Repair Clew Plate (rivets?) #82486
08/14/06 07:25 AM
08/14/06 07:25 AM
N
nhsailor Offline OP
nhsailor  Offline OP
N
The clew plate on my jib has popped all it's rivets and seperated. Is there a special rivet I need to get to replace what's there? Any tips?
Re: Repair Clew Plate (rivets?) [Re: nhsailor] #82487
08/14/06 07:39 AM
08/14/06 07:39 AM
Sailrite.com has the rivets you want, and a new clew plate if you need one. If you are buying new rivets, get the tool to install them also.
I prefer to hand-stitch clew plates on to my jibs. More work as you need custom clew plates (we make them ourself), but you can easily see any wear and fix it before they break. Not a solution for you I am afraid, as you would need to install new reinforcement patches to take the thin thread instead of rivets.
If the clew plate has come loose, how old is this jib? Perhaps it is due for replacement anyway..
Re: Repair Clew Plate (rivets?) [Re: Rolf_Nilsen] #82488
08/14/06 08:39 AM
08/14/06 08:39 AM
N
nhsailor Offline OP
nhsailor  Offline OP
N
Yes, it is old. I can't replace the sail at the moment though. I need a quick fix, I'll look at the hardware store for aluminum rivets.
Re: Repair Clew Plate (rivets?) [Re: nhsailor] #82489
08/14/06 10:22 AM
08/14/06 10:22 AM
2017 F18 Americas Site
Dan_Delave Offline
Dan_Delave  Offline
years ago I fixed a ripped out clewplate using small stainless steel screws. Worked for a long time.
Re: Repair Clew Plate (rivets?) [Re: Dan_Delave] #82490
08/14/06 10:52 AM
08/14/06 10:52 AM
Connecticut
Eric Anderson Offline
Connecticut
You may need to use small stainless bolts if the rivit holes are enlarged/ corroded too much. YOu can also get washers for 1/8" rivits that act as little backing plates. The original rivits were probably peened. These don't seem to last as well standard rivits aplied with a rivit gun.
0 registered members (), 4,249 guests, and 644 spiders.
