| Re: Spi for 430/F14
[Re: phill]
#73853 05/28/06 06:15 AM 05/28/06 06:15 AM |
Joined: Feb 2004 Posts: 461 Sydney Australia Berny OP
Posts: 461 Sydney Australia | Thanks Phil, I don't know about leaving stays connected to the mast, it's not something I like to do. My main hassle so far has been sorting the retrieval through the spi and attaching the tackline, halyard and sheet without a twist. I think I could leave the retrieval line (halyard) attached to the spi and leave it all in the sock. That'd make it a lot easier.
I flipped the boat again on the jibe mark yesty. 22 knotts, traveller down about 300mm, sheet cracked but firm, spi stowed. I bore away, waited, then pulled the sail across, got myself to the new windward side just in time to be tossed off the tramp as the boat rolled over. Bloody frustrating. I'm now thinking I'm probably turning through too larger an angle and I'm actually around to a beam reach before I'm set. I think I need to steer down after the sail pops. On a mid downwind jibe, this would give me time to set the kite and then harden up. Sound reasonable? Either that or leave the boat on the beach when it's over 15k untill I'm sorted. <img src="http://www.catsailor.com/forums/images/graemlins/laugh.gif" alt="" />
| | | Re: Spi for 430/F14
[Re: Berny]
#73854 05/28/06 08:23 AM 05/28/06 08:23 AM |
Posts: 1,449 | Bern, Basically in high winds your better off keeping the angle small and stalling the main until the kite is set. Go through too great an angle and the main not tight enough and your gone. This is just what I've found. Regards, Phill
| | | Re: Spi for 430/F14
[Re: phill]
#73855 06/04/06 05:41 PM 06/04/06 05:41 PM |
Posts: 461 Sydney Australia | It's sometimes hard to stall the top of a big top main though. One of their advantages is they allow more twist and are generally more powerful high, and this also makes them more difficult to control off the wind. Not a problem in lighter winds but it would seem that as the wind strength increases and the sheet is cracked, the top twists off and powers up as you bear away driving the lee bow in. I think that dropping the traveller and leaving the sheet on hard might be the answer in that it would tend to control the twist more. That is if the traveller can operated under the load which is doubtful.
On another note, does anyone jibe their kite on a cat? I mean as opposed to tacking it?
| | | Re: Spi for 430/F14
[Re: Berny]
#73856 06/04/06 08:50 PM 06/04/06 08:50 PM |
Posts: 591 Bradenton, FL | Be careful dropping the traveler, even with the main sheeted tight you might lose needed support for running the spinnaker.
Hobie 14T
| | | Re: Spi for 430/F14
[Re: Sycho15]
#73858 06/05/06 01:25 PM 06/05/06 01:25 PM |
Posts: 9,582 North-West Europe | Be careful dropping the traveler, even with the main sheeted tight you might lose needed support for running the spinnaker.
This can only be an issue if your mast rotation limiter is still on. If the mast is much rotated then dumping the maintraveller is (in my opinion) not a problem in any wind. Wouter
| | | Re: Spi for 430/F14
[Re: Berny]
#73861 06/13/06 03:38 AM 06/13/06 03:38 AM |
Light mylar or pentex cloth. Works fine for me ! Appears to be exactly the same as your mainsail cloth but is just a more lightweight version of it.
Leave the bag open at the back with only a single strap with eye to guide the retrieval line and prevent the spi from being pulled out.
| | | Re: Spi for 430/F14
[Re: Berny]
#73863 06/13/06 05:47 AM 06/13/06 05:47 AM |
Posts: 1,449 | Bern, Don't crack the sheet. Pull it on. Only when the kite is set and the boat up to speed do you easy the sheet a little to get the main out of its stalled situation. If you are concerned about the big head not being stalled pull the sheet on real hard just before you jibe but make sure you go through a very small angle. Just enough for the jibe.
Regards, Phill
| | | Re: Spi for 430/F14
[Re: phill]
#73864 06/13/06 05:37 PM 06/13/06 05:37 PM |
Posts: 461 Sydney Australia | Bern, Don't crack the sheet. Pull it on. Only when the kite is set and the boat up to speed do you easy the sheet a little to get the main out of its stalled situation. If you are concerned about the big head not being stalled pull the sheet on real hard just before you jibe but make sure you go through a very small angle. Just enough for the jibe. Regards, Phill Yes, that sounds like the best way to do it. I'm still in a bit of a headspin at the moment till I get more time on the water. I have realised that the boat wants to round up with no pressure in the kite so it's essential to get it set quickly. I also need to pay more attention to the telltails so I know exactly where I am going through the jibe. All pretty obvious stuff but in the heat of the moment, logic sometimes goes out the window. <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> On another note, it took me two hours + to rig on Sunday. I know it will get easier as I work out the best proceedure, but! I'm looking at simplifying the whole setup, maybe using more toggle pins, possibly a cordless screwdriver for the shackles etc. | | | Re: Spi for 430/F14
[Re: Darryl_Barrett]
#73868 06/15/06 02:43 AM 06/15/06 02:43 AM |
Posts: 461 Sydney Australia | That "us" is like the royal "we" Berny, meaning in reality just the one person. Don't worry, when the rigging with spinnaker becomes "automatic" and you don't have to stop and "work it all out" every time that you go sailing, I am sure that the time will come down dramatically. Like most things, the more familiar you are, the easier it becomes, (except for old "farts" like me) mate, I'm not as young as I used to be, and I wasn't young then. <img src="http://www.catsailor.com/forums/images/graemlins/laugh.gif" alt="" /> | | |
660
guests, and 119
