| Re: A cat vs F-16
[Re: bvining]
#67313 02/22/06 11:28 AM 02/22/06 11:28 AM |
Posts: 9,582 North-West Europe | I all dependents on the specific makes of the catamaran. I know of an 18 sq. (also an 18 foot boat) that had trouble sheeting in the spi and I know the I-17 guys overhere changed back to a single forestay. My bridle wires are much further back then those on a FX-one, so I could be fine while the FX-one won't be. There is no general rule that predicts who will have trouble and who won't, dependents on specific implementation.
Also getting a longer pole is not always a solution especially not on an A-cat whose daggerboards were never positioned with a spinnaker in mind. You can upset the balance of the boat.
I'm sure some designs could be in the clear. Nevertheless this problem can arise and has arisen on several boats.
It is definately a thing to keep in mind.
| | | Re: A cat vs F-16
[Re: fin.]
#67314 02/22/06 11:38 AM 02/22/06 11:38 AM |
That darn F16 will !
Got more then enough hours clocked in the open water by now. Actually only 3 times a year I sail on a lake. All other times (20 to 30 per year) I sail on the north sea and have to go out through the surf. And I do really mean ; A surf.
The jib does help sailing through the surf as you can steer with your sail better. (sheet in with the jib and sheet out with the main to bear away, the opposite to luff up. With a selftacker you just set the jib relatively tight and just sheet the mainsail in and out to head up and down.
I'm riding my hulls onto the beach when the surf is up. I get off as soon as I can after the hulls touch bottom, but I'm not especially careful. By then again, I have timber-epoxy hulls; no worries about making dents.
| | | Re: A cat vs F-16
[Re: fin.]
#67315 02/22/06 12:18 PM 02/22/06 12:18 PM |
Joined: Dec 2005 Posts: 443 Edmonton, Alberta, Canada bobcat
Posts: 443 Edmonton, Alberta, Canada | Tom:
Anyone know how long it takes to get delivery? I'm another F16 wannabe that placed his order right after Tradewinds in January. The European Blades are being finalized and I've been told that my boat should be built by the end of March. | | | Re: A cat vs F-16
[Re: fin.]
#67316 02/22/06 12:19 PM 02/22/06 12:19 PM |
Posts: 1,121 Eastern NC, USA | I've decided on the Blade, just waiting to hear back from Vectorworks......Anyone know how long it takes to get delivery?
I like that decision. I am going to have to move to FL. Matt is going to be very busy this year between Blade and XJ production. Seems like when I first talked to him last Nov, he was working on a 4 to 6 week delivery - that may have changed, though. I don't want to speak for him.
Tom | | | Re: A cat vs F-16
[Re: PTP]
#67318 02/22/06 12:38 PM 02/22/06 12:38 PM | Anonymous
| Anonymous
Unregistered | Pete: Just got some info from Matt I will email it to you. I may just get the A2 AND a Blade if the money come in OK. They have made some nice changes to the A2 from what I hear. You can now raise the daggerboards with a line. Send me the video in email attachment. You have my email. Are you getting the Kevlar hulls and carbon beams and rudders? Guys are the Pentex sails class legal? I have them on my Hobie 17 (squaretop and reacher) and love them. Doug Snell Hobie 17 Soon to be Nacra A2 and maybe Blade too. www.tcdyc.com | | | Re: A cat vs F-16
[Re: ]
#67319 02/22/06 01:28 PM 02/22/06 01:28 PM |
Posts: 12,310 South Carolina | I think the a guys are using carbon sails aren't they? I don't think there are any real limitations on sail cloth in A cats.
Jake Kohl | | | Re: A cat vs F-16
#67320 02/22/06 02:21 PM 02/22/06 02:21 PM | Anonymous
| Anonymous
Unregistered | I was talking about the Blade. It has an option for Kevlar hulls and carbon beams and rudders. Also a option for Pentex sails.
Doug | | | Re: A cat vs F-16
[Re: ]
#67321 02/22/06 02:26 PM 02/22/06 02:26 PM |
Posts: 1,121 Eastern NC, USA | Pete: ....get the A2 AND a Blade if the money come in OK.
Are you the Powerball winner that has yet to come forward? F16 sail cloth is not restricted. My understanding is that the VM Blade carbon upgrade refers to the foils (daggers/rudders) and tiller assembly/crossbar, not the beams. The boat weighs in a few kgs (2 or 3) above minimum, so the buyer can adjust what he/she sees fit to change. I guess carbon beams could be an aftermarket option. An un-advertised option for the Blade are the turrets for a 50 caliber found on this VM model: http://www.vectorworksmarine.com/military-article.asp
[Re: tshan]
#67322 02/22/06 03:18 PM 02/22/06 03:18 PM | Anonymous
| Anonymous
Unregistered | No Powerball, just some big money coming from other things.
Here is what I got from Matt. It says carbon beams and there is a Pentax sail option. What are stocks? Does that mean carbon mast?
Doug
Vectorworks Marine Inc.
Blade F16 price list Model Year 2006
BLADE F16
Complete Blade F16 Includes, full F16 compliant ready to race boat with: White NPG Iso gel coat exterior finish, Light weight stiff foam core sandwich construction with fiberglass reinforced vinyl ester laminate, Large diameter aluminum beams, Fiberglass foils, Composite and alloy stocks Wing section mast, Colored radial cut main and jib in Race Dacron, Single color spinnaker, Mid- pole snuffer system with single line control. Full battened jib, Self tacking jib system Top of the line bearing blocks on all control lines and Premium cordage.
USD $12,900.00
Available Options
Kevlar hulls $700.00 Carbon upgrade (Rudders, boards, stocks and cross bar) $390.00 (When available) Pentax sail material (Main and Jib) $325.00 Colored Hulls $300 In Stock
Contact factory. Some colors in stock, special order would be $500 Optional 12:1 internal downhaul system $100 Sta-Master shroud adjustment system $35 Trailer (Galvanized steel w/ 12" tires, forward cradles and rear double rollers ) $1,075.00 Composite cradles with IO carpet surface molded for Blade hulls $200.00 Set of 4
$110.00 Pair (Fore or aft)
New for 2006 we have redesigned our lamination system to provide a proprietary contour molded core system for the b providing core around virtually the entire hull surface. We have fabricated fixturing that creates, in the molding process hull halves that is more robust and lighter in weight than the traditional taped hull halves. This weight savings has then been used to drastically increase the density of the core being used to manufacture the boats, significantly improve resistance to denting. The end result of this development is that we have created a hull that weighs the same as before stiff, and damage tolerant. | | | Re: A cat vs F-16
[Re: ]
#67323 02/22/06 03:58 PM 02/22/06 03:58 PM |
Joined: May 2002 Posts: 1,037 Central California ejpoulsen
Posts: 1,037 Central California | Blade F16 price list Model Year 2006
BLADE F16
USD $12,900.00 I think any of you who have looked at new cats realize what an incredible performance VALUE that is.
| | | Re: A cat vs F-16
[Re: PTP]
#67325 02/22/06 04:08 PM 02/22/06 04:08 PM |
Posts: 12,310 South Carolina | the carbon board should have better stiffness. Flex is bad.
[Re: ]
#67328 02/22/06 04:35 PM 02/22/06 04:35 PM |
Posts: 9,582 North-West Europe | Doug, You are really expecting a money ship to come in ! 2 new boats at the same time, WOW ! Personally I would just settle on one, but then I have to safe up for years when buying new toys like this. They have made some nice changes to the A2 from what I hear. You can now raise the daggerboards with a line.
The Blade is able to have this system as well. The hull moulds have specialized sections in de daggerboard wells to allow such a system to be fitted. I don't remember whether it is fitted as standard or not. The first Blade to the Netherlands had this system fitted. It is copied from the Taipans (4.9 and A's) which have this system as well. Are you getting the Kevlar hulls and carbon beams and rudders? Guys are the Pentex sails class legal? I have them on my Hobie 17 (squaretop and reacher) and love them.
For the F16's; all sail cloths are legal and therefor also Pentex. F16 class decided not to follow the Tornado and F18 class in limiting the use of sail cloths. In this respect we follow the A-cat class and we will continue to allow all sail cloths; as the A-cat class is expected to do. I hear alot of good comments on the Kevlar hulls. It gives the lightweight hulls like those of the Blade extra impact resistance and pretty much makes them comparable to hulls of much heavier boats. Carbon rudders ; nice upgrade. I've seen the rudders that are supposed to go onto the new Blades, I've held the prototypes in my hands and I liked the answers to the indepth questions I asked. I'm not allowed to tell to much about these new developments, so I won't. Matt, vectorworks and the European agent are the official contact points for this. However I'm going to tell that these rudders have quite alot of A-cat class development incorporated in them. As a matter of fact you will be hard pressed to tell them apart. Carbon beams; I have not heard of this development at all. Are you sure that carbon beams are an option ? I'm sure everything can be done to your boat when you lay extra money on the line but carbon beams is not really something the F16 builders and buyers showed much interest in. In the way of F16 sailing there is not much advantage in having carbon beams neither in platform stiffness nor in weight. Performance difference between alu beams and carbon beams are expected to be completely negligiable when looking at the Blade F16. You can't glue the carbon beams to the hull per F16 rules and this makes carbon beams a whole lot less advantagious. This rule was included in the F16 class rules as otherwise we would have serious troubles selling and shipping the boats internationally. At 2.5 mtr width the F16's will not fit into a container when assembled (glued together); at 2.3 mtr the A-cat can only just be transported assembled this way but only at increased international shipping costs. Carbon mast, that is allowed in the F16 class and I'm sure on can be had when so desired and when you are willing to pay for the upgrade difference. Nearly all A-cat mast building development is directly applicable to F16 masts as the two classes use the same general mast design and mast/sail behaviour. The crosssection are both of ellipical rather then teardrop shaped form. Both use the flexibility of the top part as an important trimming feature. The two rigs are actually quite related. Wouter
| | | Re: A cat vs F-16
[Re: ]
#67329 02/22/06 04:41 PM 02/22/06 04:41 PM |
Posts: 1,382 Essex, UK | BLADE F16
USD $12,900.00
Available Options
$110.00 Pair (Fore or aft) Doug, The spec doesn't say carbon beams - the beams are ali. The carbon option gives you "Rudders, boards, stocks and cross bar" , Stocks are the bit that the rudder head pivots in and the 'crossbar' means the tiller bar. It's still a helluva lot of boat for the money - a really good package at a really good price. I'd definately go for the Pentex sails (the jib will be fine as it's fully battened) and the Carbon upgrade.
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: A cat vs F-16
[Re: Wouter]
#67330 02/22/06 04:43 PM 02/22/06 04:43 PM |
Posts: 1,226 Atlanta | You can't glue the carbon beams to the hull per F16 rules You are getting pretty specific with the rules if this is in the rules, Wouter. What if want to glue my F16 up after I take delivery? Lots of guys "seat" their aluminum beams with epoxy and then bolt them down so the platform is stiffer. How are you going to police this? Make every arrive your regatta's un-assembled? Any extra goop in the beam socket and you're Dq'd? Are the rest of the rules that picky? | | | Re: A cat vs F-16
[Re: bobcat]
#67331 02/22/06 04:43 PM 02/22/06 04:43 PM |
Posts: 9,582 North-West Europe | I think vectorworks marine by now has quite some order list they need to work down. The European boats batch should be nearing completion by now if they want to make the delivery date. My info had the European boats production batch scheduled at late januari.
There are still a few US orders ahead of you now, but on the other hand building in batches is very attractive economically. I expect Vectorworks marine to save up all US orders over the last months and the next few weeks and then build them all in one go. As far as I can tell all US buyers heard the same delivery date (late march) and this seems to support the assumed batch job production schedule of above.
| | | Re: A cat vs F-16
[Re: Jalani]
#67332 02/22/06 04:49 PM 02/22/06 04:49 PM |
Posts: 1,121 Eastern NC, USA | Stocks are the bit that the rudder head pivots in and the 'crossbar' means the tiller bar.
100% correct. The tiller cross bar is carbon, not the main/rear beams. The tiller extension is a regular Ariba stick, I think.
Tom | | |
2,981
guests, and 191
