Trapeze lines #47421
04/13/05 03:50 PM
04/13/05 03:50 PM
Midland
Mac05 Offline OP
Mac05  Offline OP
Midland
I am making 4 new trap lines from 1x19 ss coated wire and was wondering if it is OK to make 2 lines from one wire - use one thimble for both lines per side. Is this structurally sound?
Mac
Re: Trapeze lines [Re: Mac05] #47422
04/14/05 12:21 AM
04/14/05 12:21 AM
Hong Kong
schobiedoo Offline
schobiedoo  Offline
Hong Kong
Sounds like it will hold, but why not just make up two wires?
In the future if one corrodes, then you just replace that one and not both.
Re: Trapeze lines [Re: Mac05] #47423
04/17/05 12:49 AM
04/17/05 12:49 AM
St. Louis, MO
nova Offline
nova  Offline
St. Louis, MO
It would work. I have mine like that. Wish I had two instead. I use one line 90 or more percent of the time. But I have to mess with all four lines every time I set up. Wish I could just add the one if I would need it. Separate them so you have one less thing to hassle with.
Re: Trapeze lines [Re: nova] #47424
04/17/05 01:17 PM
04/17/05 01:17 PM
Midland
Mac05 Offline OP
Mac05  Offline OP
Midland
Thanks for the above info. I've made 4 separate lines with integrated blocks. Now we just need to get rid of the ice!
Re: Trapeze lines [Re: nova] #47425
04/18/05 02:07 PM
04/18/05 02:07 PM
North Carolina
hrtsailor Offline
hrtsailor  Offline
North Carolina
Nova,
Why do you say you have to "mess with" the trapeze lines every time you set up? I leave trapeze wires and shrouds connected at all times. When I put down the mast I coil up the slack and tie them on the tramp. Setting up I use a tripod to set the mast on and uncoil the shrouds and trapeze wires. I raise the mast alone so I have to be careful the wires don't get caught on the tramp frame. I temporarily tie the trapeze wire bungee cords up near the dolphin striker to keep them in position. I've been doing it that way for 20 years.
Howard
Re: Trapeze lines [Re: hrtsailor] #47426
04/19/05 11:34 AM
04/19/05 11:34 AM
Central Texas
yoh Offline
yoh  Offline
Central Texas
the trap wire set up will work like that ... IIRC you can buy them like that from Murray...
Boat set up... I have to remove all shrouds and wires and forestay in order to store the mast in my garage. If the mast remains on the trailer and you are not concerned about people stealing you stuff - sure keep it attached to boat and mast. It will safe you some time setting the boat up.
Patrick
Patrick, Hobie 16 '85
Re: Trapeze lines [Re: yoh] #47427
04/19/05 09:08 PM
04/19/05 09:08 PM
North Carolina
hrtsailor Offline
hrtsailor  Offline
North Carolina
I can understand why you remove everything to a safe storage area. I don't have the problem since I put the boat in my backyard so I leave everything connected. Besides, my garage is not deep enough to get the mast into it.
Howard
0 registered members (), 3,316 guests, and 345 spiders.
