| Re: NACRA 5.0 questions - help!
[Re: mangu]
#53464 07/18/05 06:05 PM 07/18/05 06:05 PM |
Posts: 12,310 South Carolina | The factory Nacra rudder system should easily adjust the rudders where they need to be...be sure you check the rudder toe in to make sure they are aligned together - strange things can happen if they are out of alignment. Could you possibly post some pictures of the rudder system and/or the boat assembled?
Jake Kohl | | | Re: NACRA 5.0 questions - help!
[Re: mangu]
#53465 07/18/05 08:01 PM 07/18/05 08:01 PM |
Joined: May 2002 Posts: 1,037 Central California ejpoulsen
Posts: 1,037 Central California | I had a 5.0 and found it sailed very well without too much rake (ie no where near the H16 settings)--can't recall exactly how much I ended up with. Also, the nylon screws were plenty long; in fact, I had them only barely protruding from the casing and had a comfortable/small about of weather helm.
BTW, an unused 5.0 is a sweet find!
[Re: mangu]
#53469 07/19/05 12:35 PM 07/19/05 12:35 PM |
Joined: Mar 2005 Posts: 2,074 Northfield,NH USA bullswan
Posts: 2,074 Northfield,NH USA | I've also checked to see if I raised the mast too high when I adjusted the dolphin striker - don't think so.
I don't get this..... When you tighten the lower nut on the mast post you don't raise the mast up, you raise the main beam up - pre-bend. Right? I just replaced the mast post and the instructions that came with it say that the distance from the top of the top nut (on top of the beam in other words)to the bottom of the mast ball should be 3/4 to 1 inch otherwise cut the rod down if it is too high. Mine was like 1 1/2 -1 3/4 inches which would have led to a connection on the shrouds and forestay extensions to about the top holes..... Could that also be the case with yours..? Greg
The nice part about being a pessimist is that you are constantly being either proven right or pleasantly surprised. - George Will "It's not that liberals aren't smart, it's just that so much of what they know isn't so" -Ronald Reagan | | | Re: NACRA 5.0 questions - help!
[Re: mangu]
#53471 07/20/05 10:03 AM 07/20/05 10:03 AM |
Posts: 2,074 Northfield,NH USA | Actually Dan, I'm a new 5.5 SL owner. I'm not sure how much tuning advice I could give that would only screw you up for a 5.0. To answer you, my rudder nylon screw is out. No weather helm. I was very careful adjusting alignment first and then through trial and error after each sailing run tweaked the rake. It's perfect right NOW. Be glad to compare notes though. I'm working on simplifying the whole process from set-up to actual sailing to K.I.S.S. standards so my 9 year old son A) doesn't get board with the set-up process and B)can understand the principles of sailing while enjoying the hell out of the speed and thrill of doing the wild thing. To that end I've done a lot of things that racing enthusists on this website will find high treason. For instance, I got rid of the deluxe four way jib sheet adjustment (I can put it back on later if/when I want) to neaten up the tramp and give me one less thing to have to say to him over and over, "Watch out, don't step on that!" I simply shackle the sheet blocks to the tracks. This week we have engineered (with my wife as sole judge of the safety factor) our methodology of stepping the mast with just the two of use. We utilize a front winch attached to the forestay and the jib halyard attached to the bridle and everything works smooth as silk. (Hey, my wife was even impressed). Now we have clearance to go sailing just the two of us and that is ALL that is important to me. I was given the gift of sailing pleasure by my dad, who died not long after,  and I want to pass that on. Plus, if I can take a friend or two of his sailing once a week I'll be doing my part for the sport itself. My wife's father is a retired sailing coach from M.I.T. and he has been grateful for this opportunity to pass on a little of what he knows and to get a common thread to his grandchild. He's almost 80 but you should see the two of them hooting and hollering out on the wire. Big grins on both. My job is just to make it happen, safely and often. If it's not tuned exactly perfectly I don't much care, quite frankly. There will be time for that. Good luck and I'll help when I can. Greg
[Re: bullswan]
#53472 07/24/05 09:28 PM 07/24/05 09:28 PM |
Posts: 7 | Greg, Glad to see someone else has the same beginning thoughts I have. I removed the whole jib traveler system temporarily for the mental health of my rookie crew. I am searching for ways to get a better angle pointing but am happy to learn as I go! Going to play with mast rake, bend, and rotation next! Just a thought on your winch system. Do you use any side stays on the way up? I found that a quick line tied to the front trap wire on each side and led down to the corners of the front crossbar gives me a rock solid mast on the way up. I was having sway problems and was concerned for the safety of those around me! Now with the temporary hoisting "guy wires" it is a really safe and easy task. Now mounting a winch comes next. Sorry if this is all redundant things you had thought of...just thought it might help!  Greg II | | | Re: NACRA 5.0 questions - help!
[Re: lifeteammedic]
#53473 07/24/05 10:11 PM 07/24/05 10:11 PM |
Posts: 2,074 Northfield,NH USA | That is funny cause I just said to my wife/crew yesterday.... "Think I'll play with the mast rake next." On the mast stepping,... After turning the mast on it's side and setting the pin in I usually swivel the mast to one side till the port shroud is taunt and then I have something to pull against. I can't picture exactly what you are doing right off with the trap lines but I promise to stand out at the boat and visualize it tomorrow as well. Always looking for a new idea. Especially if it adds to safety. I do like the idea of bring the mast up straight down the middle of the boat since it would make the winch mounted on the post load better than it does with my off to the side method. I'm very interested in anything that shortens set-up time as well. I find the attention span of my crew tends to wander. I'm thinking of setting up a fixed schedule of tasks and who they are assigned to (similar to a pre-flight airplane pilot checklist). Seems we always have either someone standing around waiting for orders or missing a step. Probably by October we'll have it down just to put it away for winter. I starting thinking about utilizing an old electric winch I have lying around here and mounting it (not permanently) on the rear bar of my trailer then running a line attached to the winch under the trailer up to a block at the base of the post on the trailer (that holds the mast up while traveling), up that post to a block and then attach it to the forestay. The beauty of the electric winch is a long remote control that would let me steady the mast and lift it all from the back of the trailer. I could then walk right up with it and using a little aluminum ladder I find handy to get onto the tramp. I also love the tip I read on this forum a while back about attaching the job halyard to a shackle on the bridle to take the weight off the forestay and let you attach the forestay to the bridle without having to hold everything up in the air while you pull on the forestay and slip a pin and a ring clip on. That is a great step to add to the procedure. Great to talk to you about this though. Thanks for the email. Feel free to email direct at Gregoryhill@verizon.net anytime. Greg
[Re: mangu]
#53476 07/31/05 08:55 AM 07/31/05 08:55 AM |
Posts: 1,479 Thailand | >asmeticral hulls  Hey wait a minute the 5.0 uses symmetrical hulls with keels to provide the lateral resistance.
[Re: mangu]
#53477 07/31/05 09:03 AM 07/31/05 09:03 AM |
Posts: 364 | The traditional angle of attack for sailing all the traditional Nacras, but especially the boardless ones, is to keep the leeward bow depressed as far as possible. This stands the mast back close to vertical despite the rake in the rig, and more importantly allows the narrow hull section forward to function somewhat like a centerboard. By "as much as possible", I mean that there should only be a few inches of bow above the water - more in wind, less to practically none in lighter air. If the deck is just awash in the puffs, you're perfect. Sail fast.
Andrew Tatton
Nacra 20 "Wiggle Stick" #266
Nacra 18 Square #12
2,883
guests, and 311
