Jib Sheets on a Tornado #36076
07/25/04 11:27 PM
07/25/04 11:27 PM
Alberta
C
Chris_A Offline OP
Chris_A  Offline OP
C
Alberta
Hello everyone, I have a 78 Sailcraft of Canada Tornado and I am not happy with Barber-Hauler setup for this boat. I do not like the steel wire going port-starboard about 3 feet aft of the front cross beam, and cannot trim the sail without a great effort. Does anyone have pictures of their setup, maybe I have mine wrong. I don't race in regattas so "rules" are not a concern. I have seem some pics threading lines under the tramp but none show enough detail. Thanks in advance for any help offered. Chris in Alberta Canada.
Re: Jib Sheets on a Tornado [Re: Chris_A] #36077
07/28/04 04:04 PM
07/28/04 04:04 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
Sounds like you've not threaded the jib 2:1 purchase correctly around the hexaratchet block. The wire line is called the "horse" and has nothing to do with the barberhauler (the line running into the forebeam from a small block around the jib sheet line). The horse cable allows you to place the sheeting (hexarachet) block fore/aft to change the angle the sail is pulled at, tensioning/easing the leech/foot of the sail to suit conditions.
See my classic tornado rigging gallery at:
Classic Rig
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Re: Jib Sheets on a Tornado [Re: Tornado] #36078
07/30/04 01:23 AM
07/30/04 01:23 AM
Alberta
C
Chris_A Offline OP
Chris_A  Offline OP
C
Alberta
Great pictures! Yup I have my lines snafu'd I'll re-rig and try it out. Thanks for your time and the effort to get these on line.
Re: Jib Sheets on a Tornado [Re: Chris_A] #36079
07/30/04 12:17 PM
07/30/04 12:17 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
You're very welcome Chris! Nice to see a new Tboat owner getting setup.
BTW, we have a Tornado-specific forum going on Yahoo at:
http://groups.yahoo.com/group/TornadoCat/
Stop by and post some questions...
Mike.
Mike Dobbs
Re: Jib Sheets on a Tornado [Re: Tornado] #36080
05/24/06 01:15 PM
05/24/06 01:15 PM
Montreal , QC
CatRon Offline
CatRon  Offline
Montreal , QC
Full Tilt,
I've recently purchased a Tornado and am dicking around with the rigging. It's barberhauler is not set up through the front beam like I've seen on other boats.
Question
If I follow the barberhauler from the starboard side, it starts on a block/becket on the jib sheet, travels into the front beam on the starboard side - how, where.
Through the beam to the port side, exits front beam - how, where - and through a jam cleat.
Any help would be appreciated. Looking for ideas - both new and tried 'n true
CatRon
----------------- H16 '82 Tornado '88
Re: Jib Sheets on a Tornado [Re: CatRon] #36081
05/24/06 04:21 PM
05/24/06 04:21 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
From my Classic Rig up this thread:
Barberhauler attached to jib sheet is the blue w. white fleck ending in a block w. becket...line runs out of shot to the right...:
...and into front beam at an opening near the outer gunwale. This opening has an exit block inside the beam, and a camcleat on a bracket outside the beam:
Then the line exits on the other side through a similar arrangement, ending at another block w. becket on the jib sheet.
You can now haul in the barberhauler from the opposite (ie. windward) side of the boat, causing the jib sheeting point to move forward & outboard on the leeward side.
Mike.
Mike Dobbs
Re: Jib Sheets on a Tornado [Re: Tornado] #36082
05/25/06 06:52 AM
05/25/06 06:52 AM
Montreal , QC
CatRon Offline
CatRon  Offline
Montreal , QC
Thanks!!!
Re: Jib Sheets on a Tornado [Re: Tornado] #36083
05/25/06 09:09 AM
05/25/06 09:09 AM
Long Island, NY
Catius Offline
Catius  Offline
Long Island, NY
Mike.
Mike - I think I have a similar setup on my Mystere. What I struggle with is that if you shorten the barberhauler on one side, you are making it longer on the other side. So at the next tack / gybe, you have to adjust again, the opposite way, right?
And if you don't uncleat before the tack/gybe, you'll have to get the crew to crawl to the leeward side to uncleat the barberhauler so you can pull it in...
At least that's what I've understood of the system so far...I may be missing a few pieces of the workings here. Comments?
Thomas Mystere 6.0
Re: Jib Sheets on a Tornado [Re: Catius] #36084
05/25/06 10:30 AM
05/25/06 10:30 AM
How critical is the barberhauler on these boats?
Re: Jib Sheets on a Tornado [Re: Catius] #36085
05/25/06 11:10 AM
05/25/06 11:10 AM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
You've understood it perfectly...it does take some forethought prior to throwing the gybes. Never struck me as a problem...since I grew on on these boats and it became second nature.
Now I sail the modern rig with spinny/self-tending jib and have not had to think about the 'hauler' again unitl I saw this post...
Mike.
Mike Dobbs
Re: Jib Sheets on a Tornado [Re: waterbug_wpb] #36086
05/25/06 11:11 AM
05/25/06 11:11 AM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
THe 'hauler' was very important for racing to get the jib clew outboard & forward off-wind. Really opened up the slot and prevented backwinding. Not necessary for pleasure-sailing.
Mike.
Mike Dobbs
Re: Jib Sheets on a Tornado [Re: Chris_A] #36087
05/25/06 11:14 AM
05/25/06 11:14 AM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
Hey Chris & CatRon,
You both should join the Tornadocat forum over on the Yahoo Groups...we've got ~200 members and there's lots of photos, advice topics etc. specifically on Tboats.
TornadoCat
Mike Dobbs
Re: Jib Sheets on a Tornado [Re: Tornado] #36088
05/25/06 12:18 PM
05/25/06 12:18 PM
Not that I don't enjoy reading/learning about T's and all the other cats in the open forum...why not a Tornado Forum at CatSailor?
0 registered members (), 349 guests, and 397 spiders.
