| Teflon washers destroyed #71473 04/05/06 06:04 AM 04/05/06 06:04 AM |
Joined: Apr 2005 Posts: 53 The Netherlands, Europe flying_dutchman OP
Posts: 53 The Netherlands, Europe | When preparing my Hobie 16 I remembered the Teflon washers always come out damaged and distorted when removing the mast. Now I discovered why: The thread end section of the dolphin striker bar is 2-3 mm above the bottom where the mast fits in. So no nice ball & cup: the mast is actually resting on this bar-end only (± 12 mm diameter) and can move rather free instead of being fixed. Tried to remove the dolphin striker but it looks like I have to take the whole trampoline apart. Grinding inside looks alsmost impossible. My best guess would be making a washer with a hole in the middle (brass-copper??) Anybody some experience or other/better solutions?
Thanks from still far to cold Europe
Eddie Hobie 16 # 99173
Happy sailing from The Netherlands!
Eddie
Hobie 16 (1992) # 99173 & CT11 - with spi
| | | Re: Teflon washers destroyed
[Re: mmiller]
#71475 04/05/06 06:15 PM 04/05/06 06:15 PM |
Posts: 53 The Netherlands, Europe | Thanks Matt! You gave me a new approach to my problem. Most likely however I'm going to face some problems with the thread. My Hobie 16 is 14 years now - all seaside and last few years salt lake (= even worse !!). So corrosion is absolutely present. Probably have to replace the base ... Thanks once again for fast and detailed information
Eddie Hobby 16 #99173
Eddie
[Re: ReefedOne]
#71479 04/09/06 09:03 PM 04/09/06 09:03 PM |
Posts: 1,252 California | why Hobie can't go with the much more practical Prindle (half-ball) or Nacra (full-ball) systems? Those are not Nacra / Prindle innovations... but, Hobie has used mast step ball systems over the years on many models. We still do. I think the first was maybe the Monocat in the 70's? Well, it was considered for the 16, but class rules and keeping it as one-design as possible won. Also, Hobie Cat USA (Dan Ketterman actually) came up with the "chip keeper". We also redesigned the stop thickness and refined the angles. We now see much less wear on all parts. We tested this out at the 2004 Hobie 16 Worlds. Never replaced a chip and saw very little wear to the stops. All in demanding conditions and time on the water that equaled a years use in just 10 days of heavy racing. We don't need no stinking balls! | | | Re: Teflon washers destroyed
[Re: mmiller]
#71480 04/10/06 08:45 AM 04/10/06 08:45 AM |
Posts: 306 St. Louis, MO | I still have my bag of spare chips I took with me everywhere. Never had a problem. I also did the chip keeper thing after my first time on the water so I wouldn't loose them while trailering. I learn quickly.
Nick
Current Boat Looking for one
[Re: hobienick]
#71481 04/10/06 05:49 PM 04/10/06 05:49 PM |
Posts: 53 The Netherlands, Europe | Checked my mastbase last weekend. With the new ideas from the forum I wanted to investigate matter. Surely my mastbase doesn't look nice on the inside  . Looked at some other H16 at our club: they look far better - but they are seldom used...  Removing the popnails won't be a problem but due to the intensive corrosion I have serious doubts about being able to remove the base from the bar  . I will surely need to find a way to withstand the torque when trying to remove the base. And most likely risk damaging the thread as well...  Should I use a disk-grinder to cut base into 2 pieces??? For the moment I use a plastic bottlecap. Got a golfball somewhere but found out it was solid !!!! And more rubber than plastic so won't work at all I'm afraid. Just a crazy idea: any change of improving the base internally with any kind of 2-component metal or synthetics?? I really want to start sailing again (adicted???) Good winds and happy Easter Eddie Hobie 16 # 99173
Eddie
[Re: mmiller]
#71483 04/11/06 05:01 PM 04/11/06 05:01 PM |
Joined: Mar 2006 Posts: 66 Fort Lauderdale, FL, USA ReefedOne
Posts: 66 Fort Lauderdale, FL, USA | Last time I checked teflon washers were still cheaper than full or half balls Uhh... yeah... which is not... really... an issue because: a) The balls last approximately FOREVER; and b) They're THREADED onto the ds support rod... you can trailer those puppies at 100 mph, or de-step your mast in a hurricane, and they're GOING NOWHERE. why Hobie can't go with the much more practical Prindle (half-ball) or Nacra (full-ball) systems? Those are not Nacra / Prindle innovations... but, Hobie has used mast step ball systems over the years on many models. We still do. I think the first was maybe the Monocat in the 70's? I know... I should've said Prindle-STYLE and Nacra-STYLE systems... to be sure those guys did not invent the ball-and-socket joint--LOL. On that same note, however, there's no patent protection that prevents widespread adoption... or retrofitting. Just like Hobie's tiller-operated rudder raising system was used in one form or another on swing-keel monohulls for decades (centuries?) before the H-14... if Mr. Alter had any patents on that, I'm sure they only covered the minutae of the cam mechanism, etc. Well, it was considered for the 16, but class rules and keeping it as one-design as possible won. I'm not a class-racer, but I fail to see how the mast bearing being male or female confers any unfair speed advantage on the water.  Really just an onshore convenience matter... unless keeping your rivals out of the race is a valid strategy, LOL!... my bad. Perhaps Hobie/Coleman/et al are hooked on the recurring revenue from Teflon wafer sales? | | | Re: Teflon washers destroyed
[Re: ReefedOne]
#71485 04/11/06 10:14 PM 04/11/06 10:14 PM |
Posts: 471 NC | Uhh... yeah... which is not... really... an issue because: a) The balls last approximately FOREVER
I've replaced balls as much as I've replaced chips. Nothing on boats lasts forever. | | | Re: Teflon washers destroyed
[Re: drbinkle]
#71486 04/23/06 09:10 PM 04/23/06 09:10 PM |
Posts: 4,119 Northfield Mn | Its kinda funny. I almost always forget that stupid little chip in the step when I trailer the boat, and they always fall out on the 10 mile trip home from the lake. I left one in coming home from Texas to Minnesota, 1700 miles!!!, and the friggin thing stayed there the hole way home. I lose more than I use, they end up disappearing before they wear out half the time. Another thing, what are they a couple bucks? They take 1.5 seconds to install? Suck it up Nancy.
[Re: Karl_Brogger]
#71487 04/24/06 01:24 PM 04/24/06 01:24 PM |
Joined: Apr 2005 Posts: 292 Ontario, Canada Captain_Dave
Posts: 292 Ontario, Canada | Eddie (Flying Dutchman),
If you want to try and salvage your existing base and improve the floor of the socket, here are my suggestions for you:
First, simply grinding the protrusion will be difficult (as you have stated), but drilling it to below grade might be easy. Start with a small drill bit suitable for stainless steel (I use cobalt and zirconium bits) and carefully drill down into the very center of the protrusion - try not to drill down any more than necessary below the grade of the socket. Then proceed to much larger drill bits - or conical grinding bits - untill you end up with what would appear as a shallow countersunk depression where the protrusion previously was.
After this, clean out all contaminants from the socket. Use a degreaser/dewaxer/silicon remover. Any autobody shop may be willing give you a few ounces of this type of solvent for a couple bucks, otherwise its about 40 bucks a gallon - or more. Then mix up some JB-WELD (its a metal epoxy and VERY durable) and apply that to fill the voids and rebuild a nice looking socket. This will be easy to do with JBWeld - widely available.
JBweld is incredible stuff for this kind of high-wear, void filling application. It has wear resistance that is probably second to none for an epoxy filler. I have first-hand experience repairing a dime-size hole that went right through the cylinder wall of a 60hp engine... That was 12 years ago and the repair is still going today. I also used JBWeld when I had to drill out a badly damaged sparkplug thread. I then re-coated the cylinder head with JBWeld and retapped it. That repair is still going too.
What JBWeld does not tolerate very well is flex, or direct impact - it is relatively brittle.
I am fairly confident that when you properly decontaminate the bonding surfaces, the voids in the socket can then be dressed with JBWeld and be expected to hold up to the wear and tear. However, I`d very much recommend a proper teflon mast bearing at all times in the future to protect those surfaces.
Dave | | |
18,523
guests, and 801
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online22,490 13 hours ago | | |
