Adhesive removal #73769
04/29/06 08:24 PM
04/29/06 08:24 PM
jdaf31r Offline OP
jdaf31r  Offline OP
Whats the best way to remove the adhesive from nonskid tape? I've tried a hot air gun, Acetone, Adhesive remover. They are all a mess and don't seem to work as easy as I think they should.
What else can I try?
Re: Adhesive removal [Re: jdaf31r] #73770
04/29/06 08:49 PM
04/29/06 08:49 PM
cyberspeed Offline
cyberspeed  Offline
3M has an adhesive remover. You will have to get it from industrial supply place.
craig van eaton
Supercat 20
TEAM CYBERSPEED
www.TeamCyberspeed.com
Endurance Series
www.SailSeries.com
Re: Adhesive removal [Re: jdaf31r] #73771
04/29/06 11:57 PM
04/29/06 11:57 PM
What kind of adhesive?
Re: Adhesive removal [Re: jdaf31r] #73772
04/30/06 11:17 AM
04/30/06 11:17 AM
V
Ventucky Red Offline
V
Goo-Off - make sure you use it outside
Paint Remover [Re: cyberspeed] #73773
04/30/06 03:03 PM
04/30/06 03:03 PM
US Western Continental Shelf
hobiegary Offline
hobiegary  Offline
I've heard good things about the 3M remover. I've used paint remover too. You apply it to the sticker, that's the whole sticker! (BassOmatic) and let it soak. You then take a disposable rag and wipe it all away. I used the stuff in the golden yellow spray can.
It has not harmed my gel-coat or anodizing, but it did strip the paint off of an aluminum cleat.
GARY
Santa Monica Bay
Re: Adhesive removal [Re: jdaf31r] #73774
05/01/06 09:06 AM
05/01/06 09:06 AM
Houston
carlbohannon Offline
Houston
Older adhesives are dissolved in a mixture resembling paint thinner. The newest adhesives do not depend on the evaporation of a solvent and can be hard to remove.
I would start with the paint thinner, then 3M adhisive remover, D-Limone (pure concentrated orange cleaner) opps, goo-off, "Latex paint remover", 3m 5200 remover and finally chill it and scrape it off.
Re: Adhesive removal [Re: jdaf31r] #73775
05/01/06 02:29 PM
05/01/06 02:29 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
Oops! is da kine brah! Available at Ace Hardware stores.
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: Adhesive removal [Re: carlbohannon] #73776
05/01/06 08:18 PM
05/01/06 08:18 PM
Amen to that Taking adhesive off old beaters is a cinch compared to what I ran into on our "new to us" van. Letters are eight years young and some dandy adhesive indeed. Acetone (my personal favorite) will do nothing more than spread it over a larger area guess I'll spring for 3M product next.
Re: Adhesive removal [Re: _flatlander_] #73777
05/01/06 10:45 PM
05/01/06 10:45 PM
on really old crusty stuff, use a razor blade to remove the vinyl - leave the crusty adhesive underneath. Then take a rag soaked with acetone and lay it on top of the adhesive for a minute or two (the rag keeps the acetone from evaporating so quickly). Then, carefully, use the razorblade to scrape up the adhesive - it will come up like butter. Keep a clean rag to clear the razor blade often. Then you can rub down with acetone to remove the little tiny leftovers.
Re: Adhesive removal [Re: _flatlander_] #73778
05/02/06 06:26 AM
05/02/06 06:26 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
Buy the 3m product direct, great service, much less markup.
http://www.3m.com/
Chris Allen
Nacra 20 Gertie
www.wrcra.org
0 registered members (), 16,102 guests, and 1,036 spiders.
Most Online22,490
Yesterday at 08:14 AM
