Daggerboards in surf- control #52472
07/06/05 04:54 PM
07/06/05 04:54 PM
NC
calcheck Offline OP
calcheck  Offline OP
NC
Just started sailing the Supercat 19 without daggerboards since I'm launching in the surf. Can anyone elaborate how to keep them from falling into the wells while heading out through the surf. In the past I only sailed a Hobie 16. Does anyone have a picture - do you attach something to the shroud to keep it in position- can it be activated from across the tramp? Do you use mechanical advantage incase you have small crew? Thanks in advance John
Re: Daggerboards in surf- control [Re: calcheck] #52473
07/06/05 08:11 PM
07/06/05 08:11 PM
Sounds like you need to install some new daggerboard well gaskets.
Or you could install a bungie board holder similar to the 6.0's.
Re: Daggerboards in surf- control [Re: calcheck] #52474
07/06/05 08:44 PM
07/06/05 08:44 PM
I'm not familiar with the S19 setup but for ideas; this is a bunji with a piece of PVC surrounded by foam. It helps put a side load on the daggerboard to help keep it where you leave it in the hull. Works beautifully and is used on the Nacra 6.0 and 5.2 (shown).
Re: Daggerboards in surf- control [Re: Jake] #52475
07/06/05 09:46 PM
07/06/05 09:46 PM
South Florida
SOMA Offline
SOMA  Offline
South Florida
The Hobie 18 has a bungee that is tied to a hole on the top end of the daggerboard and then tied to a spot near the front crossbar. This keeps forward tension on the daggerboard so it will not slip down when up.
Fred F (ex Hobie 18)
Re: Daggerboards in surf- control [Re: Jake] #52476
07/06/05 10:14 PM
07/06/05 10:14 PM
League City, TX
flumpmaster Offline
flumpmaster  Offline
League City, TX
Hobie used to use the same system on the Tiger dagger boards. It worked well but if your boards push down almost flush to the deck then the tube can slip over the top over the board - so next time you raise the board there is nothing to hold it up. They are now using a small rubber wiper that applies slight side force to the boards. It is screwed into the deck at the mid point of the board. This system works very well can could be applied to any boat with dagger boards. The parts are available as an inexpensive kit. This system is very similar to how the Nacra 20 dagger boards are secured.
Re: Daggerboards in surf- control [Re: flumpmaster] #52477
07/07/05 08:45 AM
07/07/05 08:45 AM
NC
calcheck Offline OP
calcheck  Offline OP
NC
Thanks- I was thinking of attaching something to the shroud and using a pulley- this is much simpler! The first owner rebuilt the wells since they were sticking.- I have been out in 15knots- It really flew and handles well without boards can't wait to try them. A side question- can you stand on the board for righting- or is that too hard on them or the well?
Re: Daggerboards in surf- control [Re: calcheck] #52478
07/07/05 08:57 AM
07/07/05 08:57 AM
The daggerboard is strong enough to support a good deal of the entire boat and crew weight while sailing and flying a hull. I can speak for My Nacra 5.2, 6.0NA, and F18 in that I could easily stand off the extended end easily for righting (I weigh about 170lbs).
Re: Daggerboards in surf- control [Re: Jake] #52479
07/07/05 10:19 AM
07/07/05 10:19 AM
NC
calcheck Offline OP
calcheck  Offline OP
NC
I should mention I am 215 lbs -dry!! that could be a factor
Re: Daggerboards in surf- control [Re: calcheck] #52480
07/07/05 10:47 AM
07/07/05 10:47 AM
then don't stand on the very tip end of the board - you should be OK.
Re: Daggerboards in surf- control [Re: flumpmaster] #52481
08/23/05 05:43 PM
08/23/05 05:43 PM
Bloomington, IN
jbecker Offline
jbecker  Offline
Bloomington, IN
I just acquired an older Tiger that has the old system. I haven't seen a kit like this in any catalogs. Where might I find it? Thanks.
Jeff
Tiger 849
Re: Daggerboards in surf- control [Re: jbecker] #52482
08/23/05 06:17 PM
08/23/05 06:17 PM
League City, TX
flumpmaster Offline
flumpmaster  Offline
League City, TX
Contact your local Hobie dealer - or Murrays.com (apologies if you are carrying this gizmo in your store Rick).
Chris.
Re: Daggerboards in surf- control [Re: jbecker] #52483
08/24/05 06:19 AM
08/24/05 06:19 AM
Commerce, MI
tigerboy1 Offline
tigerboy1  Offline
Commerce, MI
The various DB retention systems work OK but can't be trusted...especially in the surf. Wave action and the pitching of the boat can cause your boards to fall down into the wells. My crew and I remove and stow the DB's under the tramp hiking straps when launching from or landing on the beach. Only when we are through the surf line and in deep enough water do we engage the DB's in the wells. It's not good for the wells or the boards to have one slip down accidently and grind the tips off. Keep 'em on the tramp until it's safe.
Expert DB Repair Guy
0 registered members (), 14,809 guests, and 797 spiders.
Most Online22,490
5 hours ago
