Boom wanted #281972
02/21/16 01:37 AM
02/21/16 01:37 AM
Grafton, NSW
Greg/Debra Offline OP
Grafton, NSW
We are after a boom or blank boom section. Can anyone help?
Thanks.
1140 Gadfly
1434 J.I.B.E.
1727 Atreus
Re: Boom wanted [Re: Greg/Debra] #281974
02/21/16 10:18 AM
02/21/16 10:18 AM
Melbourne
Nic M Offline
Nic M  Offline
Melbourne
Paper tiger or sabre mast cut down. I bought a part length paper tiger section from Goodalls and then took the sail track off it.
Nic Maan
Sanity 1815
Re: Boom wanted [Re: Greg/Debra] #281975
02/21/16 07:37 PM
02/21/16 07:37 PM
Schnoogie84 Offline
Schnoogie84  Offline
I just made one last week out of 48 x 1.6mm anodized tube. I used it for the first time on Sunday at while it bowed a touch it seemed to be strong enough. I modified my old gooseneck to fit.
This place: https://www.aluminiumtc.com.au/store/category/browse/drawn_tubes/anodised/ sells it in 3m lengths already anodized.
You can buy 50mm Aluminium round section from AHPC/Goodalls which the 50mm female/male gooseneck which he sells is made to fit.
I didnt bother with an outhaul track on the new boom, and went for an outhaul system similar to this: (https://encrypted-tbn3.gstatic.com/images?q=tbn:ANd9GcQvjNtCWrSRnOd3ORId-YIXwzkD4GYNr9tFxYfqiYlLLXBv8W6JoDTzOJY) with a purchase system similar to the paper tiger. The line I pull for the outhaul comes through one side of a ronstan RF5 on the boom, and then the RF5 has been modified with an additional cleat and pulley to allow the mast rotation to got through the other side. I think there is a picture of a similar setup on the Mozzie Pics section.
Re: Boom wanted [Re: Greg/Debra] #281976
02/21/16 07:37 PM
02/21/16 07:37 PM
Schnoogie84 Offline
Schnoogie84  Offline
Re: Boom wanted [Re: Greg/Debra] #281977
02/22/16 01:15 AM
02/22/16 01:15 AM
Matt_Stone Offline
Matt_Stone  Offline
Hi Greg
I use a Pacer / Old Paper tiger/ Sabre section.
You can get a cut length or full lenght from Keeley Marine Supplies
Section Code: K02
These Sections are not Anodised
Alternative cut the track off a cut down mossie mast or current PT mast.
You can get tubes e.g. 50mm. i personally don't like as i like to make an outhaul that slides easy inside the boom. On a round section you basically rig up outhaul same as a laser with a dyneema strop. Sometimes they don't like sliding along the boom.
Im making 3 booms in the next 2 weeks. I also make the outhaul cars. Ill post pics later. I have a 3mm 50x40mm in a egg shape, with 1 x 8mm rod welded through the bottom with a 25mm nylon wheel on each side of the plate wide enough to hit the edge of the section. (no captive pins to hold wheels on).
I have a block on the outboard end of the plate ( Greg can post pic) as its a 2:1 system.
Matt
Re: Boom wanted [Re: Greg/Debra] #281978
02/22/16 01:26 AM
02/22/16 01:26 AM
Matt_Stone Offline
Matt_Stone  Offline
On the Multi hull Mayham Video on you tube in the first 30 secs has a good view on Gary Maskeil's outhaul
Re: Boom wanted [Re: Greg/Debra] #281988
02/23/16 04:38 AM
02/23/16 04:38 AM
M
Matthew Dawson Offline
M
Currently between boats
Previously …
Cobra 570
Cobra 581
Mosquito 126
Arafura Cadet 738
Re: Boom wanted [Re: Matt_Stone] #281998
02/23/16 03:50 PM
02/23/16 03:50 PM
Scarecrow
Scarecrow
Originally Posted by Matt_Stone
Hi Greg
If you end up with a non-anodised section a coat of Penetrol (about $30 from bunnings) will keep it shinny and nice (no white powder or finger prints). Redo it at the end of each season. Even better is shark hide or Nyalic but both will hurt the bank balance more.
Re: Boom wanted [Re: Greg/Debra] #282004
02/23/16 07:13 PM
02/23/16 07:13 PM
Grafton, NSW
Grafton, NSW
Thanks everyone for your advice.
Matt, what do you use for an end plug?
1140 Gadfly
1434 J.I.B.E.
1727 Atreus
Re: Boom wanted [Re: Greg/Debra] #282008
02/23/16 09:21 PM
02/23/16 09:21 PM
Matt_Stone Offline
Matt_Stone  Offline
At the gooseneck end i use a k02 to suit boom section from keeley marine supplies.the riley gooseneck slides straight in. On The gooseneck i grind out the pressed in pin and replace with bolt and the shaft that goes in the plug , i weld a nut behind it so the boom cant fall off during a race
Matt
Re: Boom wanted [Re: Greg/Debra] #282009
02/24/16 12:23 AM
02/24/16 12:23 AM
Grafton, NSW
Grafton, NSW
Thanks Matt. Do you have an email address for Keeley Marine?
1140 Gadfly
1434 J.I.B.E.
1727 Atreus
Re: Boom wanted [Re: Greg/Debra] #282010
02/24/16 02:42 AM
02/24/16 02:42 AM
BRISBANE QLD
Alan Erlandsen Offline
BRISBANE QLD
Hi Greg, I'm just going through the gotta build a new boom thing too. LR sails up here in Brisbane have some new but scratched Mosquito mast sections for $300.
More than happy to let you have a third of it for $100. I will even rip the sail track off with the plasma if you want.
Alan
Re: Boom wanted [Re: Greg/Debra] #282023
02/24/16 11:52 PM
02/24/16 11:52 PM
Grafton, NSW
Grafton, NSW
Hi Alan,
Thanks for the offer, but I am going to go with the P/T mast section, as I can get a piece out of a bent mast from one of the Arrow sailors at Grafton.
1140 Gadfly
1434 J.I.B.E.
1727 Atreus
Re: Boom wanted [Re: Greg/Debra] #282027
02/27/16 04:45 PM
02/27/16 04:45 PM
Matt_Stone Offline
Matt_Stone  Offline
Sorry no email or wrb site, still old school
Re: Boom wanted [Re: Greg/Debra] #282028
02/28/16 02:41 AM
02/28/16 02:41 AM
Grafton, NSW
Grafton, NSW
I rang them; very helpful guy there. It is not K02 section I will be using; that is an old oval section. I am using a newer P/T section. Keeley don't have the plug for that but I can probably cut down the K03 to fit.
1140 Gadfly
1434 J.I.B.E.
1727 Atreus
0 registered members (), 676 guests, and 105 spiders.
Posts267,056
