| Pointing #85257 09/23/06 08:42 PM 09/23/06 08:42 PM |
Joined: Oct 2005 Posts: 951 Brisbane, Queensland, Australi... ncik OP
Posts: 951 Brisbane, Queensland, Australi... | I can't point! The boat is going very well with plenty of speed when sailing to the jib telltales but it is well below the other cats (H16's, Taipans, F18's). When I try to point with them the speed just dies completely. The jib is sheeted in about 15-20cm from the inboard gunwhale(will measure precisely today), and it can come in further, but I'm reluctant to do that, it seems to close the slot too much for my liking.
Is this common for mossies, or should I be adjusting the setup?
Admittedly the water was very lumpy yesterday and maybe that was affecting our speed when trying to point, but even in relatively flat water at Lake Cootharaba we were pointing lower than all other cats, but we were going fast enough for it to not be a problem (our VMG was still good).
Next thing I will try is to tighten up the rig tension a bit, reducing forestay sag hopefully.
Any other suggestions or experiences. | | | Re: Pointing
[Re: ncik]
#85258 09/23/06 08:57 PM 09/23/06 08:57 PM |
Posts: 265 Sydney AUST | I had the same problem yesterday. Also how do all you othre mozzies compare with hobie 17s (speed wise)
---Ben Cutmore--- --MOSQUITO 1704--
| | | Re: Pointing
[Re: becjm]
#85259 09/24/06 12:28 AM 09/24/06 12:28 AM |
Joined: Mar 2003 Posts: 943 East Gippsland, Australia Tim_Mozzie
Posts: 943 East Gippsland, Australia | Hobie 17s are rated faster than a Mosquito but there's not much in it, so it's not uncommon for a Mosquito (on a good day) to finish (just) ahead of a 17.
As far as pointing goes, a Mozzie definitely points higher than a H17 (they don't have any centreboards), and the Mozzie should point at least as high as the other cats - so keep working on this!
If you can tighten the rig that should help some, but don't get too carried away. I've been told that the jib luff will stand up better if you get the mainsheet tension on before you tighten the jib sheets. The jib luff tension is mostly provided by the mainsheet.
I also notice the sloops have their traveller set up so it can be really positively centred (not that important for cat-rig).
Hopefully some sloop sailors will be able to throw more light on this.
Tim Shepperd Mosquito 1775 Karma Cat
304
guests, and 51
