The prebend and tight diamond wires are a better rig setup for the P-19 so you should leave your rig in that configuration. The best way to tell if you have sufficient diamond tension is to sail the boat upwind in double trapeze conditions. If you see any slack at all in the weather diamond wire, add more tension. 1.5" of pre-bend sounds about right. You should also consider investing in a Loos Gauge to measure rig and diamond tension. The Loos "A" gauge made out of silver andonized aluminum was used in the P-19 tuning guide. I seem to recall a recommended Loos gauge setting of 34 for the diamond wire tension on the P-19. You should be able to purchase a Loos gauge from Annapolis Performance Sailing (
www.apsltd.com) and possibly West Marine. Good tool to have.
By the way, I still have the Smyth spinnaker you inquired about but will not be in south Florida until next January for the next A-class midwinter race week. If you are still interested, you can purchase the spinnaker, tramp bag, spinnaker blocks and running rigging and build your spinnaker pole.
Bob Hodges
