Wavepiercing monohull with keel ?! #60229
11/03/05 05:27 AM
11/03/05 05:27 AM
Wouter Offline OP
Wouter  Offline OP
Take a look at this video clip.
It shows how the V70 boats are quickly discovering that you must have a wave-piercing bow at these speeds. If they push it any harder then they will almost pitchpole.
http://siteworks.volvooceanrace.uk.kpnis.nl/web/show/id=91479
Re: Wavepiercing monohull with keel ?! [Re: Wouter] #60230
11/03/05 07:33 AM
11/03/05 07:33 AM
brobru Offline
brobru  Offline
Wouter and all,
Nice video, thanks for the link.
Kinda makes you wonder how a multi hull of the same size would do right next to the mono (..well, not really :-)...)
The Aruba Regatta starts this week, I believe some 16' are on the list.
regards,
Bruce
St. Croix
USVI
Re: Wavepiercing monohull with keel ?! [Re: Wouter] #60231
11/03/05 07:37 AM
11/03/05 07:37 AM
That is going to be one wet ride around the marble.
Re: Wavepiercing monohull with keel ?! [Re: Jake] #60232
11/03/05 08:30 AM
11/03/05 08:30 AM
Dunedin Causeway, FL
David Parker Offline
Wavepiercing....like this?
Re: Wavepiercing monohull with keel ?! [Re: Jake] #60233
11/03/05 08:44 AM
11/03/05 08:44 AM
whodathunkit that you'd need a drysuit to run pit on a 70' ocean yacht?
Re: Wavepiercing monohull with keel ?! [Re: Wouter] #60234
11/03/05 09:03 AM
11/03/05 09:03 AM
Atlanta
bvining Offline
bvining  Offline
Atlanta
Two rudders, two boards....
Why not - 2 hulls?
Re: Wavepiercing monohull with keel ?! [Re: bvining] #60235
11/03/05 09:15 AM
11/03/05 09:15 AM
The lines are beginning to merge even more....
http://www.sailinganarchy.com/fringe/2005/images/LSS_7.jpg
Re: Wavepiercing monohull with keel ?! [Re: Jake] #60236
11/03/05 09:40 AM
11/03/05 09:40 AM
that is the ugliest lead-hauler I've ever seen.
Ecclesiastes 1:9-11 [Re: bvining] #60237
11/03/05 09:52 AM
11/03/05 09:52 AM
Panama City Beach, FL
steveh Offline
steveh  Offline
That which has been is that which shall be; and that which has been done is that which shall be done: and there is no new thing under the sun. Is there a thing of which it may be said, "Behold, this is new?" It has been long ago, in the ages which were before us. There is no memory of the former; neither shall there be any memory of the latter that are to come, among those that shall come after.
Praise be to Howard I. Chapelle for preserving the memory. Amen.
If that's a wave piercer, then so is the New Haven sharpie of the mid to late 1800's. When I first saw the hull shape, it struck me how similar the forward third is to a sharpie, particularly a vertical-sided Phil Bolger sharpie. Compare the attached ABN AMRO bow pic with these New Haven sharpie pics and lines. The sharpie shown is a working boat with a deeper hull for hauling oysters. The racing boats had flatter runs aft, less rocker and huge centerboards. Comparing the hulls, the "wave piercing," or what previous generations of designers called a "wet ride," looks more a matter of low freeboard and no flare coupled with the higher speeds associated with a high length to beam ratio, extreme shallow draft and a righting ballast gimmick. The 35-ft racing sharpies at the turn of the previous century were capable of an excess of 20 knots with an L/B of 5, a draft of about 10 inches and about 10 guys out on a plank. And now it looks like SA has replaced the plank with pods.
Perhaps in another 10 years or so, Phil Bolger will be vindicated when these V70 boats have vertical topsides and hard chines.
60793-abn amro bow.jpg (72 downloads)
Re: Wavepiercing monohull with keel ?! [Re: MauganN20] #60238
11/03/05 09:54 AM
11/03/05 09:54 AM
steveh Offline
steveh  Offline
Pshaw! Stretch those pods and reduce that center hull, perhaps even making it a square of fabric, and it has potential.
Re: Wavepiercing monohull with keel ?! [Re: steveh] #60239
11/03/05 11:09 AM
11/03/05 11:09 AM
I think the effort in that drawing is to build a maxi something that will be allowed in the Sydney - Hobart race. They don't currenly allow "multihulls"
Re: Wavepiercing monohull with keel ?! [Re: Jake] #60240
11/03/05 11:22 AM
11/03/05 11:22 AM
well they are going to come across some problems considering Jen has already publicly stated (On SA) that the design "Won't be getting anywhere near an IRC certificate".
Re: Wavepiercing monohull with keel ?! [Re: MauganN20] #60241
11/03/05 02:18 PM
11/03/05 02:18 PM
Rumour has it that the VOR70s where designed for wakeboarders...
http://team.abnamro.com/web/servlet/nl.gx.siteworks.client.http.GetFile/id=92794
Nosediving and resulting broaches are already a problem with the Open 60 monohulls, I guess the VOR70 are not much better (Or probably worse since they are required to sail upwind). Bruce Schwab added a finn to the bow of his Ocean-Planet to prevent nosediving. Also the canting keels will take a pounding and IMHO its only a matter of time before one of 'em falls of.
http://www.sailinganarchy.com/fringe/2004/op_bowlip.htm
Re: Wavepiercing monohull with keel ?! [Re: Tony_F18] #60242
11/03/05 03:43 PM
11/03/05 03:43 PM
steveh Offline
steveh  Offline
Do these hydrofoil things really work?
Re: Wavepiercing monohull with keel ?! [Re: Wouter] #60243
11/03/05 09:29 PM
11/03/05 09:29 PM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
The mono guys call it a plumb bow and just about every modern sport boat has one.
F18 USA 242
http://www.solarwind.solar
0 registered members (), 14,744 guests, and 723 spiders.
Most Online15,709
11 minutes ago
