mainsheet routing through 7:1 block #79506
07/07/06 07:01 PM
07/07/06 07:01 PM
Virginia Beach
Sunvista Offline OP
Sunvista  Offline OP
Virginia Beach
I was told by another beachcat sailor with many years more experience than I that my mainsheet is routed incorrectly. With the blocks lying flat on the deck and looking down, mine is routed through the cleat and ratchet roller up through the bottom roller of the boom block, bottom roller of the main block, center roller of the boom block, center roller of the main block, top roller of the boom block, top roller of main block and tied to the becket of boom block. I do this with concentric winds (no figure 8's). My friend says if properly wound the mainsheet should come off the center roller of the boom block through the ratchet roller and cleat. I don't see how this can be possible without the winds crossing, getting twisted or some kind of complicated figure 8 winding. Is there a preferred method of routing the mainsheet through the blocks or am I doing it right?
Re: mainsheet routing through 7:1 block [Re: Sunvista] #79507
07/07/06 07:37 PM
07/07/06 07:37 PM
Does it work the way you have it?
Re: mainsheet routing through 7:1 block [Re: Jake] #79508
07/08/06 07:44 AM
07/08/06 07:44 AM
Virginia Beach
Sunvista Offline OP
Sunvista  Offline OP
Virginia Beach
Seems to. When my critic took the helm though he thought I wasn't getting the necessary purchase. If it works, don't fix it??
Re: mainsheet routing through 7:1 block [Re: Sunvista] #79509
07/08/06 08:59 PM
07/08/06 08:59 PM
I can't figure out how else you would rig it and keep the angles to a minimum. The 8:1 is rigged as your friend indicates...sounds like you have it right.
0 registered members (), 2,679 guests, and 187 spiders.
