Barber haulers #56157
08/29/05 08:57 AM
08/29/05 08:57 AM
I want to add barber haulers to my p18. I was thinking about the Hobie Miracle 20 setup because it is so simple. It goes through the front crossbeam. Does anyone have any suggestions on a better barber hauler arrangement?
Who could help me make sure I order all the parts I need (I couldn’t figure out if I had all the right parts from the diagram)? Is the hobie helpful? Or do I have to order through a regional supplier?
Matt
Re: Barber haulers [Re: ] #56158
08/29/05 10:17 AM
08/29/05 10:17 AM
Panama City, Florida
Redtwin Offline
Redtwin  Offline
I'm not sure about the Hobie setup, but the Nacra setup is a bit of a P.I.T.A. I would say to just make sure you get good cleats. The jamb cleats on my boat just don't cut it.
-Rob V.
Panama City
Nacra 5.2
Rob V. Nacra 5.2 Panama City
Re: Barber haulers [Re: Redtwin] #56159
08/29/05 02:02 PM
08/29/05 02:02 PM
St. Louis, MO
hobienick Offline
hobienick  Offline
St. Louis, MO
If the set up you are talking about on the H20 is stock, then you can get a parts list on the website at
http://www.hobiecat.com/support/pdfs/PARTS_20.pdf
This is the illustrated parts guide for the stock boat. For my Hobie I usually use this to get eh proper sizes then buy the brand I like. It's a good starting point.
Nick
Current Boat
Looking for one
Previous Boats
'84 H16
'82 H18 Magnum
'74 Pearson 30
St. Louis, MO
Re: Barber haulers [Re: hobienick] #56160
08/29/05 02:22 PM
08/29/05 02:22 PM
Yeah on that picture it is hard to tell what I need.
I know I need the two rings (BARBER HAULER RING 61290011)
The cam cleats (PIVOT BLOCK HSB129)
But there are two pulleys and two plates to mount onto the front cross bar that I don’t see. That could be BARBER HAULER UPDATE KIT 41160010 or UPDATE PLATE
41162001?
It is hard to tell.
I just want to make sure there is not a better system out there.
Matt
Self Tacker [Re: ] #56161
08/29/05 05:00 PM
08/29/05 05:00 PM
cyberspeed Offline
cyberspeed  Offline
You ought to switch over to a self tacking system. It is the [censored]!!!
craig van eaton
Supercat 20
TEAM CYBERSPEED
www.TeamCyberspeed.com
Endurance Series
www.SailSeries.com
Re: Barber haulers [Re: ] #56162
08/29/05 07:15 PM
08/29/05 07:15 PM
South Florida & the Keys
arbo06 Offline
arbo06  Offline
The two blocks on the front beam are on page 70. Front beam assembly. It is truly simple and works very well. The only "special" parts are the mounting brackets for the pivot blocks.
Eric Arbogast
ARC 2101
Miami Yacht Club
0 registered members (), 418 guests, and 42 spiders.
