Hobie 16 Comptip length differences?? #62157
12/02/05 09:46 AM
12/02/05 09:46 AM
Norfolk, VA
Dan Berger Offline OP
Norfolk, VA
I have a new comptip section and a used one that I managed to get out of a bent mast. The new one is about 6-8 inches longer and has a longer section where it slides into the mast. Does anyone know why they are different--or when Hobie changed the design??
Dan Berger
Norfolk, VA
A Cat USA139
Supercat 15
Re: Hobie 16 Comptip length differences?? [Re: Dan Berger] #62158
12/02/05 11:24 AM
12/02/05 11:24 AM
Dan, Matt Bounds explained on "the other forum" the factory comp tip is the shorter version and retro fit the longer. My factory one (H16) is 5 3/8" shorter than the retro, dont know if this difference is the same for the H14.
http://www.hobiecat.com/community/viewtopic.php?t=2737 [Linked Image]
Re: Hobie 16 Comptip length differences?? [Re: _flatlander_] #62159
12/02/05 12:49 PM
12/02/05 12:49 PM
Syracuse,N.Y
pbisesi Offline
pbisesi  Offline
Syracuse,N.Y
Dan: If I remember correctly, All of the early retrofits, Back when you took your solid mast to the dealer to be cut off and comptipped were the style that had the bolt hole. They seemed to come loose and rock back. You can look up the mast and see it tilt back at the comptip. At some point they lengthed the part that inserts into the aluminum and that seemed to solve the problem. I think I had my 84 boat done in about 88 and it had the new longer style. These are my recollections and could be wrong.
Pat Bisesi Fleet 204
Re: Hobie 16 Comptip length differences?? [Re: _flatlander_] #62160
12/02/05 12:52 PM
12/02/05 12:52 PM
California
mmiller Offline
mmiller  Offline
California
The Hobie 16 retrofit is the only one that ever changed. It was the first attempt and was changed to the current version very quickly.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: Hobie 16 Comptip length differences?? [Re: pbisesi] #62161
12/02/05 12:54 PM
12/02/05 12:54 PM
Norfolk, VA
Norfolk, VA
Thanks for the responses.
Matt Miller explained (on the Hobie Forum) that the new ones were longer. The used one I have does have the bolt through it--I'm glad someone said something about that or I would have bolted the new one!
The things you learn..
Dan Berger
Norfolk, VA
A Cat USA139
Supercat 15
Re: Hobie 16 Comptip length differences?? [Re: Dan Berger] #62162
12/02/05 12:55 PM
12/02/05 12:55 PM
Norfolk, VA
Norfolk, VA
Looks like we were all typing at the same time..
Matt, for future reference, is there a difference in the 14 comptip as well??
Dan Berger
Norfolk, VA
A Cat USA139
Supercat 15
Re: Hobie 16 Comptip length differences?? [Re: pbisesi] #62163
12/02/05 02:00 PM
12/02/05 02:00 PM
Virginia Beach
Sunvista Offline
Sunvista  Offline
Virginia Beach
My '82 had a bolted tip and rocked back. It was a real pain as the sail would always get pinched at that point and it either hung up or came out of the track.
Re: Hobie 16 Comptip length differences?? [Re: mmiller] #62164
12/02/05 04:53 PM
12/02/05 04:53 PM
California
mmiller Offline
mmiller  Offline
California
The rest of the CompTips have not changed.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
0 registered members (), 300 guests, and 56 spiders.
