Page 2 of 3 1 2 3
Re: Blade F18 video [Re: dartfast] #68822
03/10/06 09:22 AM
03/10/06 09:22 AM
How do you go if you try http://www.thebeachcats.com/videos/BladeF18.mpg
without the "-" in the file name.
Re: Blade F18 video [Re: phill] #68823
03/10/06 10:41 AM
03/10/06 10:41 AM
It doesn't matter what kind of boats, blazing past other boats just looks great. Super looking boat phil!
Re: Blade F18 video [Re: Jake] #68824
03/10/06 10:50 AM
03/10/06 10:50 AM
I got it working.... Nice.. but why are the soundtracks always so bad
Re: Blade F18 video [Re: phill] #68825
03/10/06 12:50 PM
03/10/06 12:50 PM
Toronto, Ontario
pitchpoledave Offline
Toronto, Ontario
Here is a site with instructions to make your own steadicam:
http://www.cs.cmu.edu/~johnny/steadycam/
Very handy..Will take most of the shake out of the shots. I am going to try this out this summer..
Re: Blade F18 video [Re: phill] #68826
03/10/06 04:53 PM
03/10/06 04:53 PM
Phill,
if we want to carry the kite higher than it's designed for, we let out 5-8cm on the tack line and sheet in. So far we have used this technique to good effect in distance races when the wind isn't too strong (dont try this in anything near trapeze conditions). This small change really alters the shape of the kite and is fast up to a certain windspeed.
Following cats in any kind of chop/waves is next to impossible in small boats. They get thrown around and must slow down while cats power trough the waves much better. What you need is a powerful big boat with a deep V hull (semi-planer?) and a flybrigde, or a motor-cat
Why was they racing on the lake and not in the ocean? Sounds risky to race on the lake with Muldjewangk lurking about
PTP, I am old enough to remember when the soundtrack (Robert Palmer?) was the hottest thing played in the disco, so it works great for me. I suggest you listen to the lyrics while looking at the different scenes, this is obviously done with great consideration.
Re: Blade F18 video [Re: Rolf_Nilsen] #68827
03/10/06 07:42 PM
03/10/06 07:42 PM
Agreed - but why not ease it while in trapeze conditions? We do it often - especially distance racing.
Re: Blade F18 video [Re: Jake] #68828
03/11/06 02:51 AM
03/11/06 02:51 AM
Jake, I have three reasons. One is that it powers up to boat too much making it hard to control while creating a lot of drag once the wind is up. The second is wheter the mast can take the loads. We still have the Marstrøm Tornado alu-mast, and it's not the strongest one around. Third, it is hard on the spi cloth.
Re: Blade F18 video [Re: Rolf_Nilsen] #68829
03/11/06 08:03 AM
03/11/06 08:03 AM
We spent probably about 40% of last year's 523 mile Tybee 500 running as high and tight as possible with the spinnaker. I will attest that the loads are quite high - most of the crews hands (including mine) really paid the price. The truely grueling fact was that the spinnaker was adding a lot of drag for the power it generated - we were getting about an extra .2 knots out of it for all the work going into it...but we were racing!
Re: Blade F18 video [Re: Wouter] #68830
03/11/06 12:24 PM
03/11/06 12:24 PM
Denver. Sail in Georgian Bay,...
Chappie Offline
Chappie  Offline
Great video. Can we buy a Blade yet? Any idea on price?
H18. H20 CATchme ???30 next Multihull addict.
Re: Blade F18 video [Re: Chappie] #68831
03/11/06 05:13 PM
03/11/06 05:13 PM
Chappie:
I lost the price email when I redid conputer. Check the forum on A cat vs F16. I think it is somewhere in there.
Doug
Re: Blade F18 video [Re: Jake] #68832
03/11/06 05:55 PM
03/11/06 05:55 PM
I'm with Jake here.
Sometimes you need to go high.
I know that the last 5 miles of that race, I was trying to cover Space Coast when they snuffed their chute and started going over us. Knowing that Mark would simply pull his chute out of his snuffer (we had to tramp launch ours) if we started to douse, we popped about 4" of tack line out, double trapped and I had to play the traveller to keep us going. Point is, you can, sometimes, need to pop some tack line... not often in bouys though.
We ended up letting him get ahead of us... so he could find the sandbar for us
Re: Blade F18 video [Re: Wouter] #68833
03/11/06 06:59 PM
03/11/06 06:59 PM
California!
Inter_Michael Offline
California!
Sorry to hijack the thread..but while we are talking about pointing and using the kite....I came up with an adjustable tack line while using the stock Nacra snuffer.
I simply attached a lead at the end of the hoop, then ran a line thru the back in to a cam-cleat on the front beam. The line was measured with a stop knot to adjust from about the distance as if it were tied, to about 4-6" out. Worked pretty good to give adjustment.
If you want to keep it simple, you can always guess the conditons, then tie of the tack accordingly before you sail.
Michael
Re: Blade F18 video [Re: Chappie] #68834
03/12/06 08:21 AM
03/12/06 08:21 AM
Wouter Offline OP
Wouter  Offline OP
The Blade F16 (little brother from which the Blade F18 is derived) is build in the USA by http://www.vectorworkssail.com and it costs (fully fitted, race ready, Ullman suit of sails) 12.900 US$
More info at : Full price list given by Doug in an earlier post
The Blade F18 (as in video) is in its final development stages and so is not commericially available yet. However, I personally expect to see Vectorworks Marine add it to their product line in the not to distant future. It should be cheaper then the imported F18's (Tiger, Capricorn, Cirrus) then and on a par with other domestic F18's (Nacra, Mystere).
If you want more info about anything then contact : Phill Brander or Matt McDonald. I'll give you their e-mail adresses when interested.
Re: Blade F18 video [Re: Wouter] #68835
03/12/06 08:34 AM
03/12/06 08:34 AM
This will be a great addition to their product line for Vectorworks Marine.
Re: Blade F18 video [Re: Jake] #68836
03/12/06 09:08 AM
03/12/06 09:08 AM
Wouter Offline OP
Wouter  Offline OP
If VectorWorks Marine indeed chooses to go for the new boat as I personally expect then she is forming a beautiful product line-up :
- Blade F16 (available)
- Bim XJ A-cat (available)
- Blade F18 (expected)
- Blade 20 footer; Ultimate distance racer (Rolf, this will be something for you)
On www.bladecatamarans.com a presistant rumour is given more credit, see http://asiaboatrag.net/blade/6%20WHO/1people.html
It talks of the Blade 20 footer. Imagine a Taipan 5.7 (similar weight and rig) but with the new Blade hullshape and an updated rig. Got that picture ? Well this is where I expect it to come out at. Bloody fast and a pleasure to sail with excellent handling. And if VectorWorks Marine decides to take it to the market then this will be the first real competition for the I-20 design. The support of a significant production company will make the difference that boats like CFR20 etc simply don't have.
However, we'll have to wait a little while longer for this. One thing I like about Phill is that he doesn't rush things. It is either very good or gets another year of development. An engineers dream as I'm sure you agree Jake.
Re: Blade F18 video [Re: Wouter] #68837
03/12/06 09:46 AM
03/12/06 09:46 AM
One thing matt told me at Tradewinds about the proposed 20 footer would be that it would have kickup high-aspect boards.
I gotta see that.
Re: Blade F18 video [Re: Wouter] #68838
03/12/06 12:35 PM
03/12/06 12:35 PM
Yes I would. I can appreciate that.
Re: Blade F18 video [Re: ] #68839
03/12/06 03:43 PM
03/12/06 03:43 PM
Andrew Offline
Andrew  Offline
Doug: this is the Blade F18 thread, and I'd imagine that's what the question relates to. I know the F16 Blade is available, but I don't think (or know) that the F18 is.
Re: Blade F18 video [Re: MauganN20] #68840
03/12/06 03:59 PM
03/12/06 03:59 PM
Maughan,
technically, kickup daggers are not too hard to do. There has been made some prototypes for the Tornado. The downside is that you need gaskets to cover the bottom of the well as the boards need room to rotate aft..
Look at this: http://personal.inet.fi/private/muu/boards.htm
The mechanism can be refined a lot so it's hidden in the hull, or look for some other ideas further down on the page. Knowing a certain designers ability to think "out of the box", there might be something completely different in the works.
PS: Browsing trough Reino Uralas site is well worth, he has done lots of interesting stuff. Last was a VPP study of when to go double trapezeing downwind with the spi on a Tornado..
Re: Blade F18 video [Re: Rolf_Nilsen] #68841
03/12/06 06:04 PM
03/12/06 06:04 PM
Rolf: I thought it would involve gaskets, but Matt indicated that it wasn't the case IIRC.
Page 2 of 3 1 2 3
0 registered members (), 20,780 guests, and 1,475 spiders.
Most Online22,490
Yesterday at 08:14 AM
