it's possible ? #57514
09/18/05 11:28 AM
09/18/05 11:28 AM
max Offline OP
max  Offline OP
i want to do my rudder blade like this :
http://www.hobie-cat.net/img/produits/accessoires/lame_safran_fleur.jpg
it's possible to put a thin cotton\nylon tissue under the epoxy layer to show the pattern and protect?
it's like laminate the carbon or not?
after a good polish it should be shine and perfect.......
Re: it's possible ? [Re: max] #57515
09/18/05 09:46 PM
09/18/05 09:46 PM
Those blades are made with the colors in the mold. They first lay down a layer of clear gel coat, then the colored material (sometimes vinyl graphics when small, other times painted), and then the composite board is laid up. I'm not sure what the best method is to do something like this after the board has been made.
Re: it's possible ? [Re: Jake] #57516
09/19/05 07:39 AM
09/19/05 07:39 AM
catman Offline
catman  Offline
I've buried vinyl using clearcoat. I'm sure you could do the same with tissue or cloth. The trick may be how you glue the graphic down. Maybe spraying a little clear first then lay the graphic down. Then bury it with the clear. A craft store may have some tips on attaching the graphic.
Couple ideas anyway.
Re: it's possible ? [Re: catman] #57517
09/19/05 08:27 AM
09/19/05 08:27 AM
Dunedin Causeway, FL
David Parker Offline
Sufboard glassers have been doing this forever. Contact one of them. Say, didn't Hobie make surfboards...for like, 30 years? Ask their surfboard division, if it still exists.
Re: it's possible ? [Re: David Parker] #57518
09/19/05 10:33 AM
09/19/05 10:33 AM
California
mmiller Offline
mmiller  Offline
California
Internal graphics in a surfboard-like construction uses something called "rice paper" that the graphic is screen printed onto. A surfboard is constructed by core first, glass, rice paper and then the finish coats of resin I think. Rice paper becomes clear when wetted with resin.
Not sure of the process with the euro blades, but I assume it is similar.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: it's possible ? [Re: mmiller] #57519
09/19/05 11:07 AM
09/19/05 11:07 AM
Simi Valley, CA
jfint Offline
jfint  Offline
Simi Valley, CA
i had a freind who refinied his decks on an older(wooden decks) 505 like this, he used this god-aweful plad cloth. Musta thought the boat had more character after that. But it looked to me like it was just painted over with resin. He must have dones something creative to hold the cloth down tight though to get the nice finish he got.
Josh Fint Prindle 19 "Accident Prone" Moro Bay Sailing
Re: it's possible ? [Re: jfint] #57520
09/19/05 01:34 PM
09/19/05 01:34 PM
catman Offline
catman  Offline
There are the thick clear resins, like used on bars or tables. Experiment and let us know what happens. I wonder if the photo graphics would be the way to go. Put that on like vinyl then bury that in clear.
Re: it's possible ? [Re: catman] #57521
09/19/05 01:39 PM
09/19/05 01:39 PM
If I recall, that polyester is pretty heavy...
Re: it's possible ? [Re: catman] #57522
09/20/05 01:26 PM
09/20/05 01:26 PM
Gainesville, FL 32607 USA
dacarls Offline
dacarls  Offline
Those "decoupage" tabletop deals are epoxy. Polyester does not work well.
Dacarls:
Re: it's possible ? [Re: Jake] #57523
09/21/05 01:35 PM
09/21/05 01:35 PM
Michigan, USA
sparky Offline
sparky  Offline
Michigan, USA
I was at the Performance Catamaran factory last April and they were doing what you want just like Jake described. The material that went down right after the clear gelcoat was a printed fabric. I don't know the material but I thought it was a polyester. I think they had some problem with a nylon (I'm not sure of this) that looked like carbon fiber. They showed me some neat material that looked like woodgrain! I thought the teak would make a cool looking boat! They said they just sarted with clear gelcoat, decorative cloth and then the normal layup of glass-foam-glass. I saw some examples of daggerboards done this way.
Les Gallagher
Re: it's possible ? [Re: max] #57524
09/21/05 06:22 PM
09/21/05 06:22 PM
maui
jollyrodgers Offline
maui
if that rudder were a surfboard, i'd say that was a fabric inlay. the fabric is from the fabric store and is applied and trimmed prior to the glass job.
i don't know how log lasting fabric is if you don't burry it with glass. just a clear coat isn't enough on a surfboard, even if you use rice paper instead of fabric.
these days you can print your design on special paper like rice paper with an inkjet printer and fiberglass that in. the ink can fade tho.
for an existing rudder, sand off about as much material as you expect to add in the new process....good luck with that. your rudder is going to come out heavier and thicker if you add layers. plus the new layers could pop off if the rudder flexes much.
0 registered members (), 19,230 guests, and 494 spiders.
Yesterday at 04:54 AM
