| Re: Buying a second hand boats - checks
[Re: seajay]
#57646 09/20/05 08:14 AM 09/20/05 08:14 AM |
Joined: Mar 2005 Posts: 2,074 Northfield,NH USA bullswan
Posts: 2,074 Northfield,NH USA | I was searching for this a while back and when it finally came up in another thread I saved it. I think it is what you are looking for........ Sailing Shop Buyers Guide Greg
The nice part about being a pessimist is that you are constantly being either proven right or pleasantly surprised. - George Will "It's not that liberals aren't smart, it's just that so much of what they know isn't so" -Ronald Reagan | | | Re: Buying a second hand boats - checks
[Re: seajay]
#57647 09/20/05 09:06 AM 09/20/05 09:06 AM |
Posts: 12,310 South Carolina | The Nacra 20 is a pretty solid boat and I have not really seen any common flaws in the hulls are rigging. There have been some changes to the rigging as the boat matured.
there was an issue with the 'old-style' trampoline that slid into milled grooves in the side of the hull. In reality, the bolt ropes on replacement trampolines were too small which resulted in the trampoline pulling out from the hull. Old original trampolines rarely suffered from this problem. You can send an original trampoline back to be updated with a larger bolt rope and side lacing for about $150 US.
Other than that, look for corrosion on the beams (particularly around the mast post), closely inspect the mast for any cracking (I've never seen any but it is a carbon mast), and like any other catamaran check the stiffness of the decks.
Jake Kohl | | | Re: Buying a second hand boats - checks
[Re: pitchpoledave]
#57651 09/21/05 08:33 PM 09/21/05 08:33 PM |
Posts: 12,310 South Carolina | Last year I believe they stopped making the groove in the side of the hull. They're using the Nacra F18 (which was adopted from other designs) style tramp system that laces to large rounded bolts on the side deck. I like this system - gives me something to hang on to when it gets hairy.
#57652 09/22/05 07:52 AM 09/22/05 07:52 AM |
Posts: 5,590 Naples, FL | Last year I believe they stopped making the groove in the side of the hull. They're using the Nacra F18 (which was adopted from other designs) style tramp system that laces to large rounded bolts on the side deck. I like this system - gives me something to hang on to when it gets hairy. And it's more aerodynamic, right?
[Re: waterbug_wpb]
#57653 09/22/05 08:34 AM 09/22/05 08:34 AM |
Posts: 12,310 South Carolina | That was not yet prooven - on the same note did Befi ever install the "belly tale" to show the amount of lift generated by a beer belly?
#57654 09/22/05 10:50 AM 09/22/05 10:50 AM |
Posts: 5,590 Naples, FL | That was not yet prooven - on the same note did Befi ever install the "belly tale" to show the amount of lift generated by a beer belly? Yeah, but it sure is fun to stir the pot! As for BEFI, I'm sure there's a telltale they could pierce on somewhere....
452
guests, and 43
