| Re: outboard mounting?
[Re: Clayton]
#29963 02/19/04 11:58 AM 02/19/04 11:58 AM |
Posts: 144 Near SLC, Utah | Clayton:
I'm still thinking about replacing the 9 hp 2-stroke on my Stiletto 27...with something that will push the boat faster for those occasional long, windless, coastal passages while cruising. I wish to improve the motor’s ability to handle head-to-wind motoring when bashing directly home, during those occasional "in-your-face" winds from hell". I also wish to have a charging system on the motor so it will help maintain my battery's charge during my two-week long coastal cruising adventures.
My questions are:
How do you like the 9.9-4?
What does it weigh?
Is it a Honda?
Did you modify the Stiletto's motor bracket or is it stock?
Why did you opt for the 9.9-4 instead of something larger, which costs the boat about the same amount of weight?
How do you handle thh motor and all that wieght when you break down the boat for trailering?
Where to you carry the motor when trailering the boat?
What would your recommendation(s) be for re-powering the Stiletto 27?
Thanks,
[Re: Clayton]
#29966 02/25/04 06:55 PM 02/25/04 06:55 PM |
Posts: 13 | Clayton:
Thanks for the info on your outboard and others you've seen on your local Stilettos.
Armed with that info and other information I've been collecting, I'm presently saving my pennies for a Honda high thrust 20 hp 4 stroke, extra long shaft.
That will more than double my available horses, give me an alternator to charge my batteries and help run my autohelm... I can help reduce pollution and improve my miles I get out of a gallon.
I do a fair amount ot coastal cruising, on the open waters of the Sea of Cortez, in Mexico, on the Pacific Ocean, off southern California, in addition to local lake sailing, here in Utah. Indeed, on some of those coastal trips, we've ended up motoring long distances with no wind. We've also had more than sufficient expereince with opting to motor, rather than sail, when we've wished to make a bee-line to some shelter, when the wind got to be more work than pleasure, in rougher conditions.
Either way, the 9 hp two stroke was lots better than a paddle, but I certainly wished I had a more juice.
Thanks for the info.
Tom | | |
656
guests, and 129
