Sail Number Removal #80708
07/21/06 05:58 AM
07/21/06 05:58 AM
Victoria, Oztralia
mattaipan Offline OP
Victoria, Oztralia
Hello All
I was just wondering if anybody could tell me, how to remove the glue left when you peel off the sail numbers.
I have just bought a secondhand main and need to replace the numbers with mine. The sail is dacron.
Thanks
Matt
Taipan AUS329
Oztralia
Re: Sail Number Removal [Re: mattaipan] #80709
07/21/06 06:15 AM
07/21/06 06:15 AM
Acetone
Re: Sail Number Removal [Re: Jalani] #80710
07/21/06 06:21 AM
07/21/06 06:21 AM
Victoria, Oztralia
Victoria, Oztralia
Have you used it before Jalani, with no dramas.
I just happen to have some here.
Matt
Re: Sail Number Removal [Re: mattaipan] #80711
07/21/06 06:33 AM
07/21/06 06:33 AM
I have always used household liquid detergent and a brush, with OK results.
Re: Sail Number Removal [Re: Rolf_Nilsen] #80712
07/21/06 06:45 AM
07/21/06 06:45 AM
Used pure acetone many times with no problem. Don't use nail varnish remover though - apparently it's different?
Re: Sail Number Removal [Re: mattaipan] #80713
07/21/06 06:46 AM
07/21/06 06:46 AM
acetone ... on coated Dacron? That makes me nervous.
Re: Sail Number Removal [Re: Jake] #80714
07/21/06 06:50 AM
07/21/06 06:50 AM
Try it on a scrap of sailcloth or an old sail if you don't believe me Jake. I've used it so many times over the years with no problems. I also used it recently on my homemade spin when some Venture tape accidentally got stuck where it shouldn't have.....
Re: Sail Number Removal [Re: Jalani] #80715
07/21/06 06:52 AM
07/21/06 06:52 AM
OK - that would make me feel better. Your previous post didn't back it up with much info. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: Sail Number Removal [Re: Jake] #80716
07/21/06 07:25 AM
07/21/06 07:25 AM
claus Offline
claus  Offline
I have to do this also this weekend. I have found a sailmakers page that tells how to do it. I am afraid it is in german:
http://www.sobstad.ch/Deutsch/numeros.htm
In a few words, they say you should use lots of solvent like gasoline or turpentine where the old glue ist left over. Once the glue has turned smoother, you carefully use a scraper to get rid of it.
Re: Sail Number Removal [Re: claus] #80717
07/21/06 07:38 AM
07/21/06 07:38 AM
Victoria, Oztralia
Victoria, Oztralia
Thanks for replies, have used acetone, works very well.
Matt
Re: Sail Number Removal [Re: mattaipan] #80718
07/21/06 08:52 AM
07/21/06 08:52 AM
Houston
carlbohannon Offline
Houston
Depends on what adhesive is used. Old style adhesives use mineral spirits. The new ones use alcohol/water (acetone is an alcohol), silicone, 2 part systems and there are plenty I have never run into.
You can start with mineral spirits and move to soap and water and finally add acetone to the soapy water or you can do what I do and buy some 3M decal remover.
There are probably some newer systems that cannot be dissolved. These will not be "sticky". You will have to remove them mechanically.
Re: Sail Number Removal [Re: carlbohannon] #80719
07/21/06 01:10 PM
07/21/06 01:10 PM
Scotland
George_Malloch Offline
Scotland
Funny, it was a ketone was I was at school....
They must have changed it <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
Stealth www.peyc.org.uk
Re: Sail Number Removal [Re: George_Malloch] #80720
07/24/06 08:21 AM
07/24/06 08:21 AM
Houston
Houston
You are right, I am wrong. Acetone works in most cases however sometimes you have to figure out which alcohol they used as a solvent
Re: Sail Number Removal [Re: mattaipan] #80721
07/25/06 08:04 AM
07/25/06 08:04 AM
Gulf Coast
tami Offline
tami  Offline
Gulf Coast
As you've seen, acetone is just fine for any flavor of sails...
if you can get it, what's even better is xylene....
sea ya
tami
Who has worked in a sail repair shop...
Re: Sail Number Removal [Re: tami] #80722
07/26/06 03:08 AM
07/26/06 03:08 AM
Sydney Australia
Berny Offline
Berny  Offline
Sydney Australia
methylisobutylkeytone (sp) is good but it takes the flesh off your fingers and is seriously carcinogenic <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: Sail Number Removal [Re: Berny] #80723
07/26/06 08:58 AM
07/26/06 08:58 AM
Dunedin Causeway, FL
David Parker Offline
methylisobutylkeytone (sp)...is seriously carcinogenic
There are several chemistry-sailors on this forum that I thought would chime in on this thread but has none yet so...
This ketone is not carcinogenic, at least not by the MSDS.
MSDS (material safety data sheet) for methylisobutylketone
If you wonder about your health near an unfamiliar compound (and you should be), look it up. Search "MSDS methylisobutylkeytone". It is a "worst case senerio" document so you should read it for respect due, not to get scared. Look up "sodium chlorde" (table salt) and it looks like bad stuff on an MSDS. Read about HMPA for bad juju. It's a fantastic solvent...and then you die.
Anyway, acetone is the smallest ketone and evaporates too quickly for most summer use. Home Depot sells a heavier but similar ketone called MEK, methylethyl ketone, that is a nice solvent. Methylisobutylketone or cyclohexanone are also simple ketones but are hard to get and are potent paint strippers but unnecessary for this task...and not really carcenogenic. Xylene was suggested but it is a very different compound and will have a very different solvating profile and will work on different glues than acetone or MEK. Same for alcohols.
Keep an arsonal of solvents around, test each on the sail material first, then test on your problem glue. Give them time to work and use with LOTS of ventilation. Don't smoke. Lots of gentle rubbing. Be patient, be careful, be sensible. Don't mix what you don't know about. Don't die.
Re: Sail Number Removal [Re: mattaipan] #80724
07/28/06 12:35 PM
07/28/06 12:35 PM
Hillsborough, NC USA
I
Isotope235 Offline
Isotope235  Offline
I
FWIW, I've used acetone succesfuly, but generally find that it evaporates too quickly and the adhesive dries again before I can get it all scraped up. It takes several applications. Mineral spirits keep the adhesive gummy longer, and lighter fluid works even better. Follow it up with an orange-based product (such as goo-gone), which will also remove the remaining petroleum distillate, and you're good to go.
Eric
0 registered members (), 2,404 guests, and 365 spiders.
