Page 10 of 10 1 2 8 9 10
Re: Naming your cat [Re: erice] #71828
08/22/08 05:53 AM
08/22/08 05:53 AM
japan
erice Offline
erice  Offline
japan
try again on the pic
eric e
1982 nacra 5.2 - 2158
2009 weta tri - 294
Re: Naming your cat [Re: erice] #71829
08/22/08 07:48 AM
08/22/08 07:48 AM
Herbie53 Offline
Herbie53  Offline
Currently sailing as "BBSHB" - Blue Bird [censored] Hits Bow.
Re: Naming your cat [Re: Herbie53] #71830
08/22/08 07:59 AM
08/22/08 07:59 AM
Netherlands
DennisMe Offline
DennisMe  Offline
Netherlands
Erice, are those sails as bad as they look?
Re: Naming your cat [Re: DennisMe] #71831
08/22/08 08:53 AM
08/22/08 08:53 AM
japan
erice Offline
erice  Offline
japan
what do you mean bad?
they are a whole lot better than the sails on my 420
eric e
2009 weta tri - 294
Re: Naming your cat [Re: erice] #71832
08/22/08 11:15 AM
08/22/08 11:15 AM
Here we go...put up a picture of you sailing and you better get ready to get...well...reviewed. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Jib's too tight and it's clearly stalling the mainsail. This usually happens before the leading edge of the main caves in but you're clearly in full on choke the main mode there. <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" />
Re: Naming your cat [Re: Jake] #71833
08/22/08 03:00 PM
08/22/08 03:00 PM
H
harx Offline
harx  Offline
H
I've got a 1981, baby blue, scuffed-hull, chipped-paint, epoxy-repaired, all around beat up Prindle 16.
Name: SUM > PARTS
Re: Naming your cat [Re: Jake] #71834
08/22/08 04:18 PM
08/22/08 04:18 PM
japan
erice Offline
erice  Offline
japan
ooohhh,,,
penny drops, thought dennis was ragging on the age/condition of the sails not their trim
yes, now i see that jib is hauled in way to tight and directing air INTO the main and not around it
in fact it looks like the only thing stopping the luff of the main from full collapse is the battens
must keep and eye on that
thanks for the call
eric e
2009 weta tri - 294
Re: Naming your cat [Re: NCSUtrey] #71835
08/23/08 09:35 PM
08/23/08 09:35 PM
Ont Canada
windsurfingsteve Offline
Ont Canada
Hey now your talking, I bought a used cat this summer and named it CATastrophe and yes we already had one small Catastrophe with it...
Brother of CATasrophe
Re: Naming your cat [Re: windsurfingsteve] #71836
08/24/08 12:27 PM
08/24/08 12:27 PM
Cincinnati, Ohio
Tri_X_Troll Offline
Tri_X_Troll  Offline
Cincinnati, Ohio
Sooo, apparently it's bad luck to rename a boat?
What happens if you take two boats and make them into one? Do you end up with a boat that has two names?
What happens if you replace the hulls on your boat?
What if you keep your hulls and replace everything else?
Re: Naming your cat [Re: Tri_X_Troll] #71837
08/25/08 02:12 AM
08/25/08 02:12 AM
Netherlands
DennisMe Offline
DennisMe  Offline
Netherlands
Erice, my message was quite ambiguous. Probably because I wasn't 100% sure what was wrong there myself.
Jake seems to have had little doubt though!
Sorry for the Hyjack everyone!
(personally I don't think renaming is bad at all, if Poseidon disagrees I'll take him on any day!)
Re: Naming your cat [Re: Tri_X_Troll] #71838
08/25/08 08:56 AM
08/25/08 08:56 AM
bad luck to rename a boat? - YES, bad mojo
two boats and make them into one? - Add a hyphen
replace the hulls on your boat? - check to see if your life insurance is in order
hulls and replace everything else - drink 2 bottles of rum, spin around 24 times counterclockwise and sacrifice a chicken.. you should be fine
0 registered members (), 373 guests, and 654 spiders.
