| Re: To trap or not to trap - THAT IS THE QUESTION!
[Re: Robi]
#91474 12/06/06 09:22 AM 12/06/06 09:22 AM |
The simple answer is ;
"Dependents on the conditions and the course."
Didn't we cover this about 4 weeks ago already ?
[Re: Wouter]
#91475 12/06/06 09:35 AM 12/06/06 09:35 AM |
Joined: Jul 2004 Posts: 2,718 St Petersburg FL Robi OP
Posts: 2,718 St Petersburg FL | "Dependents on the conditions and the course." Without writing a huge reply can you elaborate. I think that quote can be applied to a lot of sailing questions. Didn't we cover this about 4 weeks ago already ? Maybe we did, I dont know. That is why I am asking TODAY. | | | Re: To trap or not to trap - THAT IS THE QUESTION!
[Re: Robi]
#91477 12/06/06 09:58 AM 12/06/06 09:58 AM |
Posts: 6,049 Sebring, Florida. | Robi, what you are asking is the very essence of downwind speed itself. Only the Master knows for sure, which will be faster in a given wind condition and on a given course. We mortals can first start with the two extremes: light air (5kts) and heavy air (20 kts). Obviously in light air you cannot trap, so you sit way inboard and try to get the hull up to minimize drag. Heat it up, lift the hull, slowly bear away while trying to keep it up, rinse and repeat until it's time to gybe. In heavy air you must trap or swim, but you will still want the hull up for less drag, as long as it won't lead to swimming.
So the "change over" point is the great unknown and that is where experience and skill come into play. If we go half way between 5 and 20, that is 12.5 knots of wind. So about there you will need to chose one. Having the experience to know which one to choose is what makes fast guys fast. But the wind is never that steady. What is fast right now might not be fast when a puff hits or when you sail into a hole. You have to shift gears a lot when it's gusty and the fast guys are the ones who are very good at shifting gears quickly.
I have crawled up the mountain to ask the Master and he told me this: "Speed is the only thing that matters, so make it go as fast as you can, as long as you can."
And remember, gaining speed will move the apparant wind forward, thus allowing you to go deeper, and at greater speed, until it bleeds off and you have to heat it up again.
Some like it hot, others like to go deep. In medium conditions it's always tough to make that choice, so I follow the fast guys... <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" />
Blade F16 #777
[Re: Timbo]
#91478 12/06/06 10:23 AM 12/06/06 10:23 AM |
Posts: 1,121 Eastern NC, USA | Personally, I do not trap with spin when buoy racing. Realize that I sail on a relatively small lake with short courses usually. I do use the foot straps on the tramp and "droop" hike at the rear beam (a la Kilkenny).
I think it all depends on the distance of the leg, the number of anticipated gybes, exact conditions - but as a general rule, I do not like to waste the time.
Tom | | | Re: To trap or not to trap - THAT IS THE QUESTION!
[Re: Rolf_Nilsen]
#91480 12/06/06 10:57 AM 12/06/06 10:57 AM |
Posts: 1,382 Essex, UK | Based on the last two UK Nationals, I'd say that because a Stealth/F16 tacks so easily and quickly, we don't tend to 'bang the corners'. It was especially noticeable at Mumbles this year that people were prepared to tack to cover/break cover/use the shifts etc. and upwind on a 50 minute race you might easily put in 4 or 5 tacks, downwind I reckon most people went for 3-4 gybes unless they were duelling (as I was on more than 1 occasion) and you might put in up to 7 or 8!
Since getting the Stealth I've learned to be more like the Assy skiffs and dinghies and keep well under and inside the laylines to a mark and it's paying dividends! Tacking just a few yards for clear air no longer holds any fear for me as the boat spins so quickly and accelerates so easily. You're gonna love it Rolf! <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: To trap or not to trap - THAT IS THE QUESTION!
[Re: pkilkenny]
#91483 12/06/06 12:07 PM 12/06/06 12:07 PM |
Posts: 3,528 Looking for a Job, I got credi... | I'm convinced that wiring downwind is faster once you get to the "critical" wind speed. This was about F3 on my Inter 17 and I'm assuming (for now) it will be lower on the 16 as it's lighter. BUT when it gets real windy then it's safer to not wire as it is just too wild. The "too wild" point will no dubt go up the wind speed as I get to grips with the 16.
First sail was in about a F3 last weekend and wiring was 100% (IMO of course) quicker then not wiring - you just get heated up so much more and so the apparent wind goes forward and so you bear off more(it is however harder work!). Sailing the 17 in a top F4 I could sail DEEPER flying a hull on the wire, than I could hitting on the side flying a hull as there was more speed, this moved the apparent wind forward (so I had to sheet in harder) and then you go deeper - This may sound mad, but it works !
There comes a point (as I said above) where it's just too wind to be out on the wire.
The size of the course also matters as does the number of boats around you (and so the probabily of needing a quick gybe to get out or trouble).
It's always a trade off between VMG and manoverability (and ability to react to shifts), it is also usefull to be able to gybe back into gusts quickly - thus sometimes it pays NOT to wire so you can ride a narrow wind band down hill.
It's all a trade off really.
I'll be wiring "hungry monster" downhill most of the time.
F16 - GBR 553 - SOLD I also talk sport here | | | Re: To trap or not to trap - THAT IS THE QUESTION!
[Re: fin.]
#91484 12/06/06 12:09 PM 12/06/06 12:09 PM |
Posts: 465 Oxford, UK | Bob was pretty forceful in his statement to me that bouy racing is about sailing the shortest distance.
Well that's clearly an over simplification, as I can assure you that sticking the thing dead down wind is *not* the fastest way to the mark even though it is the shortest route. Similarly, if you sail at 90 degrees to the wind, you'll never get to the downwind mark. Somewhere in between is the fastest angle, and that's where the challenge lies. I think it really depends on the conditions, and not just the wind strength, but also the size of gusts and the size of waves. Given how Aaron sails when he's kicking us all, I'm confident that there comes a point where in a steady wind trapezing is faster. If the wind is gusting from non-enough to trapeze to too much to trapeze, you'll do better to sit in: being sat in in the gusts doesn't do much harm, as you just go deeper, but being trapped in the lulls does, because the boat gets horribly out of trim. Paul | | | Re: To trap or not to trap - THAT IS THE QUESTION!
[Re: pdwarren]
#91485 12/06/06 12:28 PM 12/06/06 12:28 PM |
Posts: 3,348 | Bob was pretty forceful in his statement to me that bouy racing is about sailing the shortest distance.
. . . sticking the thing dead down wind is *not* the fastest way to the mark even though it is the shortest route. . . Paul True enough! As I recall, keeping 90 degrees apparent wind was an essential part of the bargain. Guess I should have mentioned that small detail earlier. <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" /> | | | Re: To trap or not to trap - THAT IS THE QUESTION!
[Re: fin.]
#91486 12/06/06 01:07 PM 12/06/06 01:07 PM |
Posts: 465 Oxford, UK | True enough! As I recall, keeping 90 degrees apparent wind was an essential part of the bargain. Guess I should have mentioned that small detail earlier. <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" />
Ah, OK <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> I definitely think it pays to go a bit hotter than 90 degrees apparent wind. I tend to go for about 70. I was quite surprised to discover that it pays even in very light wind. At one of the races at Grafham the wind dropped right off and I was resisting the temptation to go high. When I realised the F18s were getting past me, I started sailing the same angles as them. The angles felt really high, but I was now beating them downwind. Paul | | | Re: To trap or not to trap - THAT IS THE QUESTION!
[Re: pdwarren]
#91487 12/06/06 03:54 PM 12/06/06 03:54 PM |
Posts: 9,582 North-West Europe | I've been in situations where it payed to do either of these opposing things, it came down to specifics to determine which was best. For me control is most often the deciding factor. Most often I hike out as Paul does. I don't have toestraps yet, but I really do want them as in certain short waves I want to trap as well to prevent the bows from burying to much. If I sit in then, I find that the boat both stops and wants to capsize. With one on the wire it tends do punch throught the next wave and not heel as much.
I've sailed through the fleet of F18's at my club both when trapezing and when not trapezing in very similar conditions. I couldn't tell you why. I just did what felt fast at the time. I always decide at the moment what is best.
[Re: Robi]
#91489 12/06/06 05:28 PM 12/06/06 05:28 PM |
Joined: Nov 2005 Posts: 337 Victoria, Australia C2 Mike
Posts: 337 Victoria, Australia | Ive noticed some folks trap out with spin up during bouy racing.
What does the rest of the F16 class do around the world? I have learned with the little racing I have done, that trapping out with spin up is just a big pain in the butt for bouy racing. Sometimes the course is to short to go through the trouble.
Also while chatting with Bob Cury, he said if you trap out you have to heat up too much in order to build aparent wind making you sail a higher course. Makes total sense to me.
What do you all think, do or practice? Not quite F16 but it might be a help - as a rough rule of thumb, on the Tiger when we are 2 stringing up wind, we put the crew on the wire downwind. 1 on the wire upwind has the crew on the windward deck off breeze and on the tramp up wind = crew to leeward with the spi. Note: This is *very* rough. You need to take into account the sea conditions, wind, other boats and where the next mark is. Tiger Mike | | | Re: To trap or not to trap - THAT IS THE QUESTION!
[Re: spfechner]
#91490 12/06/06 05:35 PM 12/06/06 05:35 PM |
Posts: 465 Oxford, UK | How hard is it to maintain this position? I have been a bit leary of doing it much solo without other boats around. Are you able to keep trapping successfully in moderate to higher winds with the spin out? It seems like it would be hard to maintain without footstraps if you had to quickly bear off or dump the spin sheet to keep from flipping.
The problem I have is bearing off too much, having the boat slow down and then me shuffling inelegantly forwards to avoid losing grip/balance. Doesn't lead to capsize, but it is annoying. I'm going to be putting footstraps on this weekend, and I'm also considering some pro grip. This made a world of difference when we put it on the Tiger. Paul | | | Re: To trap or not to trap - THAT IS THE QUESTION!
[Re: Robi]
#91492 12/06/06 07:41 PM 12/06/06 07:41 PM |
Posts: 1,246 Orlando, FL | I find the following technique allows me to trap without much effort. For this example I'll assume a starboard tack downwind under spi uni (solo).
Once on the proper starboard heading (assuming you just jibed or rounded "A"), I hook up with my trapeze. I situate myself near the rear beam with my butt hanging over the hull--ie I'm suspended by the trap' line. Right leg is extended with foot against the (starboard) stay plate. Left leg is collapsed with my knee near my chest, foot on the hull.
From this position I can re-position my weight forward or aft.... or .... extend my left leg and voila' I'm full trapped.
USA 777
5,958
guests, and 539
