Help Comptip repair #46928
04/06/05 02:29 PM
04/06/05 02:29 PM
Açores- PORTUGAL
hobie_acores Offline OP
Açores- PORTUGAL
Hi all sailors!!
I bought a used H-16, but the problem is that the comptip got broke in the process of shipping. My question is if there is any possibility of fixing the comptip with some good layers of fiber? I took some pics to help.
Thanks!
Re: Help Comptip repair [Re: hobie_acores] #46929
04/08/05 12:33 AM
04/08/05 12:33 AM
Hong Kong
schobiedoo Offline
schobiedoo  Offline
Hong Kong
That looks like toast to me.
Considering the strain and mast bend that you place on the top of the mast when you crank on the downhaul, I don't think that a repair will be good enough unless you get a very expensive repair job done by a specialist.
If you've got shipping insurance then you may be able to get them to stump up for a new mast, otherwise I'd try to find a new comptip and get that fitted. There must be loads of H16 masts around that have been bent with a perfectly good comptip on them that may be possible to use if you're on a budget. There are certainly lots of old masts kicking around on our beach but that's in Hong Kong!
Re: Help Comptip repair [Re: hobie_acores] #46930
04/08/05 02:26 PM
04/08/05 02:26 PM
Ontario, Canada
Captain_Dave Offline
Ontario, Canada
Although I do not have experience fixing masts, I do have a lot of experience with composites and repairs. If that comptip is carbon-fiber it is probably fixable judging by the look of the photo. However, it may not be fixable by you. Also, (although I can`t see any in the photo) if there are longitudinal breaks in the mast - cracks running up and down the mast, extending more than a few inches - it may be a real problem to fix and not safe. On the other hand, if all you have is a horizontal break, as the photo shows, you could attempt a fix as follows: (1) build a jig/support system that holds both broken halves in PERFECT alignment throughout the repair, and also lets you have some access to the break point. This can be done with carefully selected (straight and true)lumber built into a U-channel type box/trough. (2) You MUST be able to obtain a 3 foot piece of aluminum or steel tubing that fits perfectly snug within the diameter of the comptip. This piece must be strong enough to withstand the forces of a mast-like application "all by itself" - or very close to it. (3) Degrease/dewax the interior(especially) as well as exterior of the repair area. Acetone can be used over several applications, with clean cloths used for each application, but a commerial product from an auto body supplier would work best. Clean, Clean and clean again! Also perform this procedure with the aluminum/steel insert you will be using. (4) Coarsely and completely abraid the inside of the comptip(tricky but possible) and the insert. But only do this after the cleaning. (5) Using a low viscosity epoxy (I like west system) thinly coat the entire insert and contact area inside the comptip. (6)Then mix up a generous batch of medium viscosity epoxy with fumed silica or milled fiberglass (also west system) to the thickness of smooth peanut butter. Note: slow cure epoxies form better bonds that fast cure epoxies.(7) Now, here is the critical part. Being overly generous with the thick peanut-butter-type mixture, apply it to both the insert and inside the comptip (which are still wet or tacky with the thin epoxy) - taking exceptional care to make sure All GAPS between the repair insert and the inside wall of the comptip will be filled, join the two halves of the mast. Be careful to keep the insert centered on the break. Check and re-check the alignment because this is a "one shot" deal. However, avoid moving the repair halves as much as possible. Let it cure 24 hrs, then remove it from the jig and carefully grind off all excess epoxy. Taping around the comptip about 1/4 inch from the break (before the repair) will make this part much easier. Touch up with flat black paint. If you want extra support or confidence, some strategically placed rivets using stainless covering plates (similar in thickness to your mast tang) both above and below the repair may really help. These do not have to be big, just well-placed and tidy-looking. Just be sure the rivets are long enough to make it through the stainless plate/support, the comptip AND the repair insert too.
Good Luck,
Re: Help Comptip repair [Re: hobie_acores] #46931
04/10/05 07:52 PM
04/10/05 07:52 PM
I saw a new comptip on ebay about a week ago. I don't remember what the bid was at, but probably worth looking into.
Re: Help Comptip repair [Re: Karl_Brogger] #46932
04/10/05 09:38 PM
04/10/05 09:38 PM
White Bear Lake, MN
h17racer Offline
h17racer  Offline
White Bear Lake, MN
According to Hobie the comptip is fiberglass.
Had the beginings of some cracks in mine last season. Laid it up with cloth and resin and it performed just fine all last season.
Your damage looks significant.
Probably a used comptip through Ebay or an area dealer would be the safest approach in the long run.
Good luck, Tom G
1 registered members (Damon Linkous), 2,526 guests, and 167 spiders.
