| Re: As a result of the upgrade I lost ....
[Re: Mary]
#74900 05/15/06 06:54 PM 05/15/06 06:54 PM |
Posts: 5,582 “an island in the Pacifi... | It appears to be some kind of problem with the forum clock. The most "current" post "was" made at 12:29 a.m. tomorrow. And others were made later this evening. Very interesting. <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />
Chad is working on it. That might explain why read posts keep coming back as new ones. <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" /> US Sail Level 2 Instructor US Sail Level 3 Coach | | | Re: As a result of the upgrade I lost ....
[Re: Mary]
#74901 05/15/06 07:10 PM 05/15/06 07:10 PM | Anonymous
| Anonymous
Unregistered | Chad:
Red new post numbers won't go away once you have read them. Still needs tweaking.
Doug | | | Re: As a result of the upgrade I lost ....
[Re: Mary]
#74902 05/16/06 02:58 AM 05/16/06 02:58 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | The problem appears to be fixed. As I had hoped, once we caught up to the future and into the present again, the posts started bringing the threads up to the top again.
Now my only problem is that all mine show in Central time instead of Eastern time. Is that just me, or is everybody not showing the posts in their local times? I don't know how it worked before the upgrade, but I assumed everybody was seeing all the posts with their local times, wherever they were in the world. | | | Re: As a result of the upgrade I lost ....
[Re: Mary]
#74903 05/16/06 03:12 AM 05/16/06 03:12 AM |
Posts: 1,382 Essex, UK | Mary,
You have to set your local time as an offset from the forum time.
If you scroll right to the bottom of the Main Index page, on the bottom left is a box of Extra Information. At the bottom of that is a Current Adjusted Date link which tells you what your current setting is. All you need to do is note how far out it is then click the link which takes you to your personal display preferences page. Change the time offset according to the amount of offset you require, hit Submit and your time is adjusted. (It's easy to adjust 'the wrong way') Simple!....NOT <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: As a result of the upgrade I lost ....
[Re: ]
#74904 05/16/06 03:13 AM 05/16/06 03:13 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | Doug, Now that the time is back in synch, the yellow folder light goes out and the red numbers indicating new posts goes out after you have opened the thread with new posts.
As before, after you have read a particular thread, in order to make the lights go out, you have to go up to the top of that thread and click on "Index," in that bar that says "Previous," "Index," "Next," etc. When you click on "Index," it takes you back to the list of posts in that particular forum, and you should see the lights out on the post you just read.
P.S. However, if you want to leave the "lights" on so you can find it to go back and read it again later, just hit your normal "Back" button (instead of that "Index" button) and it will take you back to the forum thread list without eliminating your "lights." | | | Re: As a result of the upgrade I lost ....
[Re: Mary]
#74906 05/16/06 07:14 AM 05/16/06 07:14 AM |
Joined: Mar 2003 Posts: 943 East Gippsland, Australia Tim_Mozzie
Posts: 943 East Gippsland, Australia | I'm having the opposite problem with the unread posts indication. Many people have said the red numbers won't go away, but I'm not getting any in the first place. The threads used to be highlighted a darker grey background when there were unread posts as well but this isn't happening either. I'm logged in and I have cookies allowed. I can see no indication of new posts at all now. Very inconvenient <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" />
Tim Shepperd Mosquito 1775 Karma Cat
[Re: Tim_Mozzie]
#74908 05/16/06 08:17 AM 05/16/06 08:17 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | Tim, I think your problem may be the same as what we had here, with things being somehow posted in the future. It has gotten back to normal here, but maybe it will take longer for yours to catch up so that things start getting posted normally again.
And be sure to adjust your time setting for the forum, as Jalani explained in this thread. I don't know how many hours you are behind or ahead of the U.S. "Central Time" -- I think you are ahead of us; aren't you? At least I know Australia celebrates New Year's before we do. So, you would have to add a bunch of hours to the forum clock. Once your clock is on your local time, instead of U.S. Central Time, maybe everything else will work right? I hope. <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />
| | | Re: Time to load.....
[Re: David Parker]
#74909 05/16/06 08:32 AM 05/16/06 08:32 AM |
Posts: 1,382 Essex, UK | David,
there is no doubt that the forum is much, much quicker since the upgrade. The Main Index page load time for me is near instant (as are all the forum pages). Are you sure that the delay is not at your end?
"Generated in 0.143 seconds in which 0.102 seconds were spent on a total of 12 queries. Zlib compression enabled."
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: Time to load.....
[Re: Jalani]
#74910 05/16/06 04:51 PM 05/16/06 04:51 PM | Anonymous
| Anonymous
Unregistered | Mary:
The forum is working great. The red numbers are still not showing. I just have to look at each thread by the date and see if I have read it.
Doug | | | Re: Time to load.....
[Re: ]
#74911 05/16/06 05:41 PM 05/16/06 05:41 PM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | If your numbers and lights are not coming on, then it is NOT working great for you. Rick has the same problem on his computer that you are having, but everything works fine on my computer.
So what causes the difference? It must be some adjustment that has to be made within certain computers.
Rick's clock is set properly to synchronize with the forum server clock, same as mine.
Oh, well, somebody will come up with the answer to this mystery. <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" /> | | | Re: Time to load.....
[Re: Mary]
#74913 05/17/06 07:11 AM 05/17/06 07:11 AM |
Joined: Jun 2001 Posts: 9,582 North-West Europe Wouter OP
I have all the issues that other describe on all the 3 individual PC's that I work on (no cookie problem therefor). Also sometimes it works as it is supposed to but more often it is not. I'm still just remembering dates and times. I also adjusted the time settings very early on, didn't help.
[Re: Mary]
#74915 05/17/06 07:51 AM 05/17/06 07:51 AM |
Joined: Nov 2001 Posts: 138 Florida, Pnellas, USA dartfast
Posts: 138 Florida, Pnellas, USA | Don't fix it!? You have done a great job. Thanks so much for the fantastic fix. Mine is working great. Usually it is my computer that is out of sync. Super fast now. Generated in 0.11 seconds in which 0.082 seconds were spent on a total of 13 queries. Zlib compression enabled. Everything else seems to be working also.
Terry | | | Re: Time to load.....
[Re: Mary]
#74916 05/17/06 07:57 AM 05/17/06 07:57 AM |
Posts: 1,382 Essex, UK | OK, here's something peculiar:
My computers (3 of them - 2 at home one in the office) all work as I'd expect; red numbers for new posts, yellow folders on the left etc. BUT one of them, my laptop, shows numbers of new posts with red numbers in the indexes and clears them once read, EXCEPT for the F18 forum!!! <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" />
It doesn't matter how many times I read the posts in the F18 forum, when I go back to the Main Index there are 2 unread posts showing for the F18s. I finally had to go to My Home and select Mark All Posts Read to clear them. Then someone posted a new post in the F18s and the problem is back!!! <img src="http://www.catsailor.com/forums/images/graemlins/mad.gif" alt="" />
I notice that in the My Home section you can reset the cookies for the site, I'm going to try that next.....
[color:"red"] EDIT: Since expiring the cookies and logging in again all seems to be working perfectly. Unfortunately no-one has yet posted to the F18 forum so that I can check whether that particular problem is solved (at least for me personally).
Mary, it might be worthwhile expiring the cookies on one of the other misbehaving computers (while logged in) then logging in again and see if it sorts that computer out? [/color]
[Re: Jalani]
#74917 05/17/06 11:29 AM 05/17/06 11:29 AM | Anonymous
| Anonymous
Unregistered | I have just had to go by checking the dates.
[Re: Jalani]
#74918 05/18/06 01:45 PM 05/18/06 01:45 PM |
Posts: 1,187 38.912, -95.37 | OK, here's something peculiar:
Mary, it might be worthwhile expiring the cookies on one of the other misbehaving computers (while logged in) then logging in again and see if it sorts that computer out? [/color] The new system works great, and thank you very, very much. I'm experiencing the same thing with the new posts not clearing for the F18 forum, even after repeated readings and exiting through the "index".
[Re: ]
#74919 05/18/06 01:45 PM 05/18/06 01:45 PM | Anonymous
| Anonymous
Unregistered | In regards to the issue where the number of unread messages and the folder colors are not working, the following is from a support request I submitted to UBB.threads. https://www.infopop.com/q/q.php?a=vt&ticket=1147923434-R9GG7They are aware of the issue and trying to find out what is going on. Maybe we can help provide some more info for them to work with. Please post here your OS, browser version and if you are having problems with the unread message totals and unread message folder colors. | | |
14,959
guests, and 1,083
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online22,490 5 hours ago | | |
