tramp lacing button required #43334
01/24/05 09:39 AM
01/24/05 09:39 AM
Brighton, UK
grob Offline OP
grob  Offline OP
Brighton, UK
Does anyone know who makes or supplies the "buttons" that attach to the rear beam that you normally lace your trampoline to. Preferably a UK or European supplier. Or even what they are called.
Thanks
Gareth
Re: tramp lacing button required [Re: grob] #43335
01/24/05 10:38 AM
01/24/05 10:38 AM
Houston
carlbohannon Offline
Houston
Marstrom has them for the Tornado and A. Hobie has them for the H20.
Try and find the kind that have a monel tube inside (I don't know where mine came from) The plastic has long since disappeared but the monel tube and large head monel rivet work fine without it and will probably last as long as the beam
Re: tramp lacing button required [Re: carlbohannon] #43336
01/26/05 04:15 AM
01/26/05 04:15 AM
Brighton, UK
grob Offline OP
grob  Offline OP
Brighton, UK
I am still struggling to find these parts, are they specially made for lacing a trampoline or they more commonly used for something else, i.e. attaching boat covers etc.
Re: tramp lacing button required [Re: grob] #43337
01/26/05 06:30 AM
01/26/05 06:30 AM
Ref: http://www.funcat-sailing.de/Tornado/sitebeamsbeschlaege.htm
Look for the aft view of a Tornado rear-beam, there you can see the rivets you need.
You can order them from these guys, in Germany, or:
http://www.catsailing.net/shop/rearbeam.htm also in Germany.
Otherwise, you can go directly to http://www.marstrom.com, and order them there from his webshop.
I dont know which of these will respond quickest, but I have mixed experiences buying small items directly from Marstrøm.
If you are desperate, forget about the rivets and make your own SS hooks, thread the other end of the hook and bolt them with some nylon washers and a lock-nut on the front side of the aft-beam. Requires some fiddling with battens inside, to tighten the lock-nut, but lets you raise the trampoline a bit since it dont have to go under the beam anymore.
If you find similar bolts/rivets, they are probably not in monel, but with a alu house and steel nail. The nail will quickly rust and the fitting will break.
My best tip, order some from the guys in Germany.. I think Wolfgang Heineman works for Catsailing, and he is a nice guy to deal with.
Re: tramp lacing button required [Re: grob] #43338
01/26/05 01:39 PM
01/26/05 01:39 PM
Gareth,
I can probably help you out with these.
Send me a private email and I'll send you some pictures to make it is exactly what you want.
phillbrander@bigpond.com
Re: tramp lacing button required [Re: carlbohannon] #43339
01/26/05 10:39 PM
01/26/05 10:39 PM
New Jersey
Bob_Fraser Offline
Bob_Fraser  Offline
New Jersey
A solution I used was to buy 3/16" I.D. vinyl tubing cut into 1/2" long lengths to use as a spacer between the rear beam and a 3/16" washer secured by a #10 x 1" stainless steel self tapping pan head screw. Not quite as elegant but it has been in use now for 7 or 8 years without any failures.
Bob Fraser
H20
Re: tramp lacing button required [Re: phill] #43340
01/27/05 04:34 AM
01/27/05 04:34 AM
Brighton, UK
grob Offline OP
grob  Offline OP
Brighton, UK
Thanks Rolf, Phil.
I have since found another source and much cheaper i.e. 0.15 Euros instead of 2.15 euros for plastic or the same price 2.15 euros for stainless steel.
see www.pointnorth.co.uk item no LB2 for black plastic or LB3 for stainless steel.
I will get some samples, make sure they are suitable and report back.
Thanks
Gareth
www.fourhulls.com
Re: tramp lacing button required [Re: grob] #43341
01/27/05 05:36 AM
01/27/05 05:36 AM
Bob: I had a stainless self-tapping screw trough an aluminium section on my rudderstocks. It failed last summer, with badly corroded alu where it went trough the stock (factory mounted).
All literature also advise against letting steel and alu be in contact without insulation between, even if you have good experience with it.
Gareth, the heads looks nice, but how do you plan to attach them to your beam? The sailcloth section of their site was not cheap..
Looking forward to hear about your experiences.
Re: tramp lacing button required [Re: grob] #43342
01/27/05 10:11 AM
01/27/05 10:11 AM
could you not just purchase some plastic tubing and cut it to small even sections. Then place a big head rivit in the middle of it and voila!
Here you go [Re: Jake] #43343
01/27/05 11:29 AM
01/27/05 11:29 AM
Dunedin Causeway, FL
David Parker Offline
This is what Mystere uses. Just look at any RWO catalogue.
Try RWO R2905 or something else on this page.
RWO tramp hooks
Tramp lacing [Re: David Parker] #43344
01/27/05 03:25 PM
01/27/05 03:25 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
On older Tboats, the rear beam lacing was attached by standard stainless eyestraps rivetted to the beam.
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Re: tramp lacing button required [Re: grob] #43345
01/29/05 08:10 PM
01/29/05 08:10 PM
Houston
Houston
Grob
Thanks for finding these things and thanks for posting the link.
From the picture they look like what I purchased from Redhead Sails. They were nylon, they worked just fine
I requested some information on the dimensions. If it's even close to what I need I am going to buy 100-200. My Tornado uses 16 and my F14 uses 28.
Every time I find a deal like this I buy enough to last a couple of years and I have never regretted it.
1 registered members (Damon Linkous), 2,478 guests, and 337 spiders.
