| New Rule 40.2 Quick Release Harness??? #39658 11/01/04 11:57 AM 11/01/04 11:57 AM |
Joined: Jun 2001 Posts: 3,116 Annapolis, MD Mark Schneider OP
Posts: 3,116 Annapolis, MD | Hello
Does anyone know what equipment will meet the new rule 40.2?
Apparantly, we have until Jan 1 2006 to use a quick release device on trap harnesses. (I assume my standard harness with a hook will be illegal a year from now)
XMAS is comming Thanks Mark
crac.sailregattas.com
| | | Re: New Rule 40.2 Quick Release Harness???
[Re: Mark Schneider]
#39660 11/01/04 01:27 PM 11/01/04 01:27 PM |
Posts: 12,310 South Carolina | Wouter - Mark is referring to the ISAF rule. I hope that if they continue with the rule that they choose to reword it because I think that it can be interpreted it to mean that our current hook and ring equipment still qualifies...or at least, it's too generic to really indicate what DOES qualify. 40.2 A trapeze or hiking harness shall have a device capable of quickly releasing the competitor from the boat at all times while in use.
Jake Kohl | | | Re: New Rule 40.2 Quick Release Harness???
[Re: Mary]
#39663 11/01/04 03:43 PM 11/01/04 03:43 PM |
Posts: 12,310 South Carolina | I know this isn't perfect either but perhaps something a little more to the point like...only trapeze systems will be allowed on which the attachment point can be disengaged from the harness if it was attached to a submerged object while being worn by the user.
I can understand why they might be squeamish to define the rule any further due to liability and that further definition might also imply that they will need to have a list of approved hardware. However, if they don't make it a little more defined, they will not achieve anything other than giving the issue a little more publicity. Perhaps the publicity is all they hope to achieve - it has got us talking about it in two threads and I'm now thinking about what I'm going to replace my harness with regardless of the rule change.
Jake Kohl | | | I actually of a system that ...
[Re: Rolf_Nilsen]
#39671 11/01/04 06:16 PM 11/01/04 06:16 PM |
Posts: 9,582 North-West Europe | I actually know of a system that would work and not wear down.
I thought of it some 3 years ago when the first discussion were had about this.
I does release the bar completely and easily. No moving parts. I planned to persue it and make a buck out of it but it I kept putting it off.
What shall I do ? Make it public domain or try to make a buck out of it.
This in doubt.
[Re: mmiller]
#39672 11/01/04 06:27 PM 11/01/04 06:27 PM |
Posts: 4,451 West coast of Norway | Sounds like ISAF needs to come with an interpretation of this rule.. I still think it will be enforced (in whatever interpretation is given) as the RRS needs to be respected. If they make a new rule without enforcing it, what is the point of the new rule, and what then about the other rules.. Are they also optional? No, it will be enforced, but we need an interpretation of the rule. However, getting trapped by your trapeeze hook underwater is just one of the possible scenarios. But as we have had one (several?) fatality, I can understand why they try to do something about this. Perhaps helmets and exoskeletons are next? There are several quick release trapeeze hooks on the market , so most harnesses can probably be re-fitted (if this is what ISAF wants from the rule). Ref: http://www.rwo-marine.com/newproducts.htm(Mary, I checked, and could not find a similar product in the catsailor.com store, besides the Bethwaite one. I guess he will be livid if his system is not approved..) | | | Re: New Rule 40.2 Quick Release Harness???
[Re: H17cat]
#39677 11/02/04 04:25 AM 11/02/04 04:25 AM |
Joined: Nov 2002 Posts: 612 Cape Town, South Africa Steve_Kwiksilver
Posts: 612 Cape Town, South Africa | "40.2 A trapeze or hiking harness shall have a device capable of quickly releasing the competitor from the boat at all times while in use. " Although the rule is well-worded, it may be too open to interpretation and will be difficult to prove which harnesses or systems do or don`t qualify. What determines "quickly ?" Some competitors may be able to hold their breath longer than others  . The rule is well written since it only requires that the competitor be released from the boat, which is the desired goal. Under this rule, any harness with a pocket qualifies, as long as you have a pair of wire-cutters in the pocket. I believe they have worded it as such so that you can develop a harness that has the hook, but has a quick-release buckle which enables the sailor to disengage his body from the harness should the harness become tangled,or disengage the hook from the harness, as this would satisfy the requirement of the rule. I don`t think the ball & keyhole system is any better than the hook in this regard, assuming the sailor is trapped under the boat and the trapeze wire is under load, both require the same effort to undo. The keyhole system`s only advantage is that you are unlikely to get it snagged on a sidestay or something else underwater, which is possible with the hook. I think it`s a good rule, and probably highly necessary. However, as someone else posted, the only way of making it enforceable is to have a list of approved harnesses, otherwise you leave it up to the discretion of the Race Officer or protest committee to decide, can you imagine the implications of that ? If a competitor drowns due to his harness becoming trapped after it has been approved for use in the competition, his family could take legal action against the Race Officer, sadly we live in an age where you can sue someone else for allowing you to do something that you should be aware of the dangers of, and where people demand to be able to do a potentially dangerous pastime without accepting the responsibility of that risk. No, here ISAF has to take the lead : If they make the rule, THEY have to enforce it, the only way I can see is to send harnesses for tests, and then have a list of approved models. This will make all our old harnesses obsolete, but it`s the only way to do it properly. This is how all paragliding equipment is treated, it must be certified by DHV tests to be suitable for use. I`ts not a failproof system, and equipment still can fail or not work as designed under certain circumstances, but at least it will help minimize the risks and establish a minimum requirement for equipment. It may not be sold as paragliding equipment if it doesn`t comply with the requirements of the tests. The rule, however, as currently worded, only applies to sailors while they are racing, as it uses the word "competitor" implying that anyone out sailing for the fun of it can still go ahead and drown, so perhaps that needs to be revised. Cheers Steve | | |
1 registered members (edraciunas),
572
guests, and 383
