| Rules on late starters #8371 07/01/02 10:51 AM 07/01/02 10:51 AM |
Joined: Jun 2001 Posts: 342 Lake Murray, SC,USA Cary Palmer OP
Posts: 342 Lake Murray, SC,USA | What's the rule on late starts? Is there a time limit after which the rules can effect your points, and how can you work this to your advantage? Recently we had a problem, repaired it and subsequently latestarted. There were a # of no shows for the race from the previous day. (# of boats had gone from 7 or 8 down to 4 or 5 in our class) Figured if we at least latestarted then we got last place points in a smaller class for that 1st race of the day instead of a DNS.
A little supportive wisdom here, Gentlemen?
CARY ACAT XJ Special C&C 24
| | | Re: Rules on late starters
[Re: Cary Palmer]
#8373 07/01/02 02:13 PM 07/01/02 02:13 PM |
Posts: 3,116 Annapolis, MD | This is an issue that is resolved by your standard sailing instructions. on page 81 of the rule book they recomend statement 10.4 "a boat starting later then X minutes after her starting signal will be scored did not start This changes rule A4.1
So. If your SI's ommit this proviso. so long as the line is established you could start and sail the proper course. The SI's may also specify qualifiers to finishing. eg. time limit to finish.
If the RC has gone home for the day. a yacht is take their time and report to the RC as soon as possible. I believe that this is in the rule book and it is usally restated in the SI's.
crac.sailregattas.com
591
guests, and 41
