Carbon Sails Rule!!!!!!! #56424
08/31/05 03:35 PM
08/31/05 03:35 PM
jpayers Offline OP
jpayers  Offline OP
Last weekend at the Isotope Nationals I borrowed a pair of Carbon Sails. When I first picked them up I noticed they were about half the weight of the pentex/dacron sails. An extreme weight savings 20+ feet in the air turns into horizon job for the competition. They kept there shape well and I did very well concidering the light wind circumstances. There hasen't been any other mention of this incredible speed advantage. Has other fleets experienced this? [color:"red"] [/color]
J.P.Ayers
Isotope 186
Re: Carbon Sails Rule!!!!!!! [Re: jpayers] #56425
08/31/05 04:00 PM
08/31/05 04:00 PM
catman Offline
catman  Offline
A friend of mine recently purchased a set and your right they are very light, but the cost is heavy. I'm waiting to see how they hold up.
Re: Carbon Sails Rule!!!!!!! [Re: catman] #56426
08/31/05 07:37 PM
08/31/05 07:37 PM
They're not class legal in most catamaran classes.
Re: Carbon Sails Rule!!!!!!! [Re: Jake] #56427
09/01/05 02:42 AM
09/01/05 02:42 AM
Cape Town, South Africa
Steve_Kwiksilver Offline
"They're not class legal in most catamaran classes. "
You mean like, one-(manufacturer)design classes ??
We`ve seen this before, mylar sails are still outlawed in many class rules that were written in the `70`s, despite them having become cheaper and more durable, hold their shape longer etc. I guess the reason might be that if, in your particular boat`s class rules, it states that you have to buy your sails from one supplier, normally after being marked up by the "license holder" (ie manufacturer), it`s not in their best interest that the buying public have sails that last indefinitely and have a long racing life.
That`s the cost of "keeping the costs down"
Re: Carbon Sails Rule!!!!!!! [Re: jpayers] #56428
09/01/05 08:17 AM
09/01/05 08:17 AM
Crystal Beach/Dunedin CSWY Fl.
catsailorp19mx Offline
I am probably the person that catman speaks of.
Light?....yes, very. Costly?...like anything else in life, that is a personal matter. Class legal? I am sailing a P19 platform with Tornado spin/spin pole/snuffer. Nothing class legal about my boat. The sails were custom built to be as close to Tornado sails as possible; given our mast height differences. Heck, they used carbon sails to race around the world. That should say something about how they hold up.
Dave
Re: Carbon Sails Rule!!!!!!! [Re: Steve_Kwiksilver] #56429
09/01/05 08:18 AM
09/01/05 08:18 AM
I think most fiberglass factory production cats are about 100lbs. heavier than the could be if the industry would switch to carbon fiber hulls, masts, boards, rudders, beams and sails.
The argument against it is "Carbon is too expensive..." but if the entire industry were to swith and suppliers could make it in bulk, wouldn't the cost come down quite a bit?
The light aircraft industry is slowly changing over from aluminum to carbon and the prices are pretty much the same but the finished product is both lighter and stronger.
Re: Carbon Sails Rule!!!!!!! [Re: jpayers] #56430
09/01/05 08:20 AM
09/01/05 08:20 AM
Dave
Re: Carbon Sails Rule!!!!!!! [Re: Steve_Kwiksilver] #56431
09/01/05 08:21 AM
09/01/05 08:21 AM
Re: Carbon Sails Rule!!!!!!! [Re: Timbo] #56432
09/01/05 02:31 PM
09/01/05 02:31 PM
There is an echo in here....
Re: Carbon Sails Rule!!!!!!! [Re: scooby_simon] #56433
09/01/05 04:04 PM
09/01/05 04:04 PM
Central California
ejpoulsen Offline
ejpoulsen  Offline
Central California
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Re: Carbon Sails Rule!!!!!!! [Re: ejpoulsen] #56434
09/01/05 04:41 PM
09/01/05 04:41 PM
Galveston
jgrady Offline
jgrady  Offline
Galveston
I have had a set of cuben fiber sails on my P-19 since early last year. Huge difference in performance. Zero stretch, less weight and holding up well so far.
Salud
JGrady P-19 #1115 w/Hooter Galveston
Re: Carbon Sails Rule!!!!!!! [Re: ejpoulsen] #56435
09/01/05 06:29 PM
09/01/05 06:29 PM
South Florida & the Keys
arbo06 Offline
arbo06  Offline
What? Can you say that again?
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Carbon Sails Rule!!!!!!! [Re: ejpoulsen] #56436
09/01/05 06:30 PM
09/01/05 06:30 PM
arbo06 Offline
arbo06  Offline
What? Can you say that again?..
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Carbon Sails Rule!!!!!!! [Re: Timbo] #56437
09/01/05 07:10 PM
09/01/05 07:10 PM
Jimbo Offline
Jimbo  Offline
Fibergalss is basically mined from the ground as sand, then refined. That's why it's cheap. Carbon fiber OTOH,is a synthetic product with a complex and costly manufacturing process. Unless some new miracle process emerges, the cost will not go down anytime soon. The "synthesized mesophase pitch" method of production was supposed to be that miracle method, but the cost has not come down.
The economics and mechanics of boat vs light plane manufacturing are so completely different that such a simple comparison certainly becomes a bit simplistic, I'm sorry to say. The choice in light aircraft is between structural aluminum and carbon/epoxy, NOT glass and carbon. BIG difference. The savings in aircraft manufacturing comes not mainly from weight savings, but labor, because the parts count is so much lower for carbon/epoxy. Remember that metal aircraft are mostly riveted together, and that this is still done mostly by hand, one rivet at a time. Carbon/epoxy has allowed aircraft makers to build large structures in molds with significant automation and far fewer labor hours.
Structurally, riveted or bonded high-strength aluminum still competes well with carbon/epoxy, but I for one would never buy an aluminum boat built from one of those corrosion-prone high-strength alloys. Corrosion problems are bad enough with masts and beams even though they are generally made of lower alloys like 5052 or 5056.
It's like comparing apples to boiled eggs!
Jimbo
Re: Carbon Sails Rule!!!!!!! [Re: ejpoulsen] #56438
09/01/05 08:00 PM
09/01/05 08:00 PM
What?
Re: Carbon Sails Rule!!!!!!! [Re: Timbo] #56439
09/01/05 10:40 PM
09/01/05 10:40 PM
Jimbo Offline
Jimbo  Offline
What?
Boats are already made in molds in few pieces. No savings in labor can be expected by switching to carbon/epoxy like there is for airplanes. So the boat just costs WAY more to build in carbon/epoxy. No way around it.
Carbon won't be getting cheaper anytime soon. In fact, the price is expected to rise because the manufacturing process is energy intensive.
Fiberglass has never been competitive in airplne structure because it lacks stiffness. Riveted aluminum is better structurally than fiberglass, though laborious to assemble.
Airplanes are getting more and more carbon/epoxy structure mostly to save labor ($$$) not weight.
Get it?
Jimbo
Re: Carbon Sails Rule!!!!!!! [Re: Jimbo] #56440
09/02/05 12:32 AM
09/02/05 12:32 AM
Minnesota
Jeff Peterson Offline
Minnesota
There ARE cheap sources of carbon!
At any Wal-Mart you can get a 20 pound bag of Kingsford charcoal for $4.00.
Jeff Peterson
H-16 Sail #23721
Big Marine Lake, MN
Re: Carbon Sails Rule!!!!!!! [Re: Jimbo] #56441
09/03/05 07:17 AM
09/03/05 07:17 AM
Jimbo, I got it the first time, my "What" was in reference to the echo effect with all the double posts, the forum seems to be having problems.
Re: Carbon Sails Rule!!!!!!! [Re: Jimbo] #56442
09/04/05 09:08 PM
09/04/05 09:08 PM
Houston
carlbohannon Offline
Houston
The real reason you don't see carbon/epoxy or even glass/epoxy boats is most builders don't have the facilities. A competitive carbon/epoxy boat requires an autoclave (a computer controlled pressure chamber/oven) and metal molds. A polyester/glass boat is done in open molds that can be wood or better( And NO NACRA does not make the A2 in their facilities)
The extra cost of carbon and epoxy is minimal, less than $500 per boat. It's paying for the facility that costs so much. You have to use the facilities 24/7 to make them pay. That means your whole line has to use them or you have to take in outside work. That why there is not much overlap between the polyester/glass builders (F18) and the epoxy builders
However, from what I have seen, the increase in quality and durability is worth the extra money. For example, based on Tornado experience you could build an F18 with a 10-14 year competitive life for the hulls.
Re: Carbon Sails Rule!!!!!!! [Re: carlbohannon] #56443
09/05/05 02:04 AM
09/05/05 02:04 AM
From carbon sails to carbon hulls..
The T's hold up so well becouse they are overbuildt (minimum weight is to high for Marstrøms pre-preg-autoclave work). Now, the F-18's are even heavier, so if some builder started producing F-18's with the same methods it would probably be bulletproof as well as long lasting. But I dont think the F-18 sailors will be willing to pay Tornado prices for their boats.. About US$ 27.000,- last time I checked.
There also a shortage of carbon today. The plants was probably not ready for Boeing and Airbus's latest models. New plants are coming online, but this takes time.
0 registered members (), 6,180 guests, and 782 spiders.
Most Online7,274
1 hour ago
