| Sail Number Removal #80708 07/21/06 05:58 AM 07/21/06 05:58 AM |
Joined: Jul 2006 Posts: 461 Victoria, Oztralia mattaipan OP
Posts: 461 Victoria, Oztralia | Hello All
I was just wondering if anybody could tell me, how to remove the glue left when you peel off the sail numbers. I have just bought a secondhand main and need to replace the numbers with mine. The sail is dacron.
Thanks
Matt Taipan AUS329 Oztralia
Matt Harper
Homebuilt Taipan 4.9
| | | Re: Sail Number Removal
[Re: Jalani]
#80710 07/21/06 06:21 AM 07/21/06 06:21 AM |
Posts: 461 Victoria, Oztralia | Have you used it before Jalani, with no dramas. I just happen to have some here.
Matt
Matt Harper
[Re: Rolf_Nilsen]
#80712 07/21/06 06:45 AM 07/21/06 06:45 AM |
Posts: 1,382 Essex, UK | Used pure acetone many times with no problem. Don't use nail varnish remover though - apparently it's different?
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: Sail Number Removal
[Re: mattaipan]
#80713 07/21/06 06:46 AM 07/21/06 06:46 AM |
Posts: 12,310 South Carolina | acetone ... on coated Dacron? That makes me nervous.
Jake Kohl | | | Re: Sail Number Removal
#80714 07/21/06 06:50 AM 07/21/06 06:50 AM |
Posts: 1,382 Essex, UK | acetone ... on coated Dacron? That makes me nervous. Try it on a scrap of sailcloth or an old sail if you don't believe me Jake. I've used it so many times over the years with no problems. I also used it recently on my homemade spin when some Venture tape accidentally got stuck where it shouldn't have.....
[Re: Jalani]
#80715 07/21/06 06:52 AM 07/21/06 06:52 AM |
Posts: 12,310 South Carolina | acetone ... on coated Dacron? That makes me nervous. Try it on a scrap of sailcloth or an old sail if you don't believe me Jake. I've used it so many times over the years with no problems. I also used it recently on my homemade spin when some Venture tape accidentally got stuck where it shouldn't have..... OK - that would make me feel better. Your previous post didn't back it up with much info. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
#80716 07/21/06 07:25 AM 07/21/06 07:25 AM |
Posts: 160 | I have to do this also this weekend. I have found a sailmakers page that tells how to do it. I am afraid it is in german: http://www.sobstad.ch/Deutsch/numeros.htmIn a few words, they say you should use lots of solvent like gasoline or turpentine where the old glue ist left over. Once the glue has turned smoother, you carefully use a scraper to get rid of it. | | | Re: Sail Number Removal
[Re: claus]
#80717 07/21/06 07:38 AM 07/21/06 07:38 AM |
Posts: 461 Victoria, Oztralia | Thanks for replies, have used acetone, works very well.
Matt
Matt Harper
[Re: carlbohannon]
#80719 07/21/06 01:10 PM 07/21/06 01:10 PM |
Posts: 131 Scotland | Funny, it was a ketone was I was at school.... They must have changed it <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" /> | | | Re: Sail Number Removal
[Re: George_Malloch]
#80720 07/24/06 08:21 AM 07/24/06 08:21 AM |
Posts: 778 Houston | Funny, it was a ketone was I was at school.... They must have changed it <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" /> You are right, I am wrong. Acetone works in most cases however sometimes you have to figure out which alcohol they used as a solvent | | | Re: Sail Number Removal
[Re: Berny]
#80723 07/26/06 08:58 AM 07/26/06 08:58 AM |
Joined: Jun 2001 Posts: 890 Dunedin Causeway, FL David Parker
Posts: 890 Dunedin Causeway, FL | methylisobutylkeytone (sp)...is seriously carcinogenic There are several chemistry-sailors on this forum that I thought would chime in on this thread but has none yet so... This ketone is not carcinogenic, at least not by the MSDS. MSDS (material safety data sheet) for methylisobutylketone If you wonder about your health near an unfamiliar compound (and you should be), look it up. Search "MSDS methylisobutylkeytone". It is a "worst case senerio" document so you should read it for respect due, not to get scared. Look up "sodium chlorde" (table salt) and it looks like bad stuff on an MSDS. Read about HMPA for bad juju. It's a fantastic solvent...and then you die. Anyway, acetone is the smallest ketone and evaporates too quickly for most summer use. Home Depot sells a heavier but similar ketone called MEK, methylethyl ketone, that is a nice solvent. Methylisobutylketone or cyclohexanone are also simple ketones but are hard to get and are potent paint strippers but unnecessary for this task...and not really carcenogenic. Xylene was suggested but it is a very different compound and will have a very different solvating profile and will work on different glues than acetone or MEK. Same for alcohols. Keep an arsonal of solvents around, test each on the sail material first, then test on your problem glue. Give them time to work and use with LOTS of ventilation. Don't smoke. Lots of gentle rubbing. Be patient, be careful, be sensible. Don't mix what you don't know about. Don't die. | | |
157
guests, and 99
