| Hobie 16 Comptip length differences?? #62157 12/02/05 09:46 AM 12/02/05 09:46 AM |
Joined: Mar 2002 Posts: 284 Norfolk, VA Dan Berger OP
Posts: 284 Norfolk, VA | I have a new comptip section and a used one that I managed to get out of a bent mast. The new one is about 6-8 inches longer and has a longer section where it slides into the mast. Does anyone know why they are different--or when Hobie changed the design??
Dan Berger Norfolk, VA A Cat USA139 Supercat 15
| | | Re: Hobie 16 Comptip length differences??
[Re: _flatlander_]
#62159 12/02/05 12:49 PM 12/02/05 12:49 PM |
Posts: 393 Syracuse,N.Y | Dan: If I remember correctly, All of the early retrofits, Back when you took your solid mast to the dealer to be cut off and comptipped were the style that had the bolt hole. They seemed to come loose and rock back. You can look up the mast and see it tilt back at the comptip. At some point they lengthed the part that inserts into the aluminum and that seemed to solve the problem. I think I had my 84 boat done in about 88 and it had the new longer style. These are my recollections and could be wrong.
Pat Bisesi
Fleet 204
[Re: pbisesi]
#62161 12/02/05 12:54 PM 12/02/05 12:54 PM |
Posts: 284 Norfolk, VA | Thanks for the responses.
Matt Miller explained (on the Hobie Forum) that the new ones were longer. The used one I have does have the bolt through it--I'm glad someone said something about that or I would have bolted the new one!
The things you learn..
[Re: Dan Berger]
#62162 12/02/05 12:55 PM 12/02/05 12:55 PM |
Posts: 284 Norfolk, VA | Looks like we were all typing at the same time..
Matt, for future reference, is there a difference in the 14 comptip as well??
[Re: pbisesi]
#62163 12/02/05 02:00 PM 12/02/05 02:00 PM |
Posts: 99 Virginia Beach | Dan: If I remember correctly, All of the early retrofits, Back when you took your solid mast to the dealer to be cut off and comptipped were the style that had the bolt hole. They seemed to come loose and rock back. You can look up the mast and see it tilt back at the comptip. At some point they lengthed the part that inserts into the aluminum and that seemed to solve the problem. I think I had my 84 boat done in about 88 and it had the new longer style. These are my recollections and could be wrong. My '82 had a bolted tip and rocked back. It was a real pain as the sail would always get pinched at that point and it either hung up or came out of the track. | | | Re: Hobie 16 Comptip length differences??
[Re: mmiller]
#62164 12/02/05 04:53 PM 12/02/05 04:53 PM |
Posts: 1,252 California | The Hobie 16 retrofit is the only one that ever changed. The rest of the CompTips have not changed. | | |
441
guests, and 41
