Hull taking on water #36383
08/04/04 03:54 PM
08/04/04 03:54 PM
Palm Beach Gardens. FL
palmwolfe Offline OP
What is the best/easiest way to find a hole or spot where water could be coming in ?
Thanks
Re: Hull taking on water [Re: palmwolfe] #36384
08/04/04 05:27 PM
08/04/04 05:27 PM
Simi Valley, CA
jfint Offline
jfint  Offline
Simi Valley, CA
blow air into the hull, taking a shop-vac on revers, or air compressor, or something else and taping it to the drain plug. Then you can take soapy water in a spray bottle and spray the hull. Everywhere that the air you are blowing into the hull is escaping, the soapy water will make bubbles and you can see it.
Josh Fint Prindle 19 "Accident Prone" Moro Bay Sailing
Re: Hull taking on water [Re: jfint] #36385
08/04/04 05:30 PM
08/04/04 05:30 PM
Largo, Florida
papayamon2 Offline
papayamon2  Offline
Largo, Florida
Woa, there! Too much pressure can damage the hull from the inside!! Either have someone blow w/ a straw, or just get the vacuum near to the hole to slightly pressurize the inside.
Kevin
Prindle 18
Re: Hull taking on water [Re: papayamon2] #36386
08/04/04 09:06 PM
08/04/04 09:06 PM
S. Florida
BRoberts Offline
BRoberts  Offline
S. Florida
Right on Kevin!
A "one psi, 1.0 psi", increase in inside hull pressure is a force of 2400 pounds trying to blow the deck off the hull on a 20ft hull. Example: 20ft x 12ins/ft x 10ins average deck width x 1.0 psid = 2400 pounds. That is 1.2 tons!
Be very, very careful.
Bill
Re: Hull taking on water [Re: BRoberts] #36387
08/04/04 09:21 PM
08/04/04 09:21 PM
Simi Valley, CA
jfint Offline
jfint  Offline
Simi Valley, CA
Re: Hull taking on water [Re: jfint] #36388
08/05/04 06:59 AM
08/05/04 06:59 AM
South Florida & the Keys
arbo06 Offline
arbo06  Offline
Kevin,
I used a shop vac as you suggested but I had to make sure that the hose was properly vented to eliminate any back pressure. Hulls are not intended to have "any" pressure exerted from the inside out. I jury rigged the hose to an old hatch cover and drilled several holes in the cover for vents. It worked, I think. See the attached pic.
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Hull taking on water [Re: arbo06] #36389
08/05/04 07:36 AM
08/05/04 07:36 AM
At least your sense of humour is fine!
Re: Hull taking on water [Re: Jake] #36390
08/05/04 07:46 AM
08/05/04 07:46 AM
arbo06 Offline
arbo06  Offline
It's all I got right now. I have two modes, laughin' and cryin'.
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Hull taking on water [Re: palmwolfe] #36391
08/05/04 07:49 AM
08/05/04 07:49 AM
Dallas, Texas
thom Offline
thom  Offline
Dallas, Texas
What kind of boat???
thom
Re: Hull taking on water [Re: thom] #36392
08/05/04 08:26 AM
08/05/04 08:26 AM
Yardley PA
DanWard Offline
DanWard  Offline
Yardley PA
I used a hair dryer on low with the drains open to vent out. It provided plenty pressure to do the soapy water test and didn't damage the hulls...Dan
Re: Hull taking on water [Re: arbo06] #36393
08/05/04 08:30 AM
08/05/04 08:30 AM
Arbo,
At least it seems like your method found the leak!
Re: Hull taking on water [Re: thom] #36394
08/05/04 09:41 AM
08/05/04 09:41 AM
arbo06 Offline
arbo06  Offline
Thom,
Was a H-20, now it's a H-10.
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Hull taking on water [Re: arbo06] #36395
08/05/04 10:06 AM
08/05/04 10:06 AM
Eric -
I'm sure I don't need to tell you that those pieces and parts make great fleet trophies... don't chuck 'em. Some of the coolest awards I've seen were pieces of once-useful booms, masts and rudders. I've been trying to find a dagger board to use in building the tongue-in-cheek Mystere 4.3 Nationals trophy. Every time Kirk gets one in the shop, though, he fixes it and sells it!
Re: Hull taking on water [Re: John Williams] #36396
08/05/04 11:18 AM
08/05/04 11:18 AM
Thanks for all the ideas and laughs, I will try the small shop vac and let you know what I find. The boat is a 1985 P18 and has always been pretty dry.
Thanks again
