| Re: Spray paint graffiti
[Re: gregheebner]
#281996 02/23/16 03:22 PM 02/23/16 03:22 PM |
Posts: 12,310 South Carolina | Is it a dacron or mylar sail? If Mylar, it should be relatively stable against MEK (methyl ethyl ketone) and that MEK is a pretty good solvent and should remove the paint if used carefully.
Jake Kohl | | | Re: Spray paint graffiti
[Re: gregheebner]
#282000 02/23/16 04:26 PM 02/23/16 04:26 PM | MN3
| MN3
Unregistered | I have no idea if it is fabric safe but many spray paints (from a can) can be removed with Acetone | | | Re: Spray paint graffiti
[Re: gregheebner]
#282001 02/23/16 05:21 PM 02/23/16 05:21 PM |
Posts: 12,310 South Carolina | Dacron is more difficult. It's essentially a polyester fabric - which isn't great on it's own against a lot of solvents (it is listed as "marginal" resistance against MEK and Acetone...which isn't great). Dacron sail cloth also has several different coatings and binders that might also be affected by solvents. By the book, there probably isn't an easy way to remove the paint from Dacron without some risk of damage to the cloth but maybe someone else has some more practical experience.
[Re: gregheebner]
#282002 02/23/16 06:10 PM 02/23/16 06:10 PM | MN3
| MN3
Unregistered | spray new paint the color of the sail over the graffiti ? | | | Re: Spray paint graffiti
[Re: Isotope235]
#282013 02/24/16 07:33 AM 02/24/16 07:33 AM |
Posts: 12,310 South Carolina | Eric, great catch! I looked that up in the tables and Xylene does have a good compatibility with Dacron.
Where on the Atlantic coast are you getting tar balls? You should try Long Beach!
#282014 02/24/16 09:58 AM 02/24/16 09:58 AM |
Posts: 5,590 Naples, FL | Where on the Atlantic coast are you getting tar balls? You should try Long Beach!
Pretty much anywhere near commercial shipping. They ballast their hulls with seawater (which invariably seems to have oil or bunker residue) and pump out near the docks. Used to get them a lot up and down FL east coast. Baby oil was a good to get that stuff off your feet.
741
guests, and 92
Mod | | Forums26 Topics22,404 Posts267,055 Members8,150 | Most Online2,167 Dec 19th, 2022 | | | |
