Jammed rudder pins #73745
04/29/06 11:36 AM
04/29/06 11:36 AM
H
HangOver Offline OP
HangOver  Offline OP
H
I did a quick search in forums but couldn't find anything new to try so thought i'd ask.
Basicly my rudder pin has jammed in the casting, it's off the boat but i left the pin in the casting for lack of a better place to keep it over the winter and it is now jammed such that no amount of oil and hitting it with a mallet will free it.
can anyone offer any other suggestions?
thanks, Andy
Re: Jammed rudder pins [Re: HangOver] #73746
04/29/06 12:57 PM
04/29/06 12:57 PM
Andy:
You might try some CLR. I got a zipper loose with it.
Doug Snell
Hobie 17
Sunfish
Soon to be Mystere 4.3
www.tcdyc.com
Re: Jammed rudder pins [Re: HangOver] #73747
04/29/06 02:40 PM
04/29/06 02:40 PM
Columbia South Carolina, USA
dave mosley Offline
dave mosley  Offline
liquid wrench will free anything
Re: Jammed rudder pins [Re: dave mosley] #73748
04/29/06 03:00 PM
04/29/06 03:00 PM
H
HangOver Offline OP
HangOver  Offline OP
H
i should have said i'm from the uk and while i haven't seen the products you mention over here i have been trying a penetrant oil to no avail
Re: Jammed rudder pins [Re: HangOver] #73749
04/29/06 03:04 PM
04/29/06 03:04 PM
I think CLR is an acronym for calcium, lime and rust. It is used to clean bathroom tile and the like.
Re: Jammed rudder pins [Re: dave mosley] #73750
04/29/06 03:36 PM
04/29/06 03:36 PM
ACK to liquid wrench!
PB Blaster. Find some at your autoparts store where all the spraycan stuff is. Will free frozen spark plugs in engine blocks. Let it soak for about 10-15 minutes then hit it with a second soaking, wait another 5, then hit it one more time and then try to free it.
If that doesn't work, cut pin, drill it out, and go buy another.
Re: Jammed rudder pins [Re: HangOver] #73751
04/29/06 04:48 PM
04/29/06 04:48 PM
What kind of boat? (it might help to understand what the pin and casting look like).
Re: Jammed rudder pins [Re: Jake] #73752
04/29/06 06:43 PM
04/29/06 06:43 PM
Had a zipper that was corroded REAL bad to the metal slide. Soaked it overnight and it cam loose. Try CLR (Calcium, Lime and Rust) if you can find it.
Doug
Re: Jammed rudder pins [Re: ] #73753
04/30/06 10:13 AM
04/30/06 10:13 AM
H
HangOver Offline OP
HangOver  Offline OP
H
the boat is a hobie 16, I've got the casting soaking in some oil again now but if that doesn't free it up i'll have a look around the auto parts stores when they open again on tuesday (it's a public holiday on monday)
thanks for the suggestions, i'll let you know how i get on
Re: Jammed rudder pins [Re: HangOver] #73754
04/30/06 01:52 PM
04/30/06 01:52 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
After soaking it in penetrating oil for a while you might tap on the pins with a punch from underneath.
If you can't break it loose it might be easier to remove the gudgeons from the boat and cut the pins. Repalce the gudgeons and pins and polish the holes in the rudder castings before assembly.
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: Jammed rudder pins [Re: hobie1616] #73755
05/05/06 05:10 PM
05/05/06 05:10 PM
H
HangOver Offline OP
HangOver  Offline OP
H
finaly got it out, since it was already off the boat i had a guy with a vice have a go at it and it came straight out
0 registered members (), 2,355 guests, and 145 spiders.
