Outdrive question (NCR) #8791
07/15/02 01:24 PM
07/15/02 01:24 PM
Sailortect Offline OP
I figure SOMEBODY on this board has got to be an outdrive expert....
a friend's outdrive got all eaten up with elecrolysis last season because he didn't remove the coating on the zinc before installation. a consequence of this is that the hydraulic rams are shot, and the large steel pin that anchors the rams to the upper end of the outdrive got its threads eaten off. new rams are on the way, but now the pin's the problem... it won't come out.
is this thing pressed into the housing at the factory, or should it be loose and it's probably just electrolytically welded itself to the housing? cut-and-drill to remove it or just bang like hell with a 4pound sledge?
thanks.
Re: Outdrive question (NCR) [Re: Sailortect] #8792
07/15/02 04:58 PM
07/15/02 04:58 PM
toronto, canada
basket.case Offline
basket.case  Offline
toronto, canada
Re: Outdrive question (NCR) [Re: Sailortect] #8793
07/15/02 07:11 PM
07/15/02 07:11 PM
I am assuming this is either a Mercruiser, OMC Cobra or late model Volvo Drive.
You need to purchase a product called PB Blaster from your local NAPA store and soak that pin for at least 24 hours. Then take a rubber mallet and beat it out. If the rubber won't move it, switch to metal and a brass punch. If that fails, use the hammer and then you'll have to replace the pin.
Re: Outdrive question (NCR) [Re: Sailortect] #8794
07/20/02 02:51 PM
07/20/02 02:51 PM
toronto, canada
basket.case Offline
basket.case  Offline
toronto, canada
0 registered members (), 386 guests, and 41 spiders.
