Hobie 14 steering problems #2953
10/04/01 02:06 PM
10/04/01 02:06 PM
heavyair14 Offline OP
I have a 1975 Hobie 14 with what appears to be newer rudder casings on it. But when sailing in winds above 10-15 knots I get alot of weather helm while on one tack. This happens at all points of sail. What is the best way to correct this problem? I have looked at new rudder casings but the cost is to high for the amount of times a year I get to race a Hobie 14. <br><br>
2981- (48 downloads)
Hobie 16 sail #102653
Re: Hobie 14 steering problems [Re: heavyair14] #2954
10/06/01 09:51 PM
10/06/01 09:51 PM
South Louisiana, USA
Clayton Offline
Clayton  Offline
You might want to check the shroud length and or settings. If the mast is tilted one way or another it will handle differently on opposite tacks. Also check the rake on the rudders. They might need to be adjusted (maybe just one if the problem is on one tack). Make sure they are the same. Prop the back of the boat up maybe while on the trailer with the tongue on the ground and check the rudder rake with the rudders in the down and locked position.
<br>
<br>Good luck
<br>Clayton<br><br>
Re: Hobie 14 steering problems [Re: heavyair14] #2955
10/12/01 06:18 PM
10/12/01 06:18 PM
Sweet Home, OR
ScaredyCat Offline
ScaredyCat  Offline
Sweet Home, OR
Make sure the left rudder is on the left side and the right rudder is on the right side! I did it in the past and it makes steerage quite difficult, particularly in heavy winds!
<br>
<br>SC<br><br>
3113- (39 downloads)
Re: Hobie 14 steering problems [Re: ScaredyCat] #2956
10/14/01 03:47 PM
10/14/01 03:47 PM
Will raking the mast help? My mast is as straight as possible. I may need to have the shrouds shortened to rake the mast for frostbite racing anyway. <br><br>
3131- (38 downloads)
0 registered members (), 4,284 guests, and 418 spiders.
