winter long to melt the ice and snow, most of the auto dealers offered an 'Under spray' package, where they would spray the black goo under your car/truck on all the exposed metal surfaces, to keep them from rusting out with all the salt. I'm guessing if you buy an aluminum F150, you had better pay the extra $600 and get it sprayed!
Blade F16 #777
[Re: Jeff Peterson]
#277850 03/07/15 07:02 AM 03/07/15 07:02 AM |
Posts: 4,119 Northfield Mn | The aluminum will handle it better than the steel. Range Rover has been building aluminum bodied vehicles for a long time.
[Re: Jeff Peterson]
#277859 03/08/15 04:17 AM 03/08/15 04:17 AM |
Joined: Apr 2013 Posts: 858 Victoria Australia Pirate
Posts: 858 Victoria Australia | Alloy bodied vehicles don't use a pure alloy a such, its a mixture alloy of aluminium and magnesium Land Rover's (& I assume other makers) alloy bodies are made from Birmabright, Birmabright is merely a trade name of the old Birmetals Co. (located in Birmingham) for a British standard specification of sheet, ... (it is actually NS4 std). All the major aluminium rolling mills - Alcan, Pechiney, British Aluminium, High Duty Alloys, Alcoa etc. sold the same sheet either under their trade-name or under the relevant British specification. for more try this link (Wikipedia) nb: I'm an Australian, we're a lazy mob when it comes to speech, therefore Alloy = Aluminum (alloy is quicker to type and easier to spell, same shyte/different name)  Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
Kingy started with Impara Cadet #3 / Mosquito #245 & now Mosquitos #1182 & #1740 | | | Re: Aluminum vs. Salt (per F150)
[Re: Jeff Peterson]
#277867 03/08/15 11:07 AM 03/08/15 11:07 AM |
Posts: 12,310 South Carolina | Ford is fighting this process by electrocoating the aluminum panels to electrically and physically isolate the metals, and by using new coatings on all body bolts. To test the long-term durability of these kinds of joints, engineers normally bathe body panels in a saltwater spray during a hot/cold environmental cycle—this encourages the formation of iron oxide. But with aluminum that was just too slow. So they switched to a corrosive acid bath and found that tweaking the metallic coating on the bolts protected the metal admirably. http://www.popularmechanics.com/car...-tested-its-new-aluminum-f-150-16682803/There has been a lot of work done to electrically isolate and/or protect aluminum body and frame components. The TT Roadster I had a few years ago had an aluminum chassis and mostly aluminum body. Audi designed the car with a steel rear section to achieve a 50/50 balance and pioneered a method to connect the steel and aluminum frame/body sections rigidly and protect from galvanic corrosion. I'm sure Ford has done their homework.
Jake Kohl | | | Re: Aluminum vs. Salt (per F150)
[Re: Jeff Peterson]
#277871 03/08/15 04:14 PM 03/08/15 04:14 PM |
Posts: 4,119 Northfield Mn | Delorean's were stainless steel. Rumor always was they were for shipping coke, and could be dumped and retrieved later I'd need be.
Either way, John Z Delorean screwed the Irish in a major way.
[Re: carlbohannon]
#277881 03/09/15 10:00 AM 03/09/15 10:00 AM |
Posts: 12,310 South Carolina | I missed that in his original question!
The corrosion process is an electrical chemical reaction. You can protect the pylons and other aluminum bits by connecting something to it that is more reactive to make a sacrificial anode. This method is used on everything from boat motors, docks, and even the steel natural gas pipes in the ground. If you were to connect a magnesium anode to the aluminum part and make sure it remains in solid electrical contact, it will protect the aluminum. The question then follows; is it worth all of that expense and trouble?
[Re: bacho]
#277882 03/09/15 10:40 AM 03/09/15 10:40 AM |
Posts: 6,049 Sebring, Florida. | Plenty of aluminum aircraft operating in salty conditions, i havent seen too many fall out of the sky.
Actually, they do have a LOT of corrosion problems with the fleets that spend a lot time in the 'salt water' environments. Also, all aircraft have to undergo inspections every 100 hours of flight time, and major inspections and overhauls every 1,000 hrs. and 10,000 hrs. etc. At some point depending on 'cycles' and total time, the entire airframe has to be uncovered, inspected, put back together. They refer to that as a 'heavy check' and it is quite expensive, Delta is parking all 16 of it's 25yr. old 747's due in part to the cost of the upcoming heavy checks. (Millions of dollars, each.) Do you recall many years ago (25?) Aloha 737 came apart in flight? The top of the fuselage ripped right off, sucking one of the Flight Attendants, and a couple of passengers out? That metal (aluminum) failure was attributed to salt water corrosion. http://www.youtube.com/watch?v=8NWW77HnGTc And do you remember a airline down in Miami/Nassau called Chalks Air? The flew their 'flying boats' back and forth to the Bahamas from Miami and Ft. Lauderdale, until they had a spar failure and the subsequent inspections grounded their fleet putting them out of business. http://www.youtube.com/watch?v=95Ca9rmmmPU There was a light plane accident right here in Sebring a couple years ago, a pilot flying an old two seater was circling over his passengers house when the wing spar failed, one wing came off, they both died. http://highlandstoday.com/news/agri...estigating-golf-hammock-crash-ar-306955/ That happens a lot in older light airplanes that don't get flown much and sit outdoors all year round, rain water and condensation collect at the 'low point' which is usually under the belly, right where the main spar passes through. One of the most expensive parts of owning an airplane is all the inspections you have to comply with, on both the engine and airframe, and if they do find any corrosion, it can be VERY expensive to repair/replace. Also, did you see that video of the fire bomber that folded up? Again, and older plane who's main spar snapped on pull up. Watch this: http://www.youtube.com/watch?v=yYKIGT7EgSA
Blade F16 #777
[Re: Timbo]
#277953 03/12/15 07:38 PM 03/12/15 07:38 PM |
Posts: 1,403 | Thought this was a crack in the wings from fatigue and not being fixed properly... As much as we whine and complain about the cost of the 100 hour and annul inspections... I am glad they are there! Been flying Delta lately.... Southwest has skipped a few rudder inspections.... didn't they learn from US Air | | |
2,751
guests, and 449
