Hobie 17 questions #49371
05/16/05 02:02 PM
05/16/05 02:02 PM
bolivar Offline OP
bolivar  Offline OP
I have just started my second season on my Hobie 17 and found it difficult to "find" the speed again. I read Rick White's book this winter and finally managed to make a smooth (and quick) tack!
I have two questions that probably most of you can answer quite easily:
1. I do not have a jib, what is the best way/position to mount a wind vane? And what type?
2. How do you control mast rotation? Where/how do you use the lining/cleating?
Thanks,
Bart
Re: Hobie 17 questions [Re: bolivar] #49372
05/16/05 02:36 PM
05/16/05 02:36 PM
California
mmiller Offline
mmiller  Offline
California
Vane? Try two CM7703 Bent to suit your needs. One on each adjuster at the bow. Other than that. One off the front of the mast would work. We used to have an adapter for that, but looks like its not available any longer.
Mast rotation is a line tied at a cleat on the boom that then runs to the rotater arm and back to the boom cleat. Basic rotation: Rotate to near (pointing at) the shrouds upwind and 90 degrees plus downwind. I haven't raced the 17 in awhile, there is likely to be more fine tuning.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: Hobie 17 questions [Re: mmiller] #49373
05/17/05 02:50 PM
05/17/05 02:50 PM
Dunedin Causeway, FL
hobiephil Offline
hobiephil  Offline
Most racers use cassette or video or 8-track tape on the bridle wires.
Matt remembered well about the rotator setting.
Re: Hobie 17 questions [Re: hobiephil] #49374
05/17/05 03:47 PM
05/17/05 03:47 PM
North Carolina
hrtsailor Offline
hrtsailor  Offline
North Carolina
A couple of pieces of yarn work as well or better than cassette tape and won't tear off when you are trailering the boat.
Howard
Re: Hobie 17 questions [Re: mmiller] #49375
05/18/05 01:44 AM
05/18/05 01:44 AM
bolivar Offline OP
bolivar  Offline OP
Matt - What does CM7703 stand for?
Bart
Re: Hobie 17 questions [Re: bolivar] #49376
05/19/05 12:17 PM
05/19/05 12:17 PM
California
mmiller Offline
mmiller  Offline
California
That is the part number for a standard bridle vane. CM was for Coffee Marine... the original vendor. Hobie makes these now.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: Hobie 17 questions [Re: mmiller] #49377
11/02/05 03:00 AM
11/02/05 03:00 AM
I use a Telo-Cat on mine and love it. Just put it a safe plae when you take it off>
Doug
0 registered members (), 482 guests, and 200 spiders.
Posts267,056
