| racing with both monohulls and multihulls #66456 02/11/06 10:40 PM 02/11/06 10:40 PM | Anonymous
| Anonymous
Unregistered | We are trying to work with the monohullers (24-35’) to share a race committee. They are afraid that with our tacking angles and different speeds it will create problems for them. We were planning on doing separate starts.
Does anyone have any experience racing with both monohulls and multihulls?
Any thoughts on how we could stagger the starts to stay out of their way?
Thanks,
Matt | | | Re: racing with both monohulls and multihulls
[Re: ]
#66457 02/12/06 06:50 AM 02/12/06 06:50 AM |
Posts: 3,348 | I think the monohull group has to feel the need. Cats weren't really welcome in my group for many years. Then membership started to drop, so they became more accepting to make up lost revenue.
If they want it to happen, it isn't a problem. Until then you're wasting your time.
My advice is to smoke out the real objection, the angle thing sounds bogus to me.
Specifically, they probably haven't considered two "A" marks. That, along with separate starts should cure any problems.
[Re: ]
#66458 02/12/06 07:09 AM 02/12/06 07:09 AM |
Posts: 9,582 North-West Europe | They are afraid that with our tacking angles and different speeds it will create problems for them.
In my experience it is rather the cats that will have problems with the tacking angles of the mono's. Typically they outpoint you on the start line and they can luff you up beyond comparison there. Also at the bottom mark the mono's sail very deep and nearly always achieve a inside overlap at the bottom mark. Most often because a catmaran is coming from behind and hardly has any rights that way. In addition the two groups seperate from each other pretty quickly with the cats going wide and the mono's going high and deep. The only issue I ever saw arise was at the top mark were typcially the monos try a port approach to the A-mark alot more often. In cat sailing this is a big no-no because you hardly ever can stay clear and get in. The mono's feel, for some reason, that they can and always misjudge the speed of a catamaran. Combined fleets (the few times I did them) were actually alot of fun. It is amazing to see some mono's getting really good vmg and from the other perspective (the mono one) it is unbelievable how the cats pass the other boats. Best advice for a cat in a mixed fleet is to just sail around a mono is any way you can (windward or leeward, doesn't matter) and get as quickly as possible to the clear air on the other side. If you have to bear down and arc around a mono, then just do it. You loose less time then when trying to maintain your optimal course and speed. Wouter
[Re: ]
#66459 02/12/06 08:39 AM 02/12/06 08:39 AM |
Posts: 12,310 South Carolina | We race on mono-hull courses from time to time. Historically, we've had little respect on the course because, as a group, we are believed to be only interested in going fast and know very little about the racing rules of sailing. We've changed a good bit of that belief and having larger fleets intertwined in the local sailing clubs (F18HT, F18, A cats, etc.) and having very refined boats on the line has helped overcome this image.
It's painful but the cat's should probably start first. This way you don't have to go blazing through the monohull fleet before they get to A and the monohulls can go around the course at least once before having to deal with the multis. A second, further away A pin for the cats is also a good idea. If the race committee is committed to supporting the multihull fleet, a split start and finish line would be a great advantage because it would allow them to start you guys in another race before everyone has finished. Otherwise you end up waiting around a LONG time.
Most of any mono vs. multi issues I've had have been at C mark and I think the problems I've experienced (monohulls not willing to give me the room I'm entitled to at a mark) I attribute to their feeling like they shouldn't have to yield to such a low life, speed freak, rule-not-knowing race boat (mine). Lately, they watch us have some very tight F18 racing and I think they've begun to understand how competitive and technical we are. It just takes some time to get past any stigmas.
Jake Kohl | | | Re: racing with both monohulls and multihulls
#66460 02/12/06 09:37 AM 02/12/06 09:37 AM |
Posts: 4,451 West coast of Norway | We have shared most of our race-training with monos. When we started sailing (cats) the club was dying, so another boat in the wednesday night races was welcome even if it was a raft made up of two pontoons.
Having a separate start is a good way to avoid the worst problems. Monos approach the line from further away than cats do and will luff you into irons the last few meters unless you have made a hole to dive into. On the course, the ugly situations come while going downwind. Monos generally go a lot deeper, and are poor at keeping watch to their leeward. This is generally where a cat under spi or going wild downwind will come zipping in. You can never assume they have seen you, and even if you shout at them they need some time to jibe or slow down. Going up is not an option for them (they can, but are bloody stiff necked about it, and they need time to avoid breaking stuff if you take them too high). I dont agree with Wouter that they often have rights over you. With the different angles cats and monos sails downwind, it's my experience that the cat most often will have established an overlap a long way out and will have luffing rights when the boats get close (assuming the cats are overtaking the monos of course. Please correct me if my interpretation of the rules are wrong). The funniest part is when some old-timer go hailing "mast abeam". Then we know it's time to jibe away..
Upwind there are seldom conflicts, just take care to not get in a position where you are a good luffing target (the stupid ones sometimes try to luff you, and loose time that way). You will not be around long enough to use tactical measures like backwinding on them. Just get by them no matter how, and if you go close to leeward, ride the lift in front of their bow if you dare to.
Keeping away from them during rundings is a good idea. Those boats are not very manouverable, and sometimes the crew loose control on them. "It doesn't matter where you go, as long as you go there fast" is a good rule, if it's crowded in the roundings (or look for the pinwheel effect and "slow down to win" as Rick likes to say). Remember that they will go high just after rounding the leeward mark, so be fast if they are to leeward of you.
When sharing the course with monohulls, we never assume they have seen us and never assume they will respect our right of way. This has proven to be wise time over time. I dont think they ever will learn how fast cats move in a decent wind.
Having a W/L course for the monos, and a triangle course with W/L for the cats is my preferred layout when sharing the course. Eventually, put the windward mark longer up.
I think Pete has it right. Find the real reason why they dont want to run races for you, and work on that. There is a lot of prejudices about multihulls, not to speak about beachcats among some monohullers. We are accepted in our small club now, after 6 years of attending all social, sailing events, volunteer work on the club house/area and holding office for the club. But they still dont understand why we prefer to zip around on a "childrens boat" like a Tornado instead of getting a proper boat. We just laugh at them and let them know that they dont understand what they are missing out on. | | | Re: racing with both monohulls and multihulls
[Re: ]
#66461 02/12/06 10:26 AM 02/12/06 10:26 AM |
Joined: Jan 2006 Posts: 195 Straight Outta Hell Boudicca
Posts: 195 Straight Outta Hell | Clear Lake Racing, Houston/Clear Lake, TX does this: they start at same place and are sent on different course.
This sig would be something witty, but the censors are against that.
[Re: ]
#66462 02/12/06 10:35 AM 02/12/06 10:35 AM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | While I was heavily critized for the courses at the Tradewinds, they certainly worked. Two weather marks, two reaching marks and two leeward marks. Multis on the outside course, monos on the inside course. That way they also finish near the same time to get in more races.
When I first started racing there was ONLY mixed fleets. And they always started the cats last. That meant we had to sail through the fleet. One of our Shark Cat guys was reaching over a Highlander and the guy started to luff him. Our cat guy shouted at him, "If you don't struggle, I will do it fast!" <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
At Sandusky Sailing Club the Thistle Fleet was huge. We only had 12 Sharks there at the time. The head Thistle guy was extremely biased and told me we could never out point a Thistle. In reply I simply said that I didn't want to go that slow. But, a week or so later at a fun race, they started us all together. This Thistle guy started a boat length ahead of me and right at the RC boat. I was able to outpoint him and drove over him on the way to the A Mark. I was grinning.., he was frowning.
Mixed company can be fun.., try it. Rick | | | Re: racing with both monohulls and multihulls
[Re: RickWhite]
#66463 02/12/06 11:29 AM 02/12/06 11:29 AM | Anonymous
| Anonymous
Unregistered | Contact Buddy Brown. He has been doing it for over 20 years with the Wed nights. Doug http://www.clearlakeracing.com/ | | | Re: racing with both monohulls and multihulls
[Re: ]
#66464 02/12/06 03:10 PM 02/12/06 03:10 PM | Anonymous
| Anonymous
Unregistered | All good thoughts, thanks
The problem with our situation is that we have permanently set racing marks out a couple of miles and just set the start to the wind. This means that making a separate course would not be that easy.
The other thing is that we (the catamarans) are not racing with spinnakers, so that will make a difference downwind.
It seems like if we started 10 min early it should not be a problem.
[Re: ]
#66466 02/12/06 03:34 PM 02/12/06 03:34 PM |
Posts: 3,116 Annapolis, MD | On the Chesapeake Bay, We race with CBYRA and handle starts both ways.
The races are usually 3 miles or longer around fixed govt marks. The course is the same for all boats.
For the PSA overnight Race of 40 miles, Beach Cats start last and finish well ahead of the mono's.
For the West River Twilight Race, We are the first start (assuming we get the fleet out to the start line in time)
For the 165 boat NASS 35 mile Race to Oxford, we are the fastest boats on the course and start last behind the PHRF A0 and Crusing Multihulls.
For the Race Back, We start in the middle of the fleet off of Tred Avon Yacht club for a 20 mile back in forth in the Choptank river and out o the Bay to Poplar Island.
In light air... you just need to clear your air... Not easy with lots of boats out there. Stay on the weather hip of the fleet. In breeze... you pass the mono's so quickly that it's not that much of an issue upwind. If you are double trapped.. you can play the puff's to climb above any monohull out there (Nevertheless, they stil believe that cat's don't go to weather)
Downwind... you will have to zig and zag through the parade of mono's running dead down wind. You are windward and overtaking so you have to thread the needle through several boats knowing that you don't have a lot of options for bearing off and the mono chutes throw up a big wind shadow. This is much easier to do without a chute up. Usually you just have to cross the fleet once... because for the next cross you will be far ahead.
By all means, make an effort to make sure your guys know the CURRENT rules, discuss the likely crossing situations a head of time, AND exercise some common sense and graciousness.
It goes along way, when you try to do the race the next year. Mark
crac.sailregattas.com
[Re: Mark Schneider]
#66467 02/12/06 03:44 PM 02/12/06 03:44 PM |
Posts: 3,116 Annapolis, MD | One final point.
Racing the monohulls will never work out. A single number rating system such as PHRF cannot handle the dramatic performance changes of a Cat fairly.
The PHRF boats complain about the Melges amd Henderson 30 ratings for similar reasons... They are able to race the rest of the mono's but the old adage of horses for courses still holds. All handicap ratings work well when you are racing similar boats together and simply need to tip the balance a little to favor the slightly slower boats.
I don't think ANYONE wants to start the mono's and beachcats together.. boat mass and mast height are working against any cat on that starting line. If they insist... Please demand a LONG line so you can minimize the mismatch on the start line.
Mark
#66470 02/12/06 08:02 PM 02/12/06 08:02 PM |
Posts: 1,121 Eastern NC, USA | Has anyone done a Bermuda start system? They tack on the handicap at the front (or best they can). I once waited 1 hour and 45 minutes for a three hour race (counting my starting time). I was quite toasted before we left the dock. Needless to say, I crossed the first leaner about a half mile to finish.  t
Tom | | | Re: racing with both monohulls and multihulls
[Re: tshan]
#66471 02/12/06 10:58 PM 02/12/06 10:58 PM |
Joined: Jan 2004 Posts: 196 Arkansas, USA CaptainKirt
Posts: 196 Arkansas, USA | Tom- They used to have a distance race in North Carolina where they did this- Started all the cats after all the monos had left. The first time I did the race on my 18 square meter I beat the Committee boat (a huge Hatteras motoryacht) to the finish marker and just sort of sat there waiting for them. They didn't believe that I was actually in the race at first, but since I had passed every other boat in the race I had plenty of witnesses!  Having sailed in many "mixed" fleets I agree with almost everything said here- I always try to be gracious and stay out of their way- it helps to have sailed/skippered/crewed on some monos so you can relate to what they are going through and they're thinking. To me the biggest issue is the huge speed difference, especially in a puff- most mono guys are used to scanning slowly for approaching boats and they judge passing/crossing encounters based on their experience (which is usually other monos) and so can be extremely surprised when you just suddenly "show up" on their hip/quarter/whatever. I definitely "drive defensively" when sailing with monos- Never plan to get too close to them as they may suddenly tack just as you are about to pass to windward or gybe just are you are planning to go by. I personally enjoy starting dead last, sailing through the entire fleet of monos (to weather upwind!) and finishing before any of them. The only downside is then waiting to start again.  Agree with Mark about "horses for courses"- there is a "come all" race in Shreveport I have attended a number of times- in the typically light air the Thistles and MC scows have a clear advantage but one year the wind blew well and the top 5 boats were all cats - even on handicap!! Kirt
Kirt Simmons Taipan, Flyer
[Re: CaptainKirt]
#66472 02/12/06 11:13 PM 02/12/06 11:13 PM |
Posts: 917 Issaquah, WA, USA | Our Friday night series on Lake Washington in Seattle has both. We have five starts, with the multihulls starting last. It is a six mile triangle, usually run in light 5 to 10 mph winds. But, when it gets to 15 and over, it is fun to fly by the leaders, even after a giving a 20 minutes head start. They do have PHRF ratings for all, including the multihulls, but do not score us in the overall. The fleet includes a wide range from Cal 21's to 50ft and over Maxis.
Lots of fun for all. Including the video of the event at the bar in Anthony's, the sponsor, after the race.
Caleb Tarleton | | | Re: racing with both monohulls and multihulls
[Re: CaptainKirt]
#66473 02/12/06 11:59 PM 02/12/06 11:59 PM |
Posts: 5,582 “an island in the Pacifi... | All of the posts on this thread have great info. I've convinenced the two YCs on Maui to have multihull starts. I won't find out until the first race on where we'll start. They're lucky if the get four leaners. I'm expecting at least two F-27s plus my H 20. US Sail Level 2 Instructor US Sail Level 3 Coach | | |
2,472
guests, and 347
