| Re: F16 JIB system set ups
[Re: SkunkWORX]
#63839 01/03/06 05:33 AM 01/03/06 05:33 AM |
Posts: 465 Oxford, UK | Comments are welcome as we'd like to see the NEATEST system on the planet with the LEAST amount of fittings. So far so good. I'm used to the system on the Hobie Tiger, and it works pretty well. Basically, it's the same as the Agent Orange system, but without the first pair of pulleys that the jib sheet goes through (at the foot of the pole). It goes straight from the cleat to the floating block and back to the other cleat. It does mean that the sheet angles aren't perfect, but provided that you set it up well (such that the floating block is far enough down the pole) it works very well. You still get about 3:1 on the jib, which is plenty. Paul | | | Re: F16 JIB system set ups
[Re: pdwarren]
#63840 01/03/06 09:19 AM 01/03/06 09:19 AM |
Posts: 1,121 Eastern NC, USA | Agent Orange's system minimizes the amount of jib sheet needed (larger dia, less weight/spaghetti), so that is a plus. The VWM Blade has fixed blocks on the pole, so twisting would not be a problem (may not be a problem, but theoretically could be)..so that is a plus. The Pro Asia set up is the same as the VWM Blade, but with more floating blocks, maybe a very small minus.
I'd have to vote a tie with VWM and Agent Orange, with the Pro Sail in a close third. The winner would depend on the sheeting action of the two systems (which I cannot judge from here).
Where do the bitter ends of the jib sheets go? Tied off at the shroud, main beam, looped through the main beam? I'd like to see a continuous jib sheet system. I am sure if I get back to the other thread, it'll be in there somewhere.
My two cents.
Tom | | | Re: F16 JIB system set ups
[Re: tshan]
#63841 01/03/06 10:17 AM 01/03/06 10:17 AM |
Joined: Jul 2005 Posts: 28 Peninsular Malaysia SkunkWORX OP
Posts: 28 Peninsular Malaysia | well the bitter ends haved a sweet ending because they go through a sleeve that is the trampoline around the mainbeam and are attached to each other by a bungee cord! This has the added advantage that it really tidies up the trampoline and, for that, the Pro-Sail boats are a bit ahead i.e. no real strings across the deck.. If you want a better look, have a look at this, www.prosail-asia.com/Boats/F16%20page.htmlcheers | | | Re: F16 JIB system set ups
[Re: SkunkWORX]
#63844 01/04/06 03:47 AM 01/04/06 03:47 AM |
Posts: 13 Dubai, UAE | Hi everyone, new to forum, based in Dubai. Currently boatless & very keen to trial a blade. For jib setups, i would like to try a single swivel cleat very close to the centreline on the front crossbeam. Tailing the jib sheet to the main sheet/main traveller join. The theory being the skipper can easily assist crew getting sheet on/off for spin raise and drops. Plus less fittings and no sheet build up on one side. Not sure this would interfere with mast raising??
All the best David
Dave H
VWM Blade F16
UAE719
Dubai
[Re: SkunkWORX]
#63845 01/04/06 09:38 AM 01/04/06 09:38 AM |
Posts: 6,049 Sebring, Florida. | Those beams sound good, so why isn't everyone using them? Are they much more expesive than plain aluminium (assuming you don't have to import the alum.) and how much lighter are they?
Blade F16 #777
[Re: SkunkWORX]
#63847 01/05/06 12:03 PM 01/05/06 12:03 PM |
Rearbeam on my F16 (80 mm x 2 mm x 2500 mm) = 3.5 kg Mainbeam on my F16 (superwing mast section x 1.6 mm x 2500 mm) = 4.0 kg ex dolphinstriker setup ; 6.5-7.0 kg incl dolphinstriker setup
[Re: pdwarren]
#63848 01/06/06 12:06 AM 01/06/06 12:06 AM |
Joined: Jun 2001 Posts: 342 Lake Murray, SC,USA Cary Palmer
Posts: 342 Lake Murray, SC,USA | Comments are welcome as we'd like to see the NEATEST system on the planet with the LEAST amount of fittings. So far so good. I'm used to the system on the Hobie Tiger, and it works pretty well. Basically, it's the same as the Agent Orange system, but without the first pair of pulleys that the jib sheet goes through (at the foot of the pole). It goes straight from the cleat to the floating block and back to the other cleat. It does mean that the sheet angles aren't perfect, but provided that you set it up well (such that the floating block is far enough down the pole) it works very well. You still get about 3:1 on the jib, which is plenty. Paul On my Tiger, I rotated the cheek blocks that are mounted on the spin pole about 45 degrees when I mounted them, it clears up that sheeting angle thing. Gonna have to get a picture. Used a pair of Harken 416's. You have to play a lot to find the right angle before you drill & rivet. A lot of it has to do with your jibsheet length. Mine are actually a little too close, I did that rather than accommodate buying a new longer jibsheet. There is also no use for that Turning block that's mounted to the spinpole for the jibcar traveler adjustment. If you rotate that eyestrap 90 degrees you can lose the block completely and just use the eyestrap: West RF499 eyestrap has a stainless center ring that feeds the line without binding. Small & light and dirt simple. What is with the Flat plates you see holding up the ends of the jib traveler tracks on Orange and the Taipan? That blunt track end and the flat glass or aluminum supports looks like it would take a chunk out of me sooner or later. Ouch! Blade Track end support looks much kinder to our skin.
CARY ACAT XJ Special C&C 24
[Re: SkunkWORX]
#63850 01/06/06 07:48 AM 01/06/06 07:48 AM |
Personally I like the jib sheet cleats to be more outward so that the crew don't has to go in very far to get to them. I like them swiveling so the crew can sit far forward and on the leeward side and still work the jib cleat. And I do like the jibsheet to go back on the trampoline a bit. At least to the sidestays if not further so you can adjust the jib in a blow and not worry about putting the boat in a pitchpole by moving forward to grap the sheet.
I like a clean trampoline like any other crew but I like to stay upright in a blow even more.
For recreational sailing tidying things up to a very high level is not a problem, when racing then a boat can be too tidy. Must take care not to compromise on accessibility or to compromise the ability to switch roles (skipper working the jib etc). Both of these are very important (= fast) during racing and mostly so during racing in the rough stuff.
11,441
guests, and 344
