| Re: Which cat is the fastest?
[Re: Wouter]
#52028 06/30/05 11:57 AM 06/30/05 11:57 AM |
Posts: 778 Houston |
The standard A-cat would beat the M18 and category 1 18sq's upwind, you think ?
Think again !
I disagree, it strongly depends on wind speed. I do not have any experience with the M18 but, I have watched A-Class against Cat 1 18 sq for 3 years and have sailed in it for 1 year. Upwind: The A-class has an advantage in very light wind The A-class has an advantage from the point the A's fly a hull until the 18 sq starts to trap. From that point until the A's can't control it's even. After that the 18 sq's have the advantage. Downwind. It's even until the A's go wild. After that the A's are faster until it's too scary to wild thing (I have never seen an 18 sq go wild.) This has been an gradual development. When the A's first appeared in my area 4-5 years ago, the 18 sq was faster. But, the A-class skippers have been getting faster mostly due to improved techniques All of this depends on the skipper having enough experience to sail the optimum course for wind and wave. | | | Re: gilligans
[Re: thom]
#52030 06/30/05 01:55 PM 06/30/05 01:55 PM |
Posts: 12,310 South Carolina | In heavy stuff I would go with the SC20. It will take alot more abuse than a T and with the 12' beam its more forgiving. Seriously? I've seen more SC20's have fitting and hull failures than Tornados (I can recount three critical SC20 issues - 2 hulls peeling up at the shrouds and one beam/hull retainer pin failure). However, to keep that in perspective, the SC20s that suffered damage had a good bit of age on them. With regard to websites, you'll have a hard time finding much on the CF20 as it is pretty much a custom one-off that they're working the bugs out of. You can find out more about the Supercats at www.aquarius-sail.com
Jake Kohl | | | Re: gilligans
[Re: jimi]
#52033 06/30/05 03:28 PM 06/30/05 03:28 PM |
Posts: 833 St. Louis, MO, | Is the ARC-21 the same cat as the Supercat 20? - 'Cause I did not find any info on the Supercat 20 at "aquarius-sail.com". No the ARC21 is a different boat. The CFR20 is a one of a kind as far as I know. There is one CFR20 being sailed in FL. The SC20 Tall Rig or SC20TR is different from a standard SC20 only in the sail and mast plan. The difference is huge and the SC20 is a totally different animal than the SC20TR. Mike Hill www.stlouiscats.com
Mike Hill N20 #1005
| | | Re: gilligans
[Re: thom]
#52035 06/30/05 08:42 PM 06/30/05 08:42 PM |
Posts: 3,906 Clermont, FL, USA | Yeah and you would think the T and SC20TR would have a DPN in the same time zone.
SuperCat 20 TR, Unmod n/s SC20H 63.8 67.1 65.0 63.6 59.8
Tornado (Int.) 2-Trap spi TORN 59.0 62.7 60.5 57.9 55.5
So which is it, is the SC really fast with gift DPN, or a dog compared to the T?
| | | Re: gilligans
[Re: jimi]
#52040 07/01/05 07:52 AM 07/01/05 07:52 AM |
Posts: 351 Dallas, Texas | 20 LOA, 12'beam, 360sq ft main/jib, don't know what the spin size for certain but I think its around 600sq ft. and approximately 475lbs. Roberts said its the same boat basically as the ARC22 just 2 feet shorter. I believe the masts are different regarding spreaders and prebend.
thom
| | | Re: gilligans
[Re: thom]
#52041 07/01/05 08:35 AM 07/01/05 08:35 AM |
Posts: 3,906 Clermont, FL, USA | It all really depends on whose sailing the boat...
thom I must have missed the multiplier for that one.
[Re: Word]
#52042 07/01/05 09:08 AM 07/01/05 09:08 AM |
Posts: 3,906 Clermont, FL, USA | Ding; You are comparing SC 20TR base rating(no spin, pin head main) to that of the optimized Tornado. Hence, a big rating difference. If we add the spin and square top mods to the SC 20TR, I think the numbers get alot closer. Still, light to medium air, the SC 20 TR rating is gravy. Heavy air, and I think the T's rating is pretty sweet. Anyway, who said portsmoth rating/racing is fair? Good point on the numbers: SuperCat 20 TR, spin and squr top mn SC20H 60.9 64.3 62.1 60.7 57.5 Tornado (Int.) 2-Trap spi TORN 59.0 62.7 60.5 57.9 55.5 Keep in mind the SC20 TR finally took a rating hit for 05'. I have less of an issue with the new SC 20 TR numbers. The 'T' is the fastest 20 foot multihull in a breeze including the M20, SC 20 TR, Inter 20, N6.0 and the CFR 20. As Jake pointed out there aren't any Eagles in the US yet, but I suspect the Eagle will give the 'T' a run for its money. The SC 20 TR is NOT a big air boat. It is optimized for light air and is simply out of it's element in a breeze, sooner or later it's stick down hull up. As for the comment about DPN being fair. I'm sorry have you not met me... I'm David (DPN is a POS) Ingram. Dave
[Re: David Ingram]
#52043 07/01/05 03:27 PM 07/01/05 03:27 PM |
Posts: 5,590 Naples, FL | I'm sorry have you not met me... I'm David (DPN is a POS) Ingram.
Dave Sounds like a good sail number: [color:"red"] DPN za POS [/color]
4,120
guests, and 684
