I broke my mast on the weekend and was wondering what went wrong.
No stays or diamonds broke, I believed the mast was in good order but old, it was painted (which I believe is very bad for old aluminium masts that aren't necessarily marine grade material) and the mast broke almost exactly in half way.
I'll describe the situation:
It was a little gusty and breezy but probably wasn't above 20 knots. My crew and I (70kg and 65kg) were both on trapeze and we were travelling along well on a tight, two-sail reach, one hull just clear of the waves most of the time. We hadn't sorted out mast rotation or downhaul (only just left shore about 500m behind) but had moved the traveller about half-way down track. The main was slightly luffing, jib was powered up nicely. The main has a square head on it that adds at most 1sqm of sail area. About 30 seconds before it went I noticed that it was certainly flexing more than I'd seen before. When it broke, it bent away from the wind (leeward side of mast) at the centre (reverse of what I would've expected).
I've had the boat pressed much more than this previously without any sign of trouble. My current thinking is that there were a few contributing factors:
1. Mast was old and its time had come. 2. Mast rotation was wrong. (Don't recall what position it was actually in.) 3. Mainsheet tension was pulling on leech and pulling top of mast aft 4. Crew is too heavy...need to ditch the heavy-butt crew and get a light weight girlfriend 5. Diamond tension was all wrong.
Any hints or past experiences would be greatly appreciated before I build a new mast.
I understand the association sells sections, does anyone have a price for these?
I'll purchase a tuning guide from the association soon and maybe that will help.
Does your sail have a lot of luff round? I mean when the sail is flattened, does the mast bend look radical? There were some Cobras in Tassie who experimented with huge luff round on a similar mast a few years ago and they broke several masts. I think the mast bends so far forward the diamonds can't stop it squirting out to the side.
Or like you said, the mast may have just been very old.
Putting an extra square metre of sail up the top is not insignificant. You may find it a challenge to get enough leech tension without a stiffer mast up top.
Bob Wilson had to run a diamond up the front of his mast, but that is a bit different as he added a metre on to the length.
Come to think of it, the luff round does seem a little large. What would be a typical luff round measurement? (Measured as an offset from a straight line between head and tack?)
It is very easy to oversheet a squaretop mainsail, you want to sail a squaretop with noticeable twist in the leech. You'll go faster that way. However, if you still feel that the top of the mast is still to soft (not stiff enough) than the best and easiest solution is to move the hound fitting higher up the mast. The is a 3rd order dependency so only slight movements may produce large effects. The longer section between the hound fitting and mast base can then be stabilized again by the spreaders. And if you feel this is insufficient then longer spreaders arms will correct this. In principle and within reason you can fune-tune the mast to the new mainsail design. It is not a unchangable given, unless the class rules limit were everything may go.
Example : stiffening up the top of the mast. Say a mast is 8 mtr. long and the hound fitting is at 5.75 mtr. The top length is then 8-5.75 = 2.25 mtr. and assume it is too soft in the top in this setup. You want the top to be 20 % stiffer then before. 3rd order dependency => 120 % = 1.2 = (2.25)^3/(new top)^3 therefor (new top) = (old top)/(3rd order root (1.2)) and new hound height = 8 mtr - (new top)
(new top) = (old top)/(3rd order root (1.2)) (new top) = 2.25 mtr/1.0627 = 2.1173 mtr. = say 2.12 mtr. or 130 mm shorter
And new hound height = 8 mtr - (new top) = 8 - 2.12 = 5.88 mtr.
20 % extra stiffness then before is quite alot.
So you can see; 130 mm movement of the hound fitting can be quite alot.
Hope this helps
Nick is out on a limb with his square top sail anyway so the class rules are not that important in this case.
What you said about it being easy to oversheet a square top sail seems to contradict Gary's experience with his Ashby main (square compared to his previous Irwin sail). He thought he was using an enormous amount of mainsheet tension, but Glenn told him he wasn't using enough. He had to find new ways to get more tension on his mainsheet - he may have even added some purchase (Gary?).
It sounds to me like it's very hard to oversheet a square top main (or even sheet it enough sometimes!).
Hi Guys [/quote] What you said about it being easy to oversheet a square top sail seems to contradict Gary's experience with his Ashby main (square compared to his previous Irwin sail). [/quote]
I'd have to agree here. I've been sailing Dolphins for 30 years, and the last 15 has been with a square topped main, teamed with a wing mast.
I use enormous mainsheet tension to keep the top from laying off. I'd have thought that the mozzie mast would be too soft for a square top, in that it would keep bending whilst more mainsheet is applied. This is where the reverse diamonds up the top would be needed.
yes my experience is that the tension I pull on the mainsheet is greater the bigger the head on the sail. However like everything to do with sails, it is not that simple, on my Irwin main my attempts to achieve the leech tension I was looking for where hampered by running out of luff round. Mainsheet tension was bending the mast to the point I was flattening sail before I could get the leech in the head to stand up.
Ashby main has more depth, so I am able to pull on more mainsheet tension before the main flattens to much, keeping the leech standing up longer. However as I have found it over powers earlier, because of greater luff round and bigger head. It is difficult to have everything working the way you want all at once, but the sail is awesomely fast in 5-8 kts. as Tim on Mossie with spin and Chris on the F18 Capricorn saw last weekend.
I am still tinkering with settings and since breaking top batten in capsize last weekend, I am going to try stiffer head batten to see if this keeps head flatter and helps depowering. I haven't added more mainsheet purchases yet,just keep grunting, I hate having to use more mainsheet length than neccesary.
Regards Gary.
Re: Breaking Masts
[Re: Steve_T]
#65890 02/03/0605:29 AM02/03/0605:29 AM
I re-read Bethwaites "High performance Sailing" for the umptent time last week, and he said that mast breakages was common if the mast was 15xdiameter out of column. I am sure there are more to it, e.g. compression and dynamic loads, but he has a point.
As for twist and sheeting loads. On sloop rigs we want twist in the top of the main to offset the jibs effect on the wind. Also, at certain windspeeds, we need to trim the top of the main to the different angles of wind at the surface and the mast-top. If owerpowered, we let the top of the main fall off to depower. As long as you are trimming to your telltales, you should be in the ballpark.
I find it hard to determine what twist I sail with unless I go to lie down aft and under the boom to sight up along the leech. I really prefer to follow after the boat or have pictures taken to determine mainsail twist. What I am wondering about, is what Wouter think is twisted vs. what Gary think is straight? Do you guys have any numbers for what kind of twist you think is too much or too straight? It depends on conditions of course, so some pictures taken from aft of your boat would be preferable.
Gary: Sounds to me like the luff curve of your mainsail doesn't quite fit the mast? No wonder, if Ashby cut it for the A-class mast you have, and you beefed it up to handle the spi (just guessing here really). Next iteration probably will be better, if you have Ashby use what you have learnt
At the weekend I pulled the battens out a foot or so from my Irwin main, stretched the luff out and ran a straight line from the corners. I measured 165 mm at the furthest point from the back of the bolt rope. This wasn't measured under laboratory conditions so allow plus or minus 10-15mm for a sailmaker-quality measurement.
I believe the luff round on this sail is typical of most of the Mosquito sails in use in Aus.
Here's luff round in action on a Goodall radial ----
I should say that my leech is hopefully always twisted. When I am talking about trying to stop leech twisting, I mean excessive twist, like when you are trying to get on trap looking for maximum power.
I am basing my mainsheet tension on Glenn's advice when he was sailing behind me in 15 kts. telling me to pull on more downhaul to incease twist, but also more mainsheet tension at the same time, idea seems to be to depower sail to the point where you can keep mainsheet in tight. It is improving my upwind speed with this main. By the way Glenn cut this main after sailing Altered and having good look at mast, I think he has it right, it is just different to what I have used before. Irwin main was made without the boat rigged or in the water and was a good result considering.
I haven't really had a chance to investigate the destruction of my mast, but after looking at those photos some more it appears to me that the spreaders may be too low. Raising them up closer to the break should reduce the bending moment around that area.
Does anyone have any measurements for the location of the spreaders above the top of the forward beam?
mast break looks like most I have seen, in that it looks like compression failure. The damage to what I would call the back of the sail track does seem a little unusual though, usualy most of the compression failure seems to be on the side of the mast. Although only looking at pictures makes it difficult, the angle the back of the track is at could be from tearing after initial side wall failure.
When building Altered, I was asking about failures in carbon wing masts, I was advised compression of the side of mast was usual failure point, so I put timber web crossways inside, to stop it caving in. Seems to have made it bullet proof so far.
Spreader positions I have used is usualy halfway between diamond attachment points. Don't remember anything more technical than that. Top of diamonds is usualy determined by how close you can get to your hounds without fowling stays when rotating mast. Hound point is governed by class rules.
