Page 4 of 7 1 2 3 4 5 6 7
Re: As a result of the upgrade I lost .... [Re: Wouter] #74880
05/11/06 06:43 PM
05/11/06 06:43 PM
I would like to vote for entlarging the search time frame.
Currently it is 1 year and that is too short.
Maybe we can have it default at 1 year but still allow longer time frames.
I personally use the search function alot to do fact checking. Also thread dealing with trim, spi sailing are often out side of the year timeframe.
I also miss the "or" / "and" option in the keyword search. With the new search engine you can much less fine tune your search parameters.
All,
Agree with Wouter that 1 year is not enough.
As for searching, use + to include a term, and - to exclude.
so if you want to find posts that mention 'spi' but not 'sheet' put this in the search box +spi -sheet
If you want 'or' searching, just use spi sheet and this will return anything with either spi or sheet, if you want ONLY "spi sheet" use "spi sheet"
You can build these up, but UBB does eventually get confused!
Re: As a result of the upgrade I lost .... [Re: scooby_simon] #74881
05/11/06 07:17 PM
05/11/06 07:17 PM
Thanks for the info on how to do a search. I will see if Rick can add that to the FAQ or put it in a sticky at the top. And you right, one year is definitely not a long enough search frame. I used to like it when I could click on "All posts" which went back to the beginning of time.
Also, I really like the Calendar feature. I am going to be using that a lot to help keep myself organized -- I hope. <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />
Re: As a result of the upgrade I lost .... [Re: Mary] #74882
05/12/06 11:20 AM
05/12/06 11:20 AM
Dunedin Causeway, FL
David Parker Offline
I really appreciate the FAST screens on this new setup. Instantaneous in most cases!
HOWEVER, there is still one s-l-o-w step. If you want to change to a different forum and you hit "Main Index" at the top it takes 10-15 seconds to arrive. If you "Jump" at the bottom it's better but still slow at times. Is there a faster way or can this be sped up?
Re: As a result of the upgrade I lost .... [Re: David Parker] #74883
05/12/06 11:34 AM
05/12/06 11:34 AM
It only takes mine one second to switch to "Main Index."
Re: As a result of the upgrade I lost .... [Re: Mary] #74884
05/12/06 01:47 PM
05/12/06 01:47 PM
Does anyone else have to logon everytime they go to site? It doesn't remember me. Still would like to see new post highlighted like before.
Doug
Re: As a result of the upgrade I lost .... [Re: ] #74885
05/12/06 02:01 PM
05/12/06 02:01 PM
I changed the search setting to allow you to go back 5 years. Keep in mind that when a search is done that goes back that far, it will take up more system resources and can slow things down while the search is in progress for everyone. If this becomes a problem, we may need to shorten the search length again.
As for logging in each time, I have not tried it, but there is a checkbox at the login screen to remember you when you come back. If this is not working, please post it here and I will take a look at it.
Re: As a result of the upgrade I lost .... [Re: ] #74886
05/12/06 02:21 PM
05/12/06 02:21 PM
I almost never have to log-in again, even after I shut my computer down -- as I just did this morning because of a huge clap of thunder.
Re: As a result of the upgrade I lost .... [Re: ] #74887
05/12/06 02:35 PM
05/12/06 02:35 PM
Question: It seems as though if I do a search from our Google search engine on the home page, with it on the default for catsailor, it brings up everything throughout the forums (and our whole website) instantaneously. So wouldn't that be a better way to do a search without slowing down the whole forum for everybody?
Re: As a result of the upgrade I lost .... [Re: Mary] #74888
05/12/06 07:14 PM
05/12/06 07:14 PM
The Instant Graemlins are now working......
<img src="http://www.catsailor.com/forums/images/graemlins/ooo.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/mad.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/laugh.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/crazy.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />
Re: As a result of the upgrade I lost .... [Re: ] #74889
05/12/06 07:30 PM
05/12/06 07:30 PM
Thanks, Chad.
Re: As a result of the upgrade I lost .... [Re: Mary] #74890
05/12/06 07:39 PM
05/12/06 07:39 PM
I noticed that the new software doesnt resolve the SPAM issue.
IMHO the cause of this problem is that firsttime posters should not be allowed to put a URL in their message.
Can this be solved?
Re: As a result of the upgrade I lost .... [Re: Tony_F18] #74891
05/13/06 04:14 AM
05/13/06 04:14 AM
Can you fix it where we don't have to login everytime we go to the site? It won't remember me.
Doug
Re: As a result of the upgrade I lost .... [Re: ] #74892
05/13/06 09:52 AM
05/13/06 09:52 AM
It remember me fine every time I return to the site, over multiple machines. I suppose they use cookies for this, so perhaps you need to do something at your end?
Re: As a result of the upgrade I lost .... [Re: ] #74893
05/13/06 12:11 PM
05/13/06 12:11 PM
Doug
Check your cookie setting on your firewall. This may be the problem
Re: As a result of the upgrade I lost .... [Re: Mary] #74894
05/13/06 12:15 PM
05/13/06 12:15 PM
No problem.
It's all in the UBB guide somewhere (Yes, I have read it) and you can do other things too !
I'm in the process off setting up a site using vBulltin and it's so much better than UBB, and cheraper too !
Might be worth considering next time you have to pay an upgrade.
I'm also (probably) going to be involved in a mass migration from UBB to vB so if you are interested I can let you know how it goes.
Re: As a result of the upgrade I lost .... [Re: scooby_simon] #74895
05/14/06 08:09 PM
05/14/06 08:09 PM
The read numbers that show unread threads does not show up anymore?
Doug
Re: As a result of the upgrade I lost .... [Re: ] #74896
05/16/06 12:31 AM
05/16/06 12:31 AM
As I said the little red numbers are no longer there. You have to login every time, it doesn't remember you. Also the dates are off. It already shows the 16th.
Doug Snell
Re: As a result of the upgrade I lost .... [Re: ] #74897
05/16/06 01:02 AM
05/16/06 01:02 AM
Edmonton, Alberta, Canada
bobcat Offline
bobcat  Offline
Doug
It seems like a cookie thing. Do you have a privacy/antispyware type program installed that may be blocking all cookies?
I have to say that the unread post counter seems broken. It tends to point me at posts that I have already read.
BTW
When you emailed me a couple of weeks ago, I noticed that your system clock was off by about a week.
Edit:
Hey you are right. This post was made tomorrow!
Re: As a result of the upgrade I lost .... [Re: bobcat] #74898
05/15/06 05:07 PM
05/15/06 05:07 PM
Bobcat:
Clock is right now on my computer seems to be an intermittent problem. Red numbers are there now. Comes and goes. May be a bug. Going to crash for a while. Worked to many hours this weekend.
Doug
Re: As a result of the upgrade I lost .... [Re: bobcat] #74899
05/15/06 06:40 PM
05/15/06 06:40 PM
It appears to be some kind of problem with the forum clock. The most "current" post "was" made at 12:29 a.m. tomorrow. And others were made later this evening. Very interesting. <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />
Chad is working on it.
0 registered members (), 21,950 guests, and 1,271 spiders.
Most Online23,788
2 hours ago
