String sucking beam #282226
03/21/16 01:38 PM
03/21/16 01:38 PM
M
Mookie Offline OP
Mookie  Offline OP
M
I'm trying to get a new-to-me Taipan 4.9 back up to snuff, and I was wondering how to run the down haul and rotator lines. There are mentions of them being led or sucked into the front beam, but I can't figure it out. There are openings in the beam, so that's easy, but is there any tensioning? How do you rig that? Thanks in advance.
Re: String sucking beam [Re: Mookie] #282227
03/21/16 02:07 PM
03/21/16 02:07 PM
RickWhite Offline
RickWhite  Offline
Had one, but forgot
Rick
Rick White
www.onlinemarinestore.com
Re: String sucking beam [Re: Mookie] #282230
03/22/16 04:16 AM
03/22/16 04:16 AM
SE MI / NE IN
rehmbo Offline
rehmbo  Offline
SE MI / NE IN
Check page 47 here for a diagram of the C2 cunningham/downhaul takeup:
http://www.goodalldesign.com.au/Catamaran/index.php/owners-corner/documentation/15-c2-manual
Jib sheet takeup is a bit simpler but I couldn't find a drawing. Attempting to describe here:
For Starboard jib sheet, bungie starts at stbd end-cap, goes inside beam to a block on port side, then returns inside beam to stbd side where it is attached to the stbd sheet. Unstretched bungie is usually a bit more than beam length. You may have to adjust length to get the right tension. I found it is easier to attached the bungie to the sheet on the port side and then pull it through as needed.
Reverse for port side sheet.
btw - not all bungie is created equal - don't ask me how I know smile . Go for the good stuff
http://www.apsltd.com/covered-solid-elastomer-stretch-cord.html
I don't have any special takeup for the rotation control. Just looped around the side-stay and terminated at the tramp.
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: String sucking beam [Re: rehmbo] #282237
03/22/16 04:44 PM
03/22/16 04:44 PM
M
Mookie Offline OP
Mookie  Offline OP
M
Thanks for the heads up on the shock chord, I had no idea. To me, this boat is like a big puzzle. Fast, but a lot to figure out, and I really appreciate the rigging info.
Re: String sucking beam [Re: Mookie] #282238
03/22/16 05:06 PM
03/22/16 05:06 PM
SE MI / NE IN
rehmbo Offline
rehmbo  Offline
SE MI / NE IN
Don't be afraid to do some google searches too.
http://www.geocities.ws/f16hpclass/ahpc_taipan_49_how_to_rig.html
This forum has some old threads that would be helpful too. Like this one: http://www.catsailor.com/forums/ubbthreads.php?ubb=showflat&Number=22327
Looks like there is a wealth of information out there. Good luck!
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
0 registered members (), 2,752 guests, and 308 spiders.
