Rudder problem #56680
09/07/05 01:50 PM
09/07/05 01:50 PM
Central Europe
ceitzi Offline OP
ceitzi  Offline OP
Central Europe
The paint/coating (or whatever it is) of my rudder blades is starting to fall off (see image). It goes of really easily. If you put a piece of tape on it, and tear it off the paint will stick to tape. Does anybody know what to do (other than buying a new set of blades). I have no idea how to restore the extremely smooth surface.
Thanks
Ceitzi
Re: Rudder problem [Re: ceitzi] #56681
09/07/05 02:24 PM
09/07/05 02:24 PM
Bob_Curry Offline
Bob_Curry  Offline
I suggest contacting Marstrom since that is one of his rudders.
Bob
Re: Rudder problem [Re: Bob_Curry] #56682
09/07/05 03:41 PM
09/07/05 03:41 PM
St. Louis, MO
hobienick Offline
hobienick  Offline
St. Louis, MO
Possibly you could strip off the coating, sand and apply a new coating. If you are nervous about that follow Bob's suggestion.
Nick
Current Boat
Looking for one
Previous Boats
'84 H16
'82 H18 Magnum
'74 Pearson 30
St. Louis, MO
Re: Rudder problem [Re: ceitzi] #56683
09/08/05 03:07 PM
09/08/05 03:07 PM
catman Offline
catman  Offline
It looks like the the rudder has a clear coat paint covering. This peeling is probably a result of a nick or scratch letting the elements (water) to work itself under the coating which causes the coating to release. The spot just gets bigger and bigger. Another way this starts is simply the coating was thin to start with or wet sanding and polishing thinned the coating. Paint needs to be a certian thickness to be durable.
At any rate you should contact Marstrom and find out what they painted it with (or if they did) then you could go to any body shop and have them refinish it. Just make sure the body shop doesn't use power sanders to sand. It should all be carefully block sanded by hand to keep the shape.
Re: Rudder problem [Re: catman] #56684
09/09/05 01:47 AM
09/09/05 01:47 AM
Central Europe
ceitzi Offline OP
ceitzi  Offline OP
Central Europe
Marstrom says its a UV problem. They proposed to use 2K acrylik paint or a 2K polyurethane. They offered to paint them for me for EUR 40 each. I think this is what I will do.
Ceitzi
Re: Rudder problem [Re: ceitzi] #56685
09/09/05 02:03 AM
09/09/05 02:03 AM
That's EUR40 well spent. Strange that the rudders get a UV problem tough, do you leave them on the boat after sailing?
They will probably come back something like this old sets of re-painted rudders.
http://www.tornado-norge.org/stockholm2005/_DSC2943.JPG
Re: Rudder problem [Re: Rolf_Nilsen] #56686
09/09/05 05:29 AM
09/09/05 05:29 AM
Central Europe
ceitzi Offline OP
ceitzi  Offline OP
Central Europe
No. They are usually covered (during shorter breaks) or dismounted (after sailing). I also cannot remember flying a hull for such a large amount of time that UV exposure of the rudders would be relevant :-)
>They will probably come back something like this old sets >of re-painted rudders.
That looks really cool.
Ceitzi
Re: Rudder problem [Re: ceitzi] #56687
09/09/05 07:13 AM
09/09/05 07:13 AM
that's DEFINITELY worth EUR40.
Re: Rudder problem [Re: Jake] #56688
09/09/05 07:26 AM
09/09/05 07:26 AM
Panama City, Florida
Redtwin Offline
Redtwin  Offline
That was a sweet paint job on those rudder!
Rob V. Nacra 5.2 Panama City
0 registered members (), 20,780 guests, and 1,475 spiders.
Most Online22,490
Yesterday at 08:14 AM
