| Re: Mainsheet blocks
[Re: mmiller]
#70722 03/29/06 03:49 PM 03/29/06 03:49 PM |
Posts: 32 Midland |  Thanks Matt and John - This is exactly the info that I need. Cheers, Mac | | | Re: Mainsheet blocks
[Re: PTP]
#70724 03/30/06 10:03 AM 03/30/06 10:03 AM |
Posts: 1,187 38.912, -95.37 | In other words, to have a convertable 6:1/7:1 the upper (triple) block would need to have a becket. Add a standup block, mounted through the hardware that attaches the main sheet cleat, to your lower block. Your cleat is on the bottom, you add the extra block on top of the "plate" that supports the cleat. You're spending for an upper triple w/becket and one small block only.
Another option is the new "carbo" triple as the upper, and instead of buying with a becket, run the tail of the main sheet through the hole in the center of the blocks and dead end, in effect same as w/becket, but maybe a few more bucks.
[Re: Banzilla]
#70726 03/30/06 01:18 PM 03/30/06 01:18 PM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | I think the Ratchamatics are awesome myself and use them on every boat I have had since they came out. On my F16 I am using the 8:1 Ratchamatic with 1/4" mainsheet. Sounds small,but with the 8:1 purchase it is easy to sheet and it also runs out very well when you ease the sheet.
I know in days of yore, we may have used as large as 7/16" line, and for sure 3/8" But with the new advanced blocks it is really not necessary and smaller line works really well.
I even use 1/4" on the Wave. Great for the puffs and when wheeling around the weather mark. Others are having to pull their sheets through the block, while mine just flys out and the sail is set within a boat length for downwind. Rick | | | Re: Mainsheet blocks
[Re: Banzilla]
#70727 03/30/06 02:26 PM 03/30/06 02:26 PM |
Posts: 1,252 California | Are both the ratchmatic and the ratchet carbo lowers a pain? What makes them harder to adjust? Isn't it a case of set it and forget it? The jaw angle adjustment on the original ratchets is far simpler. They have not found a way to do this on the carbo version. Maybe not as big a deal if you set it and forget it, but I like to change the angle for some conditions. If it is really blowing, I may want to get the blocks to release easier, so place the jaws higher. It is personal preference. I see no advantage to the carbo lower. That is why we use the standard triple lower and carbo upper in combination. | | | Re: Mainsheet blocks
[Re: mmiller]
#70728 03/30/06 05:18 PM 03/30/06 05:18 PM |
Posts: 1,203 uk | The ratchamatic lower is a nightmare! My son had a new 16 at the Carnac Eurocat regatta last year and spent the whole event trying to get the cleats at the right angle, got all stressed about it and didn't enjoy the event at all! We spent some time with little plastic wedges and have eventually got it right now [one setting for all winds] For some reason, this flashy/expensive piece of kit does not hold the cleat at the right angle.
[Re: Banzilla]
#70730 03/30/06 07:31 PM 03/30/06 07:31 PM |
Posts: 1,252 California | I like the adjustments on the 194 Hexaratchet triple... ![[Linked Image]](http://www.harkenstore.com/images/194.jpg) You just ease out the screw in the slot on either side. Make the adjustement up or down and re-tighten. It is easy to see you are in the 1 to whatever position. I do not like the adjustment on the 2630 Carbo triple... ![[Linked Image]](http://www.harkenstore.com/images/2630.jpg) You have to back out the center screw to get both sides of the system out of its indents. You then move and re-seat the side plates. Then tighten the screw. There is no good way to see how far you moved it and it is a disaster if you unscrew the thing too far. The 2141 would be even harder to deal with. | | | Re: Mainsheet blocks
[Re: Mac05]
#70731 03/30/06 10:10 PM 03/30/06 10:10 PM |
Posts: 4,119 Northfield Mn | On the strenght end: I'm no weakling, and when it really blowing, and I've been out a long time I struggle with sheating. I have a 6:1 harken system w/ 3/8 sheat. Most of this is probably because I tend to go out in heavy winds, and it all on lakes, or the Mississippi. Lot's of puffs and I never cleat the main. Just food for thought if you concerned with the strenght issue.
[Re: Tom Korz]
#70734 03/31/06 02:17 PM 03/31/06 02:17 PM |
Posts: 306 St. Louis, MO | Remember, the more purchase you have in you main block system, the more line it will take to sheet in and longer it will take to sheet out. 6:1 is a good balance between the mechanical advantage you want the the ability to sheet out in a reasonable amount of time.
Nick
Current Boat Looking for one
[Re: hobienick]
#70735 03/31/06 03:49 PM 03/31/06 03:49 PM |
Posts: 321 Albuquerque NM | Ok, the 6:1 or 7:1 is probably all you need for purchase, but what about the breaking strenght of the blocks them selves?
model h194
Shackle pin dia. (in) 1/4 SWL (lb) 500 Breaking strength (lb) 2000 Use with 004 - 5:1 / 048 - 6:1
verses the h2630 at SWL (lb) 1800 Breaking strength (lb) 4500 Holding power w/180 degree wrap 50 lb (23 kg) 10:1
I assume the SWL is the swivle breaking strenght?
Is this an issue on a h16?
Sam
[b] Sail Like you have a Pair
[Re: Banzilla]
#70737 04/01/06 08:35 AM 04/01/06 08:35 AM |
SWL = sustained working load if I remember correctly. You can really put the blocks under these loads and over whithout worrying about breaking them. Maximum breaking loads are typically alot higher. If passed swl you'll just wear the blocks down quicker which is still many many years. In effect SWL doesn't mean much.
2,781
guests, and 473
