| Re: Going from Wave to Hobie 16... thoughts?
[Re: will_FL]
#78366 06/26/06 07:34 AM 06/26/06 07:34 AM |
Posts: 206 Virginia USA | It's really hard to go wrong with a H16 (or P16). Like the Wave, they are simple and durable but they are a definite step up in sailing performance. Even if you find it is not the boat for you, they are very easy to sell. However, there is a lot of 20-30 year old junk for sale out there. If you don't have a lot of H16 knowledge, I recommend taking a friend to evaluate the hulls and sails of any boat for sale. The rest of the stuff is (reletively) modest cost to replace.
H16 v. P16: Very little difference between these boats. They were both designed as rugged, off-the-beach boats. H16 has the advantage of being more popular, therefore more used parts available, etc.
4 to 5 foot seas: Any beach cat is going to be a handfull in these conditions, sustained 20+ kts. Maybe the Gulf Stream can create 4-5 in less wind, I guess your milage may vary. If the argument is that the H16 is pitch pole happy in 4-5, then show me any beach cat that isn't! The H16 hull design does make it more easy to pitch pole but it is all reletive. It is not an issue so egregious that you should not consider buying one. The argument is usually posed by people wihout a lot of H16 experience or have some other agenda.
<img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" /> | | | Re: Going from Wave to Hobie 16... thoughts?
[Re: will_FL]
#78368 06/26/06 05:41 PM 06/26/06 05:41 PM |
Posts: 31 orlando, fl | oops the second part of that post didn't send... i'll just continue it below:
i found a Hobie 16 down in tampa on craigslist and asked for a picture. one thing i noticed in the photo was what appeared to be an irregular bend in the tiller bar. is this normal?
to see the picture, its attached in my last post.
thanks again!
edit: the cat is from 1986 and its going for $1000. this seems a little low compared to other mid-80's cats i've seen. is this something to be concerned about?
[Re: will_FL]
#78370 06/26/06 07:42 PM 06/26/06 07:42 PM |
Posts: 5,582 “an island in the Pacifi... | one thing i noticed in the photo was what appeared to be an irregular bend in the tiller bar. is this normal?! Do you mean the tiller or tiller crossbar? Your picture doesn't work. The early H16s did have a bend in the tillers. The only other thing thing bent on a H16 is the front crossbar. US Sail Level 2 Instructor US Sail Level 3 Coach | | | Re: Going from Wave to Hobie 16... thoughts?
[Re: CMerrell]
#78372 06/27/06 12:12 PM 06/27/06 12:12 PM |
Posts: 1,252 California | Believe the H16 had the bent tiller for most of the '80s. Yes, tiller arms were bent in a vertical direction till about the late 80's - early 90's. | | | Re: Going from Wave to Hobie 16... thoughts?
[Re: will_FL]
#78374 06/28/06 06:54 AM 06/28/06 06:54 AM |
Posts: 206 Virginia USA | IMHO average condition for a '80s boat would be one that was used but not abused. Original sails, some wear to batten pockets but no major rips or repairs; original trampoline, showing its age; solid hulls, chalky gel coat and quality bottom job okay but no major damage or sloppy repairs, no soft spots; straight, watertight mast; proper off season care (e.g. boat on a trailer not on the beach, sails stored inside); etc. Upgrades that would add value to an "average" boat would be replacement sails, replacement tramp, rigging less than 2 YO, upgraded blocks, upgraded/reconditioned rudder system.
There are so many variables that it is hard to say what is a good price especially considering trailer/trailer condition, PFD/trap harnesses, spare parts, time of year, motivation of buyer/seller, etc.
I would walk away from any H16 with soft spots in front of the pylons. | | | Re: Going from Wave to Hobie 16... thoughts?
[Re: will_FL]
#78375 06/28/06 11:40 AM 06/28/06 11:40 AM |
Posts: 5,582 “an island in the Pacifi... | The bend in the tillers is normal.
If the soft spots are as big as you describe I'd walk away from the deal. There are a lot of boats available that won't force you into major repair mode the day you buy it. US Sail Level 2 Instructor US Sail Level 3 Coach | | | Re: Going from Wave to Hobie 16... thoughts?
[Re: will_FL]
#78377 06/30/06 08:14 AM 06/30/06 08:14 AM |
Posts: 5,582 “an island in the Pacifi... | More availibility in the fall is a good assumption. Prices should drop too.
If you can find someone with pristine hulls, make a couple of templates so you'll know how far to build up the hulls. Use epoxy and add micro balloons for strength. Throw in some color and you'll be all set. US Sail Level 2 Instructor US Sail Level 3 Coach | | | Re: Going from Wave to Hobie 16... thoughts?
[Re: will_FL]
#78383 07/17/06 12:19 AM 07/17/06 12:19 AM |
Posts: 493 Minnesota | Delaminated hulls???!!!
If the sails and mast are in great shape, I would pay up to $500. But, you are going to have to fix the delaminations.-It's a must fix! Otherwise, run away.
567
guests, and 26
