Hi Scoob
Recall the 10 ft beam Hurricane canted rig set up by Reg Whites son used in the 87 Worrell 1000 -
entered an experimental canting rig cat also that year -
though ill prepared for the race --out of time after building it to test and refine it .
Great fun though ,-a tough learning experience -
The Hurricanr had a simple set up to cant the rig
{from memory ,sorry if some element is missed}
Pretty simple set-up --a three or 5 to one block and cleat set up {as per main sheet blocks } but smaller was located at the side stay bases with a stopper knot end for safety .
The rig could be adjusted or canted to windward in higher winds --release one side and crank in the sheet on the other ,-one could also be added to the forstay to rake back as well .
warning --there is some danger in attempting to adjust the rig manually in higher winds ,-as the power of the rig can easily overpower and also if slack in the rig is induced then gibed violentely the slack -momentum and sudden stop could cause damage -
The large tris use hydrolics of course ,-to adjust rigs -nothing new ,-just adding more adjustment options .
Buoys racing ? not sure of the advantages -
Distance racing where your able to cant the rig and create lift or reduce downward sail pressures and forces only makes sence -This along with spin lift downwind should be very effective in distance racing -
http://www.ics.uci.edu/~truesdel/images/ellabache.a.gif-the adjustable rig also really helps helm balance with spin up by raking the rig not only to windward but aft assisting the CE to CLR equation .{more nutral helm and controllable better feeling cat} --very important in high winds and seas .
We will see this again in cat distance racing this year or next -I,m going to miss the 1000 mile race this year -
{I.ll really miss it } have raced the last 6 in a row plus earlier years ,-but will be following the race here on catsailor --starting May 10 and cheering for all the teams and my favorites from previous races .
Hope to put a different type of 20 together for distance racing based on N A Formula 20 rules outlines and be back for the 05 1000 race .
The n a Formula 20 rules allow canted rigs !!
have fun
Carl
