Shared Starts at Tradewinds #94078
01/02/07 10:44 PM
01/02/07 10:44 PM
Eastern NC, USA
tshan Offline OP
tshan  Offline OP
Eastern NC, USA
The US F16 class is trying to get some support for multiple fleets sharing the same starting sequence, course and timing at the Tradewinds Regatta. Each class of X or more boats will be scored as a fleet within the larger start. X being the number that previously defined whether or not you had a separate start.
The benefits of this scenario are: more competitive starts, more boats on the course to engage tactically, camraderie across fleets (enhance the conversation around the keg at night), easier start sequence management for the RC (= more races potentially) and a great chance for the US Sailing Handicap Committee to collect data from a large/well attended regatta.
The down sides are: timing of each boat taxes the RC (offset by fewer starts??) and potential for a non-fleet boat mixing it up with two contenders of another fleet.
Rick has agreed to listen to the sailors and combine at least the Open Low Portsmouth and the F16s. If anyone else in boats of similar sailing characteristics (N20, F18, etc.) would like to participate, then speak up. I am sure we can have more in-depth discussions at the bar Friday night.
I know the F18s will have a large enough group for their own competitive racing, but the invitation is extended to them as well.
Thoughts? This is NOT a discussion about Open/Handicap racing. It is about inclusion, I think one of the biggest problems in US cat sailing is the plethora of boats to choose, then as soon as 5 of the same make/model show up to a regatta they want to be sanctioned off and treated as a separate entity. Not good for keeping new sailors in the "in group". My two cents.
Re: Shared Starts at Tradewinds [Re: tshan] #94079
01/03/07 03:45 AM
01/03/07 03:45 AM
I'm not sure that what you are asking is different from normal. And I think you have got it backwards. Rick has ALWAYS combined multiple classes in the starts at Tradewinds. He does it to reduce the number of starts and also to make it more fun for fleets that don't have many boats.
It is only if a class specifically does NOT want to be combined with another class that they ask Rick if they can have a SEPARATE start. That only happens if there is some compelling reason for it.
It is very nice for the F16 class to invite other classes to start with them, but Rick probably would have combined the other classes in that start anyway.
It sounds like the only difference is that you are asking the race committee to take times on ALL the boats in each start. If that is the case, my question is: Why? What is the purpose?
Re: Shared Starts at Tradewinds [Re: Mary] #94080
01/03/07 08:15 AM
01/03/07 08:15 AM
Michigan, USA
sparky Offline
sparky  Offline
Michigan, USA
Les Gallagher
Re: Shared Starts at Tradewinds [Re: Mary] #94081
01/03/07 08:21 AM
01/03/07 08:21 AM
Why, certainly it's a desperate search for ammunition for the trash talking machine gun of the F16 class! (which, by the way, is apparently a fad). <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: Shared Starts at Tradewinds [Re: Jake] #94082
01/03/07 08:25 AM
01/03/07 08:25 AM
The F16s didn't coin the "midget boat" phrase. With the exception of Matt & Gina, you guys need to be more concerned with Curry anyway! <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" />
Re: Shared Starts at Tradewinds [Re: Mary] #94083
01/03/07 09:24 AM
01/03/07 09:24 AM
Eastern NC, USA
tshan Offline OP
tshan  Offline OP
Eastern NC, USA
We are only making it known that we would like for any fleet of similar characteristics to start as a single group. We value the larger fleet racing and will not be asking for our own start. If other fleets do not know that this invitation is open, then they cannot petition to be a part of it.
The ultimate decision obviously rests with the PRO/RC. There have been times in the past, maybe not at Tradewinds, where many small starts occurred, time between races was very long, etc. I was hoping to avoid that as much as possible.
I am not asking that all times be taken, only times in a large combined fleet (potentially large, may not happen). If an OD/Formula fleet chooses to race on their own, then they do not need to be timed.
I apologize if it came across as being self serving.
Re: Shared Starts at Tradewinds [Re: sparky] #94084
01/03/07 10:03 AM
01/03/07 10:03 AM
Les (Sparky),
But timed results are only valid in terms of boats that are all racing on Portsmouth (against the clock).
If you have a start that involves one-design class(es) (racing against the other boats within their class) and also Portsmouth class(es) (racing aganst the clock), and you take times on all the boats in that particular start, it is like comparing apples and oranges.
The Portsmouth boats only have to worry about strategy to get around the course in the shortest possible time. The one-design classes also have to worry about tactics, which can often result in them taking longer around the course than if they did not have to worry about things like covering their opponents even if it takes them to a side of the course with less wind and slower speeds.
So how would the times be relevant in terms of Portsmouth handicapping?
Re: Shared Starts at Tradewinds [Re: Mary] #94085
01/03/07 10:35 AM
01/03/07 10:35 AM
BrianK Offline
BrianK  Offline
I think there was one year where the F16s started with the other classes, but sailed the inner course vs the outer course. I believe the F16s prefer to sail the same course as the other spins.
However, I would prefer not to start, or sail, with the F16s, and I would ask that their course be set on the ocean side vs our side, and that they not be allowed to eat at Hobo's either. Thats is unless Pete doesnt show up, then you guys are cool.
Re: Shared Starts at Tradewinds [Re: BrianK] #94086
01/03/07 10:41 AM
01/03/07 10:41 AM
Okay, I'll stay home.
Re: Shared Starts at Tradewinds [Re: BrianK] #94087
01/03/07 12:07 PM
01/03/07 12:07 PM
Westport, Ma. U.S.A.
Brian_Mc Offline
Brian_Mc  Offline
Thanks Brian and Pete! LOL! Sure wish I could be there, but am counting on all of you for great reports! Bri, any video coming?
Re: Shared Starts at Tradewinds [Re: Brian_Mc] #94088
01/03/07 12:40 PM
01/03/07 12:40 PM
BrianK Offline
BrianK  Offline
Yes, we are going to be experimenting with the Brian vs Chuck cams.
Re: Shared Starts at Tradewinds [Re: BrianK] #94089
01/03/07 01:40 PM
01/03/07 01:40 PM
I think we need another installment of "Inside Cat Racing" as well. Finally get to bottom of what JC is doing in his room late at night to make him so fast. I mean, is Kenny polishing his head with canuba wax or what??
Inquiring minds want to know!
Re: Shared Starts at Tradewinds [Re: Timbo] #94090
01/03/07 02:21 PM
01/03/07 02:21 PM
MERRITTISLAND, FL
Matt M Offline
Matt M  Offline
MERRITTISLAND, FL
Originally Posted by "dingram"
If you guys want race straight up with the F18's, then bring it. If you want to be scored seperate or you want to keep your dpn, then you aren't bringing anything to the table that I'm interested in.
Even if we are on the same start, I'm still only going to race those in my class. Again, when would I ever want to engage someone I'm not racing against?
I'm in for straight up racing. My only sugestions was that because it is midwinters for the class and a Harken seriers race a separate class score be tracked as well.
It makes no sense to put boats of drastically dissimilar performance together on a start. (Waves vs I20) If they have the capability to be in the same ball park, then we are doing ourselves a disservice to separate into a million splinter groups. If I am on a course, I am judging my performance by those around me whether they are in the same boat or not. There are people I will most likely not beat no matter what boat I am on, but that does not mean I don't try. There is a range of ability in all of the classes and has nothing to do with the hull length. The good teams are going to win the start and the bad teams are going to get rolled by somebody.
I'm comming down for the party anyway so all this is a little moot. Sailing is a social thing for me. I do not get money for this, but I do have competitve nature so on the water I will try to beat whoever is close to me. We do not have enough numbers to be elitist. You sail together, you have the same stories about what happened to who afterwards. There are no huge fleets of C fleet anymore. New sailors coming in are having to race with guys with years of experieince. If the last place I20 team has a great battle all weekend with the last place F16 team then who cares if they are not in the same "class", it was good racing and they probably both learned lots.
M2C
Matt
Re: Shared Starts at Tradewinds [Re: Matt M] #94091
01/03/07 03:11 PM
01/03/07 03:11 PM
M2C
Matt
You're the Mattador from now on.
Re: Shared Starts at Tradewinds [Re: Matt M] #94092
01/03/07 04:48 PM
01/03/07 04:48 PM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
M2C
Matt
I just want to make it clear that I do not speak for the F18 fleet. If both the F18 fleet and F16 fleet are down with this arrangement then let's do it. But, I'm not at all interested in sailing straight up against the N20's.
F18 USA 242
http://www.solarwind.solar
Re: Shared Starts at Tradewinds [Re: David Ingram] #94093
01/03/07 04:51 PM
01/03/07 04:51 PM
Wuss
<img src="http://www.catsailor.com/forums/images/graemlins/crazy.gif" alt="" />
Re: Shared Starts at Tradewinds [Re: waterbug_wpb] #94094
01/03/07 04:57 PM
01/03/07 04:57 PM
BrianK Offline
BrianK  Offline
Stank, dont even make us start in on you, your pathetic attempt to hook up as crew buys you nothing.
P.S. I might need crew for Tradewinds. What you weighing?
Re: Shared Starts at Tradewinds [Re: BrianK] #94095
01/03/07 05:53 PM
01/03/07 05:53 PM
F18OxJ Offline
F18OxJ  Offline
My vote is if we get 10 or more F18s then we should race as our own fleet. It is our mid-winters and we should be scored as our own fleet. Also, I'm not sure if a separate start is required for the race to count for our class rankings (Ding - any idea?).
My thinking is that if you want to race with the F18s then get an F18.
I'm not a fan of Portsmouth racing and prefer to avoid it as much as possible. That is a big reason I race an F18, because we typically get good turnout of boats.
Now, if F16s want to race straight up then maybe I could be talked into that.
One problem with clumping boats of different speeds into a single start is that you may have fewer starts, but you end up waiting longer for everyone to finish.
Re: Shared Starts at Tradewinds [Re: F18OxJ] #94096
01/03/07 06:12 PM
01/03/07 06:12 PM
Clermont, FL, USA
Clermont, FL, USA
What freaking Olli said!
I'll have to check with Tracie about the scoring I suspect that might be an issue.
F18 USA 242
Re: Shared Starts at Tradewinds [Re: tshan] #94097
01/03/07 06:21 PM
01/03/07 06:21 PM
I think the main invitation given out the F16 class to all SIMILAR performant boats was lost somewhat in the thread.
This invitation is the result of my proposal to invite the F17 (nacra 17's) to the F16 fleet (our fleet). By this time the F16 class has enough boats at the tradewinds regatta to demand their own start. The US F16 association has decided NOT to excersize that right because it does not believe this to be in the best interest of US cat sailing or even in the best interest of the F16 sailors.
Certainly on my accord I feel that it is just plain silly to have 2 nacra 17's compete in the open Portsmouth class when these boats are so similar to the F16's that it will be alot more fun for all to welcome them to the F16 fleet. This is what lead to my proposal of inviting the Nacra 17's to race the F16's on a first in wins basis. Call it a challenge to Bob Curry and friend to show how much of a FAD boat the F16's really are.
After discussing this proposal in the US F16 class Tom Shannon came back to us with an even wider invitation. So not only Nacra 17's are welcomed but all catamarans of comparable performance. I intepreted this as an invitation to both the Nacra 17's and F18's to form a single fleet that races on "first in wins". A bold move by the US F16 association as indeed the F18's have their midwinters at tradewinds, but still it was felt that an invitation should be truly open to all. And so it was announced.
There was of course another element in Toms invitation and one that confused many of us. This was the point that it may be enjoyable if all boats of similar behavour were groupped together. This would put the I-20's and N6.0's in the fleet with the F16's and nacra 17's because all are pretty close together in speed. This may indeed be a little open minded for most US sailors. But the this part of the invitation stands.
Still I personally feel that the invitation to the nacra 17's and F18's is the most important one as those boats are truly very comparable around the course and can race first in wins with a "crate of beer" price to final winner.
So Nacra 17 sailors what do you say ? Bob ? F18's ?
