| Paint Remover
[Re: cyberspeed]
#73773 04/30/06 03:03 PM 04/30/06 03:03 PM |
Posts: 851 US Western Continental Shelf | I've heard good things about the 3M remover. I've used paint remover too. You apply it to the sticker, that's the whole sticker! (BassOmatic) and let it soak. You then take a disposable rag and wipe it all away. I used the stuff in the golden yellow spray can. It has not harmed my gel-coat or anodizing, but it did strip the paint off of an aluminum cleat. GARY
Santa Monica Bay Mystere 6.0 "Whisk" <--- R.I.P. | | | Re: Adhesive removal
[Re: carlbohannon]
#73776 05/01/06 08:18 PM 05/01/06 08:18 PM |
Posts: 1,187 38.912, -95.37 | Older adhesives are dissolved in a mixture resembling paint thinner. The newest adhesives do not depend on the evaporation of a solvent and can be hard to remove.
I would start with the paint thinner, then 3M adhisive remover, D-Limone (pure concentrated orange cleaner) opps, goo-off, "Latex paint remover", 3m 5200 remover and finally chill it and scrape it off.
Amen to that  Taking adhesive off old beaters is a cinch compared to what I ran into on our "new to us" van. Letters are eight years young and some dandy adhesive indeed. Acetone (my personal favorite) will do nothing more than spread it over a larger area  guess I'll spring for 3M product next.
[Re: _flatlander_]
#73777 05/01/06 10:45 PM 05/01/06 10:45 PM |
Posts: 12,310 South Carolina | on really old crusty stuff, use a razor blade to remove the vinyl - leave the crusty adhesive underneath. Then take a rag soaked with acetone and lay it on top of the adhesive for a minute or two (the rag keeps the acetone from evaporating so quickly). Then, carefully, use the razorblade to scrape up the adhesive - it will come up like butter. Keep a clean rag to clear the razor blade often. Then you can rub down with acetone to remove the little tiny leftovers.
Jake Kohl | | |
21,948
guests, and 1,940
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online23,915 6 seconds ago | | |
